Going to crack my tranny's pan to fix shift flare, what else to fix? - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 07-24-2006, 03:44 AM Thread Starter
artherd's Avatar
My early 99 has a shift-flare that might be getting worse (or might be my imagination.) Truck is new to me, so I still haven't flushed tranny fluid yet, etc. I aim to go in there and flush out all fluid, open the pan, change the inboard filter, change the solonoid per the shift flare TSB ( http://www.ford-trucks.com/tsb/fullt...hp?tsb=99-8-1) to part # F81Z-7G391-CB.
What else (that is relatively easy.) should I swap/change while I am in there?
- 99 F350 CC, LB, Dually - 01/98 Production Date - Tommy Gate hydraulic liftgate (awesome & highly recommended.)
- 19.5" Goodyear G622s on F550 wheels front and rear.
- F550 brakes. 1050CFM thermostatic 2nd tranny cooler. Prodigy brake controller.
- 4" exhaust to the turbo. 4-pillar EGT, TRANS, WATER, BOOST.
- Ford Ambulance APCM/AIC. Severe Duty AIS.
- Code 3 2100 LED Lightbar, Perimiter Strobes, LED-X lights, Electric (firetruck type) warning horn & PA.
- 4 batteries, Xantrex 250A automatic battery combiner/splitter.
- Dual Xantrex Prosine 2.0KW inverters for 110/220v, Laser printer/copier, plasma cutter, welder.
artherd is offline
post #2 of 12 (permalink) Old 07-24-2006, 07:07 AM
NCHornet's Avatar
Re: Going to crack my tranny's pan to fix shift flare, what else to fix?
Change out your valvebody with one from Greg Evans (FTVB)sold at Dieselsite, or the BTS valvebody from BTS. You will love the way the truck will shift, no more long drawn out shifts, quick and to the point, which has to help prolong tranny life. PM me with any ???
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
NCHornet is offline
post #3 of 12 (permalink) Old 07-24-2006, 06:18 PM Thread Starter
artherd's Avatar
Thanks NChornet, are both Dieselsite and BTS valvebodies rougly created equal?
artherd is offline
post #4 of 12 (permalink) Old 07-24-2006, 06:55 PM
My Photos: (22)
The FTVB that is sold by DieselSite tends to shift firm at all times. The BTS one has a more progressive shifting nature where it is soft at low throttle and firm at heavy throttle. I have had both and liked the FTVB at first, but the firm shifting when just cruising around starts to wear on you plus I had a shift flare that I couldn't get rid of. Switched to the BTS-VB and starting enjoying my truck more and the shift flare went away. OH, and my tranny already had the upgraded shift solenoids.
Hammer
Check out what I recently bought:
I still have the:
2001 F250 Lariat CC/SB 4x4 7.3 auto
TERMINATOR HPOS...Ceramic coated Garrett GTP-38R with BBHA & GDS outlet...DP-tuner Big Oil Program...ITPdiesel Fueling and overboost regulator...6.0 CAC...AFE Stage-II PG7... Magnaflow 3.5dp/4exh...5R110 TC, BTS VB, John Wood pump mods, & V10 cooler...Schaeffer's 9000 5w-40...Oilguard bypass...and other stuff
On the shelf collecting Dust: <font color="green"> Stainless Grill Overlay </font>
<font color="red">
</font>
Get Your Tuning Here:
and your Fuel kits here:
TheHammer69 is offline
post #5 of 12 (permalink) Old 07-25-2006, 03:45 PM
You might want to double check the SP before buying a replacement as they are non returnable. If the on in there is green(I think) then it already is the correct one, if orange then it is the older style. I had the same problem and turns out the SP was already a later model and replacing it only made it worse. I have heard that swapping out the PCM to a later code corrects the shift flare on our models. I am going to try taht first before going through all the BS of replacing tranny parts. Besides I may just get it preloaded with the DP 80HP program.
DD 2013 Ford Fusion Hybrid Titanium
Sold due to neglect
U.S.N. Paradise BB91904
'99 F350 CC LWB DRW
Mods, SuperHyper Improbability drive stage II.
Hypermax 5" turbo back system, triple pillar guages, Heater core shutoff. AEM Brute Force intake. 3.73 gearing. DP PCM with 80HP Installed!
ACD2 is offline
post #6 of 12 (permalink) Old 07-25-2006, 04:10 PM
My Photos: (22)
Hold on a second....I may be wrong, but my understanding is the solenoid pack with the green plastic tabs is the OLD version and the Solenoid pack with the orange plastic tabs is the NEW one.
Hammer
I still have the:
<font color="red">
</font>
post #7 of 12 (permalink) Old 07-25-2006, 04:13 PM
Banned
My Photos: (38)
MIne has orange tabs, 2002 MY
.02
gregrob is offline
post #8 of 12 (permalink) Old 07-25-2006, 05:29 PM
My Photos: (5)
Hammer is correct, the orange is the newer one.
1999.5 cc dually
69 mustang, 472", c/4
9 sec alky injected bracket bomber....
529" in the works as we speak
Richter69 is offline
post #9 of 12 (permalink) Old 07-25-2006, 07:16 PM
Hammer
Notice the (I think) I couldnt remember which color, but you get the point. Mine was the current color, so swapping it out was useless.
Sold due to neglect
'99 F350 CC LWB DRW
ACD2 is offline
post #10 of 12 (permalink) Old 07-25-2006, 08:23 PM Thread Starter
artherd's Avatar
Really dumb question, where is the solenoid pack located and can I check it w/o dropping the pan?
artherd is offline
post #11 of 12 (permalink) Old 07-25-2006, 08:33 PM
Banned
My Photos: (38)
You have to drop the pan to see it.
gregrob is offline
post #12 of 12 (permalink) Old 01-22-2009, 04:40 PM
KMT
I have a 2002 model with a severe case of Shift Flare. You stated that the Orange SP is the newest version. Did the '02's come with the Orange SP? or not?
Thanks.
2002, F350, PSD, Lariet, Crew Cab, 4x4, 4 inch SuperLift, Bilstein Shocks, 18x10 Eagle Alloys, Nitto 325/65R/18 Terra Grapplers, TruSpeed, 3.73's, Limited Slip, Manual Hubs, Spray In Liner, A.R.E Topper, ITP Regulated Fuel Return, ITP Over Boost Annihilator, ITP HPX, Banks 4" Exhaust, Banks Big Head Actuator, Garrett GTP38R Turbo, Ford AIS, DieselSite Engine Boots and Intercooler Boots, AMP Research Power Steps, DP Tuner with Gauge Mount Switch (Stock, Lope, Drive-Thru, 40T, 60T, 80T, 80E, 120R), BTS Valve Body, Mobil 1 ATF.
KMT is offline
