I came from the DARK SIDE.....Few Questions? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 05-04-2006, 10:19 AM   #1 (permalink)
Yeap I am just getting out of a 12v Cummins and got my first PowerStroke. I picked up a late 99 7.3 with 152,000 miles and so far have loved it. I will tow with it most of the time and have not had the chance to do that, but one of my questions is about the Bully Dog shift kit. Has anyone used this and are they worth the $80.00? My truck also has 3 1/2 pipe on it is that Stock? Last question, the truck came with the Edge Attitude on it, love the fact it has the Pyro, Boost and Rpm on it....how hard is the Edge on these trucks? Great Site! [img]/ubbthreads/images/graemlins/grin.gif[/img]
99.5 F350 Crew Cab Dually, 4.10 ratio. Edge Attitude. 153,500 miles
PowerStorkerAce is offline
Old 05-04-2006, 10:33 AM   #2 (permalink)
Bella PSD's Avatar
Re: I came from the DARK SIDE.....Few Questions?
Welcome!! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
The Edge J/A is not all that hard on the truck. It is adding 75 HP at the rear wheels on level 5/5.
Stock down pipe is 3".
I have a 6 speed, so I know nothing about the auto/bullydog shift kit.
Louie
02 SuperDuty CC Lariat 4x4, 7.3 PSD, 6 speed w/LUK clutch & South Bend Kevlar PB, DP Tuner, 1.15 A/R Van Turbo W/ATS housing, Non-EBV Turbo Pedestal, CCV mod, 4" custom mid side exit straight pipe, Tymar intake, IH T 444E BADGES, 06 Grill, WARN bumpers, AIC, 06 TT mirrors, 37" BFG BAJA on HMMWV double bead lock wheels, Bushwacker cut out flares, Superlift 4" LIFT, Triple A-pillar Gauges, A.R.E. DCU Cap with barn doors and 4'x5'x6" Con Ferr Roof Rack, Rhino Lined, CB, Wet Okole's neoprene seat covers, 2 12" subs
FOKISD Charter Member
My truck
TDS Photos
Bella PSD is offline
Old 05-04-2006, 10:48 AM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Stock begins with a 3" downpipe that expands to 3.5" where it connects to the exhaust pipe, and it's 3.5" the rest of the way. Most performance exhaust systems start with a 3.5" or 4" downpipe.
It depends on the driver. [img]/ubbthreads/images/graemlins/shocked.gif[/img]
Drive by the gauges. If you never allow more than 1,250º EGT or 25 PSI turbo boost (manifold pressure), then you won't hurt the engine.
As I understand it, the Attitude is just gauges. The Juice is what makes it go. If you have the Edge Attitude with Juice, then you need to drive by the gauges. If you don't have the Juice, then you'll probably never see 1,250 EGT or 25 PSI boost. http://www.edgeproducts.com/ford_73_powerstroke.html
SmokeyWren is offline
Old 05-04-2006, 11:44 AM   #4 (permalink)
Bella PSD's Avatar
You are right about never seeing 1,250 EGT or 25 PSI boost with just the Attitude because the Attitude needs the Juice to do anything. The Attitude will not work without the Juice. I am going by his post and he has the Attitude gauges so he has the Juice with Attitude. He should have a limit set to de fuel at 1300 EGT +-. There is no need to drive by gauges because of the safty built into the j/A to de fuel at a set limit.
Louie
My truck
TDS Photos
Old 05-04-2006, 12:56 PM   #5 (permalink)
Banned
My Photos: (38)
If you really want your truck to shift like a dream, I would suggest a fully tuned Valve Body from GB Evans or BTS.
Find them here.
http://www.dieselsite.com/index.asp?...amp;ProdID=251
http://brianstruckshop.com
gregrob is offline
Old 05-04-2006, 04:47 PM   #6 (permalink)
[quoteIf you really want your truck to shift like a dream, I would suggest a fully tuned Valve Body from GB Evans or BTS.
Find them here.
Thanks for the Welcome all....I will check out the link
[quote
Louie
Yes it has the Attitude and I have the De fuel (alarm) set at 1250 right now, when that sucker is on 5 and 5 wow look out. AM hoping this truck will run as good as my Dodge did [img]/ubbthreads/images/graemlins/confused.gif[/img] I guess I will have to wait and see. One hell of a nice rig. Again Thanks for all the info, I troll alot and just wanted to get some feedback.
Old 05-04-2006, 04:50 PM   #7 (permalink)
Hey!! Welcome to the real truck side!!!!
2000SC,4WD,4R100,3LotsaSlip73,265's, Leer XL160 for now
fxdwg is offline
Old 05-05-2006, 07:08 PM   #8 (permalink)
Jurry is still out on that one, Standard Cab was to small.
