How to get that "whistle" noise? - Page 3 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 02-24-2010, 12:20 AM   #31 (permalink)
are the WW's balanced enough from the mfg to just slap in? and how long to install for a first timer? Seen the pros on youtube do it in about 5 minutes...
Thninking about WW over ATS for minor surge control when towing 10K in mountains
All things in Moderation accept ACCELERATION!!!!
Zip ties... the duct tape of the new milenia!
truckosaurus
2001 F250 Crew, 25,000+ miles, PSD, 4X2, ProComp 6" lift, Short Bed, SCMT, Tymar set up, BTM, ISSPRO Pyro, boost, and Trans Gauges, in tank mods and harpooned, 28" air horn w/ on board air and tank also full set of train horns! 6 gallons of 150 PSI air. Prodigy, Draw tite Signature series 18K 5'r hitch. TTM
2005 wildcat 29RLBS 5'r, parallel EU2000i's
2003 Explorer, EddieBower, V8 4X4
2003 Explorer XLT, V8 4X4
2002 XR50
2001 PW50
taxgod4u is offline
Old 02-24-2010, 01:15 AM   #32 (permalink)
Flywheel's Avatar
My Photos: (6)
The foil delete is just taking out the CAC tube and removing the foil - lots of posts on how to do this - get some acetone to clean up the adhesive and put it back in.
The turbo wheel "should" be balanced with the shaft and turbine assembly complete - but many have just done it with no ill affects.
The ATS is a great mod for 99.5 and up and will increase your turbo sound a bit as well - it is a much larger intake. It will fix surge problems.
To the OP - have you had someone drive by you with your truck? i think you will see that it probably makes some more whistle out the exhaust than you can hear in the cab. Are you looking for that or are you looking to hear it inside the cab?
If you want the noise and have a 99.5, then you will need to change out your wheel as 444 mentioned. I have seen it done in less than 10 minutes (having all the tools laid out), but I would not recommend that approach (air wrench).
99.5 F-250 CC LB 4x4 7.3 Red New Pics 1/5/10
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, Bilstien Shocks, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Timbrens, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, DS Boost Relief, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F5, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand Bumpers, Original Cup Thrower, B&W GN Hitch
Autoenginuity
Flywheel is offline
Old 02-24-2010, 02:25 AM   #33 (permalink)
jroller's Avatar
GT38R whines like crazy
2001 PSD 7.3 auto DP Tuner, 4" TBE, KNN Intake (with filter charger), CCV Mod, DB Starter, Stancore GPR, ITP Overboost, John Wood installed valve body. External coolant filter. International Up Pipes.
1994 RAM 4x4 Cummins KNN, 3GSK, AFC Spring, #10 Plate, BD Valve Body, KDP, SCHWITZER S300 turbo 4" TBE.
jroller is offline
Old 02-25-2010, 11:22 AM   #34 (permalink)
Ok, sounds like I'm going to do the "foil delete" to start. Also, who makes this "6637" air filter? Is it just the air filter element or a whole intake system?
99 Ford F250 Superduty, Scab, Sbox, Stroke.
81 Olds Cutlass Drag Car, 388 SBC
Judas1 is offline
Old 02-25-2010, 11:40 AM   #35 (permalink)
Todes's Avatar
Originally Posted by Judas1 View Post
....The other day I had to get a new air fliter so I ran to the parts store with no air filter at all and this didn't make the turbo any louder....
YOU DID WHAT!!!!! NEVER run the truck with out a filter, I would start saving for a new turbo....of course this is an assumption, what roads were you on? and distance? To me doesnt matter because all it takes is one bad piece of dirt/small rock and you'll be buying a new turbo anyway.
7.3L Stroken 4 life!!!
