How does a 66mm wheel outflow an 88mm wheel? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 03-23-2008, 12:38 AM   #1 (permalink)
I've been reading every d66 thread I can find trying to decide on which turbo to buy. Many people say the d66 outflows the GTP38R, TN BB and the H2E. How is that possible with a 20mm smaller wheel and compressor housing?
Early '99 PSD SRW 4X4 GTP 38R, DI intercooler, Stealth SRP1, DS regulated return, Stock injectors, Ford AIS intake, DP tuner, 203 t-stat, Gauges, coolant filter, Amsoil bypass.
ATS trans and converter, 31 row cooler, external filter, 4.10 ARB Lockers, Traction Bars, 33" Toyo MT, tons of other stuff.
2005 Harley front end, Trail Ready, Daja Design, Vision X
project20v is offline
Old 03-23-2008, 09:22 AM   #2 (permalink)
You are looking at two different things. A wheel has two sides, an inlet(inducer) side and an outlet(exducer) side.
444-4D is offline
Old 03-23-2008, 11:23 AM   #3 (permalink)
yep i always assumed the d66 had a 66 mm wheel
but the important wheel is more like 88 mm I believe.
bean can tell you for sure .
here is the thing about e99's to upgrade to either bb unit , you need to change all the
up pipes, pedistal, spyder etc...runs 600~1000 depending on the pedistal, then add the turbo.
this is why the d66 is so cost effective for the e99's it just bolts on.
so really your looking at either a 1300 turbo or a 2200+ h2e , or bb package
or buntings new mounted turbo deal., also closer to 3k.
the draw back of the d66 is maybe, it won't last as long , and it is good up to stage 2 injectors...
at least that was what I got out of the info everytime i read up on it.
early 99 f350 4x4 crew cab
work in progress
southmike is offline
Old 03-23-2008, 01:38 PM   #4 (permalink)
66mm 88mm
your talking about the same thing!! the 88mm specs the exducer and the 66mm number is the inducer of the same wheel. the d66 is the same compressor wheel as the gtp38r has and the housing is machined to fit the larger wheel. kind of expensive if you ask me when the wheel is only 100 dollars and balancing should be less than 100 and a rebuild for the parts you can do yourself is less than 100. lets see 300 dollars for a rebuilt balanced "d66" alot cheaper than the 11-1200 beans is selling!
for that price you could pull every trick in the book on YOUR OWN turbo.
cryoing the assenbly
micro polishing shaft and journel bearings (mikronite process)
micro polishing compresser wheel turbine wheel
ceramic coating the housings
extrudehone the exhaust housing.
rebuild
balance
and have the same price give or take 50-75.00.
96 obs c/c l/b suncoast billet auto DP chip afe stg 2 afe 4" isspro gauges adrenaline hpop 6"lift 37" boggers clear head/tails/3rd brake/apc clear cab lights
01 s/c l/b 4x4 6spd. DP chip afe stg.2 afe 4" centerforce dual friction
smokerstroker is offline
Old 03-23-2008, 02:33 PM   #5 (permalink)
Several years ago I was service manager in a small shop. One day a nice man called and asked how much it would cost to get his oil and filter changed. I told him the price. After a short pause he replied " I can do it cheaper than that myself". I replied "yes sir, you can".
444-4D is offline
Old 03-23-2008, 03:29 PM   #6 (permalink)
p/n
for those of you who would like to make your own. the gtp38r "powermax" wheel and housing.
GARRETT P/N 741460-0004 they should run no more than 125.00
729567-0001 cost is around 78.00/ 81.00
you can order it through just about any rebuilder and any turbo shop can install it for you. i don't want to see people time after time paying higher prices than they need to and a 400% gouging is sad!!!
Old 03-23-2008, 11:09 PM   #7 (permalink)
Thanks for clearing up the wheel sizes. I would love to build my own, but that housing will not fit my turbo. I would need it machined. Still how would the D66 with the same wheel as the GTP38R out flow the 38R? I guess I just don't know the specs for each turbo. Do you know the turbo model for the early '99? For those with BB experience, does it really spool up much faster? If the BB is so durable and the performance so much better why don't the OEM's ie. Cat, Cummins, International and on and on us BB turbos? Thanks again. At the same time has anyone built there own injectors? Like these-- eBay Motors: 40-100 HP 7.3 Ford Powerstroke injector rebuild kits (item 330221212240 end time Mar-29-08 16:51:31 PDT)
