How to get that "whistle" noise? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 05-15-2009, 06:26 PM   #1 (permalink)
Hey guys, there's 2 trucks running around here, one a 7.3, the other a 6.0. When they give em fuel, all I here is the turbo whistling and I'm wondering how to achieve that on my 7.3? I'm guessing an aftermarket turbo but I'm not sure.....
Thanks.
99 Ford F250 Superduty, Scab, Sbox, Stroke.
81 Olds Cutlass Drag Car, 388 SBC
Judas1 is offline
Old 05-15-2009, 06:32 PM   #2 (permalink)
straight pipe exhaust and an open element air filter would be a good start.
1997 F350 CC DRW E4OD POS. electric fuel, DIY6637, Beans Stage I. 200k and counting.
webshots
RD97 is offline
Old 05-15-2009, 06:37 PM   #3 (permalink)
I've got the straight pipe exhaust but still run stock intake with a wix filter. My turbo can be heard but not like these two guys. I just personally love the sound!!
Judas1 is offline
Old 05-15-2009, 07:19 PM   #4 (permalink)
You could try one of those "turbo" ricer exhaust tips
Seriously though, they probably have straight exhausts.
You could start with a muffler delete pipe on your stock exhaust
2002 F350 CC SB Lariat 7.3 4x4 3.73 LS
Torredor Red, Viper 5701
md18 is offline
Old 05-15-2009, 07:48 PM   #5 (permalink)
Apparently you didn't catch the fact that he has no muffler on his exhaust. I don't know if you need to do the air filter thing...you hear my turbo decent from inside the cab, but I've heard my truck on the outside, and there's alot more whistle than I've normally heard on straight piped 7.3's.
'02 F-250 Super Duty CCSB 4x4. 7.3L Powerstroke, Lariat Trim, Black and Tan with Tan leather, 5% tint all around, 5% eyebrow, 4" MBRP Turbo-Back, 6" tip, A-pillar Guages, (Boost, Pyro, Trans) 6-position chip from Matt at Gearheads Automotive, ITP ported housing, Alpine WMA/MP3/IPOD Headunit, JLAudio G1300 Amp, JLAudio 12 w1v2-4 12" Sub, Leveled, 305/60/18 ProComp Xtreme A/T's, on 18x9 ProComp 1089's, Firestone RideRites. Garage Kept DD/Tow Pig.
'03 Yukon Denali, 6.0 AWD, LOADED, on 20's.
'08 Pace American 24' Pursuit Car Trailer.
Al Mighty is offline
Old 05-15-2009, 10:15 PM   #6 (permalink)
Next time try to catch one and see if they still even have the stock turbo. Otherwise it could be someone running straight pipes, afe or comparable intake, did a foil delete and put in a wicked wheel (personally don't like the staggered compressor wheel = less boost) and all this one the 7.3. Don't know too much on 6.0 turbo except the variable part (my dad has a 6.0 turbo open right now so I got to see all of it).
Year: 06/01 F-250 XLT 4X4 All hands on work completed by me. 4” Icon Lift, Dual Stabilizer, Pan Rod Bar, Shocks, Leaf Spring, Purple Cranium 10.5 & Dana 60 356 alloy, T-6 Diff Covers with Lube Locker gaskets, Mag-Hytec Tran Pan, AFE Stg II w/ PG7, MBRP 4” SS Exhaust, 0589-7887 Eagle Alloy w/ 315/75 MT Baja ATZ, U-joints upgraded to Precision Super-Strength greaseable, EBC 3GD Sport Vented Rotors w/ Yellowstuff (ceramic/carbon fiber) pads all around, SS brake lines, 203* Thermo w/ Billet housing, DB HT Starter, Harpoon/Hutch Mod w/ inline Fuelab filter, RedHead Steering Gearbox, Energy Suspension Master Bushing Kit, ISSPRO EV2 Gauges, DP Tuner.
