Headlight question - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 11-19-2009, 08:37 PM   #1 (permalink)
Headlight question
I did the 05 conv on my 02. In the process I used dfuser's 9007 to 9008 pigtail in order for my 05 headlights to work. My question is if I buy an HID kit for a 2005 will I run into any problems seeing that the pigtails are there?
2002 F250 7.3l Lariat
4'' MBRP turbo back straight pipe,Tymar,Superchip Flashpaq 1855,Boost,EGT,aih delete,wicked wheel
brc51m is offline
Old 11-19-2009, 11:57 PM   #2 (permalink)
westvandude's Avatar
Don't have any experience with headlight conversions but logic would have it that if you have a 2005 headlight, and a 2005 bulb connector, and a HID kit for the 2005 it should be "bolt-on" with no issues. If you had the 2005 headlight with older bulb connector it won't work.
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, Adrian Tavano's triple disc converter, transgo tugger HD2, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler & tru-cool trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, bug deflector, tint, 08' alum diff cover, clear corners & tails, silverstar bulbs, Xtreme XT855 reverse lights, 1500w inverter, Tekonsha Primus, EQX, Epicenter, Autotek MM4000.1D, 2x Audiobahn AWT12X, 2/0 cables, JVC KD-AVX44 El Kameleon dvd deck, 12.5" flipdown video.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. Custom fiberglass hifonics 12" sub & 280w usacoustics amp. Tint is next.
westvandude is offline
Old 11-20-2009, 03:37 PM   #3 (permalink)
Feedback Score: 3 reviews
Should work except for the housings are not designed for hids.
Cary
caryt is offline
