How do i get locking differential? - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 08-30-2010, 09:25 PM Thread Starter
how do i get a locking differential in my 1999 7.3 diesel? whats the best one and where is the best place to get it? how hard is it to install, what kinda off time am i looking at in the project? I want some pulling power boys!!!
1999 F350 6 inch lift, 38's ,tw 6 pos, aem brute force intake,4" downpipe to dual 6" stacks autometer pyro,boost,tranny
LisaLogging is offline
post #2 of 9 (permalink) Old 08-30-2010, 11:27 PM
SmokeyWren's Avatar
My Photos: (45)
The most popular aftermarket positraction for our trucks the Eaton/Detroit TruTrac:
http://www.ringpinion.com/ProductDet...spx?ProdID=221
or if you want it to lock up tight, then the Eaton/Detroit Locker
Detroit Locker for Ford 10.25" & 10.5" with 35 spline axles - DET225S-56A
I wouldn't even think about doing the R&R myself, but then I'm no longer a shade-tree mechanic.
SmokeyWren is offline
post #3 of 9 (permalink) Old 08-30-2010, 11:54 PM
really, a locker is not going to add any power, since now it is driving both axles/wheels. you will need to regear to gain more power. if you have a 2wd, you only regear the rear of course, so gears, bearing kit and a detroit full locker will run you about 800-1000. getting someone to install it can run from a case of beer to 600. it is not something you can just do yourself, the tools alone will run you over a 1000 and it can be a royal pita to do and very frustrating. either buy the gears and locker through a vendor to get good stuff or whomever does the work. randy;s ring and pinion is a good site for information. hth.
Ken
2002 F350 7.3 cc lb drw, 4wd, 190k, b&w gn hitch, auto, no other mods yet
sold 1996 F250 7.3 CC SB 239k Line-X'ed bed liner, cold air intake
bitbreaker is offline
post #4 of 9 (permalink) Old 08-30-2010, 11:55 PM
wallen's Avatar
Nevr put one in a super duty but i run detroits in my jeep and if you want selectable you cant beat an ARB. I installed the detroits myself, pretty straight forward with a few tools. The hard part is laying upside down while doing it, with a lift it would be very easy though.
03 F250 Lariat 7.3 4x4 CC SB, Autometer Pyro,Boost,Trans, DP F5 80 Econ, 80 Tow, 60 Tow, Decel, 120 Race, Tymar intake, 5 in MBRP, Garrett GTP38R, Stage 1's, Terminator HPOP
wallen is offline
post #5 of 9 (permalink) Old 08-31-2010, 12:16 AM
hey wallen, do you run the jeep at street speeds? close enough might be okay at trail speeds, but i wouldn't think so at street speeds. changing the carrier is going to change everything for the bearings. i could be wrong though. an arb requires an air source and cost more too.
Ken
post #6 of 9 (permalink) Old 08-31-2010, 12:39 AM
wallen's Avatar
Thats a very good point, my jeep is a trailer queen and rarely sees any asphalt time. That may play a big role in how it functions, im not sure. The ARB does require compressor/air lines but that was included in the price when my dad purchased his. Either way it would probably be best to take it to a shop for installation unless you have a little mechanical knowledge and are not afraid to dig into the project.
wallen is offline
post #7 of 9 (permalink) Old 08-31-2010, 07:39 AM Thread Starter
I use the truck as an everyday driver and i'm entering it into a truck pull this weekend thought a locker might help sounds like i should just leave it alone. i talked to a kid who has it on a switch to lock it just for the pull then shuts it off would a locking rear help? is it better then limited slip.
post #8 of 9 (permalink) Old 08-31-2010, 01:44 PM
wallen's Avatar
Well it all depends on the traction surface. A locker will ensure both wheels are turning an is going to be much more reliable than a limited slip, i suppose that may help you in a pull. However, it adds stress to your axle, gears etc. so beware of that. If you get a locker it sounds like a selectable is the way to go for your application. I suggest ARB air locker, but also check out OX.
wallen is offline
post #9 of 9 (permalink) Old 08-31-2010, 03:54 PM
CSIPSD's Avatar
My Photos: (52)
Very happy with my truetrac...
01 F-250 SC PSD,260k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Swamps Tuning and IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
CSIPSD is offline
