How do you answer a question like this??? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 03-01-2005, 03:52 PM   #1 (permalink)
My Photos: (14)
"How much PSI can a PSD handle?" A friend asked after he saw a pic of a twin turbo setup.
Umm... I don't know?
Any input?
2000 Bombed out F-350...RIP
1996 F-350 4x4 Crew-cab,12V Cummins, NV4500
1992 F250 IDI 4x4 E4OD Hypermax kit
Friends dont let friends drive stock programs!
SPINPOSI is offline
Old 03-01-2005, 04:26 PM   #2 (permalink)
Re: How do you answer a question like this???
If you can get the head to seal, ~100psi next question, how long will it last [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Steve
2004 F250 XLT CC 7.3PSD Ghostgum silver, Sports bar, bullbar, IPF HIR driving lights, custom s/s side steps, polyair airbags, 6 position chip, Autometer C2 guages, Wicked Wheel, MBRP exhaust, K&N FIPK II, PI TC & Built Tranny, DI Reg return, Tub liner, 285/65-16 Wrangler MT/R.
15.61@85mph on a very hot day....
2002 F250 White 4X4 4.2lt t/d 5 speed
OzDog is offline
Old 03-01-2005, 05:22 PM   #3 (permalink)
My Photos: (19)
what Steve said. I am running around 30 psi of boost right now with my setup.
redrocket
*SOLD* 2001 F-250,Toreador red,ext cab,4x4,BB turbo/1.15 housing,Mini Me's,pushrods,headstuds,AirDog,ATS Stage 5 tranny,DI headers,Hypermax Tapercore,471hp/lost the tq(Dynojet)
*NEW* 2004.5 Dodge Cummins,LB,QC,4x4,Laramie
redrocket is offline
Old 03-01-2005, 05:28 PM   #4 (permalink)
A stock PSD will pop its headgaskets at around 40-45psi from what I have read on this site over the years.
There are a few guys running 35psi and have not had a problem.
The cummins inline 6 can handle into the 50-60 range before they pop their headgaskets, but thats not fair to compare as their head design is alot more robust.
Those arent exact numbers, but are pretty close.
Ford_Forgotton is offline
Old 03-01-2005, 05:35 PM   #5 (permalink)
My Photos: (14)
Thanks guys!!
SPINPOSI is offline
Old 03-01-2005, 06:39 PM   #6 (permalink)
and i ask what does psi have to do with the amount of air your moving?
if a stock turbo at 25 psi only moves 900 CFM (example I don't know the real #)
and
a HE2 at 25 psi moves 1200 cfm (ie)
why do we measure and judge every thing on psi when we really want max CFM becuase more means more power(if you have extra fuel) or am i missing some thing here.
thank you in advance for helping me sort out my confusion.
Long Island Performance Diesel & Fuel
Coram, NY 11727
631-285-1174
http://www.longislandperformancediesel.com
PRODUCT LINE: High Tech Turbo, ARP, South Bend Clutches, SunCoast Transmissions, MBRP Exhaust Systems, Silverline, Magnaflow, Bullydog, Banks, aFe Intake Systems, Airaid, ISSPRO Gauges, Autometer Gauges, BD-power Superchips, Edge Products, Dp-tuner, BDP Injectors, Quadzilla and more... Call 631-285-1174 discount pricing.
forrest11479 is offline
Old 03-01-2005, 07:36 PM   #7 (permalink)
and
[/ QUOTE ]Good point, we have measured over 1,200cfm on my truck using the TAGs on a stock turbo at 26psi. Plenty of power and torque without the high boost pressure or smoke. More air is a good thing and at the lower boost pressures you also have lower exhaust back pressures against the engine which makes it run more efficently.
2001 F-250 Crew, long box, 4x4, Big Hoss level-5 Chip, Turbo Air Guide (TAG-II), Ford AIS air intake with foam sleeve, Monster exhaust, Aeroturbine, exhaust Guide, 6.0L intercooler, Di-Pricol Optix gauges, IHC CPS, Premo Oil Refiner, Banks Exhaust brake, SmartLock, Banks Quick Turbo, Six-Gun.
2000 Excursion PSD limited, Banks Big Hoss level-5 Chip, Turbo Air Guide (TAG-II), Banks Transcommand, UNI 2-stage foam air filter, 4" aluminized exhaust with 4" down pipe and 2 Aeroturbines.
97 F-250 Powerstoke 4x4 Banks Power Pack etc.
2006 VW Jetta, PD TDI, not modified yet[/i]
carnut57 is offline
Old 03-01-2005, 07:48 PM   #8 (permalink)
ALSO THE LESS YOU COMPRESS AIR THE COOLER IT WILL BE
Coram, NY 11727
631-285-1174
Old 03-02-2005, 06:57 PM   #9 (permalink)
CarterKraft's Avatar
My Photos: (30)
easy, not many people have CFM guages.
wifes truck 02' Excursion Limited PSD 4X4 -Quadzilla Xzillaraider module, Transgo shift kit.
06' VW Jetta TDI
06' F-750 CAT C-7 and CAT CX28 automatic transmission
CarterKraft is offline