2002 F-250 4x4 7.3L Powerstroke 205K(7/2011)
AIS Intake system, BFG KM 2 Mud Terrains new @ 184680mi (1/28/10), Cab Clearance Lights self install 4/17/10, Foil delete and new IC boots 4/24/10
Todes is offline
Old 02-25-2010, 09:50 PM   #36 (permalink)
the 6637 is a napa air filter not sure what it is actually for but from what I understand it just hooks up to your stock intake tube (you have to take out your factory breather box or it wont fit I believe) My advice would be to buy the ais severe duty intake its a factory intake and imo you cant beat it im runnin my truck with the strait piped 3.5" and ais severe duty intake and started the foil delete process but realized that you actually have to take the cac tube off to do it so Ill have to wait til i have a day off to finish it but i have no programmer and I think my truck sounds bad A**
2002 F250 Super Duty 7.3l Powerstroke Diesel 4x4
AIS Severe Duty Intake
Strait Piped 3.5"
33" Wrangler MTR's
Firestone Air Bags
Glo Shift air pressure,fuel pressure, and boost gauges
and finally after almost a year of owning this little pearl thanks to a member on the site im finally going to have a center seat and console and believe me when you haven't had one that long thats better than gettin programmer I would know cause I traded a programmer for it lol
dieseladdikt is offline
Old 02-27-2010, 08:27 AM   #37 (permalink)
Ok, did some research on the 6637 air filter. It also crosses with a wix filter from oreillys. I'd like some suggestions on if I should get this filter, not only to help with whistle noise but also to help air flow and fuel mileage or should I get a complete cold air intake system? If so, what intake does everybody recommend? I'm ready to get this project under my belt. Thanks guys.
Judas1 is offline
Old 02-27-2010, 09:34 AM   #38 (permalink)
gdp
Find the sound you like on the internet. Copy the sound file to your computer. Plug it into your truck stereo or get a cheapo horn and you'll be whistlin' big time Heck, you can whistle when you're stopped, or even backing up, how cool would that be!
2002 F-250 CC Lariat
gdp is offline
Old 02-27-2010, 09:53 AM   #39 (permalink)
knoweigh's Avatar
As others have already stated; you'll never get the 6.0 whistle out of a 7.3;
however in regards to a filter setup:
IMHO yes, the 6637 is THE way to go.
Around $50 from Napa.
While you're there, have them slice you off a 3" section of 4" diameter exhaust tube if you don't have any scrap layin around.
Buy a large hose clamp to fit around the outlet on the 6637 and you're done.
Or toss your $300 at a "cold air intake".
But if you're like me and not made of money AND don't need that $200 sticker they send with the kit, then this setup will work just as well if not better.
I used to run one of those "$200+ sticker" setups and ditched it for the 6637 set up just to try it out......................... and it's heaps better!!!
I honestly don't know how in the heck some of those kits continue to sell for that kind of money. Good marketing on their part I guess.
What a ripoff!!!
I feel a bit taken I guess to because I pride myself on be an extremely educated consumer. I just didn't do my research;.......one of those days at the local diesel shop and got sucked in I guess.
my $.02 worth.
y2k F250 7.3 psd Calif emissions, ext cab long bed 265/75/R16 E rated tires, 190k miles 4x4 (nv271 manual t-case) 7.3 #1247981 1/18/00 (forged rods), 3.73LSD, non-diode 4R100, Dp tuner stock, 60t 60e 80t 80e, high idle. DIY 6637 air filter, wicked wheel, turbo master WG controller, turbo lifesaver, bellowed uppies, 4" downpipe & exhaust, 203t-stat, triple pod glowshift gauges (egt, tranny, boost), Ride-rite 2330 air bags, BTS VB, Sports a Western plow when the white stuff flies.
Trailers:
I'm usually towing 1 of several trailers I've built.
15ft car hauler (1000lbs empty; 5500lbs loaded)
26ft deck over car hauler (2000lbs empty; 7k loaded)
36ft car hauler (Was tongue pull; have since converted into 5er'. 4500lbs empty; 14k loaded)
https://lh5.googleusercontent.com/-g...0/IMG_4130.JPG
knoweigh is offline
Old 02-27-2010, 11:37 AM   #40 (permalink)
What a ripoff!!!
my $.02 worth.
Thank you, I don't agree on the prices on them eaither. Mine whistles pretty good now, sounds like a helicoptor taking off. I am under the assumption I have to ditch the factory air box too? No big deal. I'm going to go get the 6637 today.
Judas1 is offline
Old 02-27-2010, 03:55 PM   #41 (permalink)
6637 won't be here until tomorrow. I did the foil delete today. Pretty simple project really, took about an hour. I can here the turbo alot more when I put my foot on it.
Judas1 is offline
Old 02-27-2010, 05:47 PM   #42 (permalink)
bigred7.3's Avatar
Fake Turbo Sound Whistler BOV Stock Exhaust All CARS : eBay Motors (item 300389106482 end time Mar-21-10 20:04:58 PDT)
i think this is what you need!!!
huuge 99 f250 7.3 130k, 11" superlift 39.5 iroks, 4.88 gears, airaid, custom 6" ext, big hoss chip, boost, egt, trans guages, warn winch bumber
bigred7.3 is offline
