GTP38R/ USA (Turbonetics) turbo comparison - Diesel Forum - TheDieselStop.com
post #1 of 21 (permalink) Old 10-16-2006, 10:52 AM Thread Starter
I see alot of things said that may or may not be true about both turbos so I had my turbo shop get a USA turbo and do the comparisons, these are nonbiased specs, no opinions in the specs they are what they are.
GTP38R -- USA (TN)
Shaft DIA @ Joaurnal .400 .470
Shaft @ Shoulder .250 .313
Turbine Exducer 67.69mm 68.58mm
Turbine Inducer 77.47mm 78.74mm
Compressor Wheel
Inducer 65.91mm 60.96mm
Compressor Exducer 88.14mm 91.31mm
There is a larger Turbine wheel availible for the GTP38 with exducer of 69.85 and Inducer of 77.47.
Turbine housings availible for GTP38 include the 1.0 wg, 1.0 nonwg and the 1.15 nonwg, onlt 1.0wg housing for the USA turbo due to the larger turbine wheel.
He also said that this unit looks to be better quality then one we checked out about a year ago.
So there ya go, there is the facts, I will give my opinions later but will leave it at that for now.
Ryan Bean
BIGBEAN is offline
post #2 of 21 (permalink) Old 10-16-2006, 11:55 AM
CSIPSD's Avatar
My Photos: (52)
Re: GTP38R/ USA (Turbonetics) turbo comparison
I am running the TN right now and like it... I will (WILL!) be Dynoing both when I get the Garret back. The only real issue I had with the Garret was the surge (and thats bad for me!) No issues with the TN unit other then the spool is somewhat slower and my EBPV brake is not working right ( I dont know if thats due to the turbo being larger in some way or if something is messed up on the valve)... I have a Dyno in town and will do both asap.
01 F-250 SC PSD,260k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Swamps Tuning and IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
CSIPSD is offline
post #3 of 21 (permalink) Old 10-16-2006, 12:23 PM
I don't think that Garrett info is correct. Looks to me like you have mixed some van stuff in with the GTP38R stuff.
444-4D is offline
post #4 of 21 (permalink) Old 10-16-2006, 01:00 PM Thread Starter
I will double check if you like but that is all directly off a gtpr, the optional larger t wheel would be a van wheel.
BIGBEAN is offline
post #5 of 21 (permalink) Old 10-16-2006, 01:23 PM
That's what I thought. I also don't think that stock GTP38R turbine inducer measurement is correct. The van wheels and housings are different and should not be interchanged. You can put the van housings on the smaller wheels but they don't fit right. The GTP38R housings won't fit on a van wheel. Is that 1.0 non-wastegated housing for a van wheel or a GTP38R wheel? And BTW even though I don't know why anyone would want one, you left out the .84 WG housing as a option for the GTP38R.
444-4D is offline
post #6 of 21 (permalink) Old 10-16-2006, 01:31 PM
The van parts are Navistar pieces,not Garrett's. I have the 2 non Garrett built by Garrett versions originally made.
David Lott
No purpose no happiness, know purpose know happiness
Worlds fastest 7.3 Power Stroke!!! 11.12@128.98 race truck 5805lbs
POWERSTROKE RACER is offline
post #7 of 21 (permalink) Old 10-16-2006, 02:13 PM
My Photos: (5)
You think they've made some changes to the GTP38R recently? I just dropped mine in my truck last month. The stock turbo was a surge king on my truck, and the GTP38R hasn't come close to surging at all yet. I did have Bob Riley port the compressor housing, so that might have something to do with it as well. Maybe a combination of better initial quality and Bob's porting makes a big difference in whether or not these turbos surge. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
There's my rambling, take it with a grain of salt. [img]/ubbthreads/images/graemlins/wink.gif[/img]
Pocket is offline
post #8 of 21 (permalink) Old 10-16-2006, 03:32 PM
Do you have to have a hangover to understand this? I've read it several times and scratched my head from several different angles and still don't get it.
444-4D is offline
post #9 of 21 (permalink) Old 10-16-2006, 03:35 PM
I thought his comment was about the other turbo.
444-4D is offline
post #10 of 21 (permalink) Old 10-16-2006, 03:38 PM
Ya gotta turn yer hat 'round backerds and stick yer tongue outta the corner of yer mouth when ya read that. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
"Early" '99, 4-98, F350 2WD CC DRW Lariat, Diablo tuner, Swamps 20* HPOP, 4" turbo back straight pipe & a 5" tip, S&B 12" open element air filter, CCV mod, EBV gutted, Vedder's built 4R100 with triple disk convertor, 6.0 trans cooler, Dfuser T/C lockup mod, DieselSite coolant filter, DieselSite TurboMaster, ITP reg fuel return, 4:10 gear w/lmtd slip,Centramatics, Western Diesel gauges, AIC, Ride Rite air bags & onboard compressor kit, Super-Vu convex mirrors, R.D.S. 91 gal. diamond plate aux fuel tank & toolbox combo, B&W gooseneck & 18K companion 5th wheel setup, Rhino lined, Drawtite 1,000lb leveler bars, Drawtite Activator II, Brown's Welding shop (New Braunfels,Tx)full grill/bumper/headlight guard, TurboNet V-Gate.
508,058 miles and still strokin'.
BioDiesel:
Feed a farmer, starve a terrorist.
N.R.A. Life Member
ProDriver18 is offline
post #11 of 21 (permalink) Old 10-16-2006, 04:22 PM
The van parts (mentioned above are Navistar parts meaning Navistar owns the tooling and Garret just makes it specifically for Navistar ) are Navistar pieces,not Garrett's. I have the 2 non Garrett( Navistar 1.15 van turbos converted to BB) ) built by Garrett versions originally made for me for testing purposes.
David Lott
post #12 of 21 (permalink) Old 10-16-2006, 04:45 PM
Well it sounds like you are saying the 1.15 housing for the GTP38R is the same as the 1.15 housing for the van turbo. Which turbine wheels do those two turbo's have?
444-4D is offline
post #13 of 21 (permalink) Old 10-16-2006, 05:10 PM
NO,they are not the same hence the above post. Garrett made their own version(smaller)because Navistar owns the mold and the rights to the original larger version.
I have the larger versions.
David Lott
post #14 of 21 (permalink) Old 10-16-2006, 05:27 PM
Can you tell any difference between the performance of the two versions?
444-4D is offline
post #15 of 21 (permalink) Old 10-16-2006, 05:43 PM
No I can't,the 1.0 actually feels like it pulls harder [img]/ubbthreads/images/graemlins/shrug.gif[/img]
David Lott