01F250CCLB4X4 is offline
Old 05-16-2009, 06:23 AM   #7 (permalink)
The less boost doesn't equal less horsepower. I don't see what the fascination is with big boost numbers, I'd rather make 500hp with only 9psi versus 450 with 27psi.
Old 05-16-2009, 07:45 AM   #8 (permalink)
mnstroker's Avatar
I did the foil delete and a ww and she whistles like crazy.
01 F350 CREW CAB LONG BOX 4X4
DIY INTAKE
AUTOMETER BOOST PYRO AND TRANS ON THE PILLAR
ZOODAD
STRAIGHT PIPED
AIH DELETE
CCV MOD
EBPV DELETE
ADRENALINE HPOP
STAGE 2'S
FUEL SYSTEM
mnstroker is offline
Old 05-16-2009, 09:57 AM   #9 (permalink)
Teknobenji's Avatar
Thanks.
You need an intake. I did an intake long before exhaust and I was able to hear way more turbo. I did a DIY Tymar type intake, one of my buddies has a K&N FIPK cold air intake, both of ours whistle like mad, my other buddy has the Ford Severe Duty intake - that is a more closed system and his is quieter than ours.
So buy an intake if you want the turbo noise.
1999.5 F250 Crew 4" Magnaflo Turbo back exhaust, DIY intake, AIH Delete, HPX Line, zoodad mod, Wicked Wheel, Gauges (Tranny, Boost, EGT) DP-Tuner ITP "In-Tank" mod and prepump filter, RiffRaff FRX Regulated return, foil delete and lighted cup holder...that's right - lighted cup holder.
Teknobenji is offline
Old 05-16-2009, 09:37 PM   #10 (permalink)
Beanhead's Avatar
Wicked wheel for your turbo and a 6637 air filter!
Beanhead is offline
Old 05-18-2009, 09:38 AM   #11 (permalink)
Since we are dealing with a stock turbo.... more boost does equal more power. Psi just tells you how much pressure there is in the pipes, not the amount of air. I never said anything about going over 25psi on a stock turbo. If you want to run lower boost you will not achieve the same power (other modifications aside for reference purposes). So, I do not like dropping below a 'normal' turbos boost number for the sake of noise.
Old 05-18-2009, 02:18 PM   #12 (permalink)
padgett114's Avatar
I have the wicked wheel and with the bts chip I can easily hit 30 to 35 lbs of boost with a stock turbo. Before you say it I know that's not good for the turbo. I didn't say I run it there, just that I can if I wanted to. I have everything that these guys are stating and the whistle is better than normal but I know the sound your talking about. It seems like the turbo is screaming even while idiling. I don't know how they do it what I wish I did.
2000 f350 powerstroke 4x4,voltant intake, wicked wheel,MBRP 4 inch exhaust, BTS 6 position chip,BTS valve body, 35" Goodyear MTR's, Autometer carbon fiber gauges,Boost Relief Valve +, air intake heater plug, Max AC Assist,
padgett114 is offline
Old 05-20-2009, 05:58 PM   #13 (permalink)
Thanks.
The biggest increase in whistle comes from a free flowing air filter. With less restriction the turbo will spool quicker.
greasemonkeyf350 is offline
Old 05-20-2009, 07:01 PM   #14 (permalink)
Dude all it takes is an eighty dollar K&N filter right off your turbo
evry1admiresmyf350 is offline
Old 05-20-2009, 07:31 PM   #15 (permalink)
Per Jody's instructions I installed the AFE part number 73-80006 and the whistle started becoming loud. I did this several days ago. Today, again as instructed by Jody at DP, I had the Walker muffler ( 21470 ) installed and man what a masive change. Almost like a totally different truck. The thing whistles big time and is much louder at acceleration. At idle I almost did not notice a difference. It is hard to keep my foot out of it now. I love this sound. Now I have 2 more things to install, Brian's valve body and Jody's F6 tunner. Oh and I got the Phantom II gauges installed last night and those things look trick at night.
cajuncutter is offline
