I have a purple torque converter... what is it? - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 40 (permalink) Old 09-01-2007, 09:30 PM
Re: I have a purple torque converter... what is it?
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: westvandude</div><div class="ubbcode-body">
K&N ... fram ....
:-) </div></div>
two wrongs don't make a right
99.5 F350 Scab, 4x4, Lariat, short bed, 4" MBRP w/ 'bling' and I was going for a no-bling-thing, Hutched/Harpooned tank, Kwik/6637 intake, CCV mod, 203*, Evans, coolant filter, Fumoto Valve, International up-pipes, 52K miles and counting.
tworocks is offline
post #17 of 40 (permalink) Old 09-01-2007, 10:52 PM Thread Starter
westvandude's Avatar
Ya... I know, they're both crap.... but gotta make due till more funds arrive. :-)
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, NAPC 450series trans w/billet triple disc TC, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler, 6.0L trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, tint, 08' alum diff cover, clear corners & tails, 20w LED taillight bulbs, cheap OPT7 HID kit, 2000w inverter, Tekonsha Primus brake controller, 220A HD alternator, 120w LED light bar up front, 2x18w led spots backup lights, 145USgal tidy tank, superlift 4" kit full springs & bilstein 5125 shocks, Level8 striker 16x8.5 blk rims, etc.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. REVO tuned. Aftermarket android 4.2 navi 7" touch head unit, Custom fiberglass box MD Sound 12" & Boss NXD5500 amp. GTI grille and projector fogs.
BioPro190 owner. 20,000L produced 2010-2015.
westvandude is offline
post #18 of 40 (permalink) Old 09-01-2007, 10:58 PM
Fever's Avatar
My Photos: (9)
don't bother putting the K&N back in...if you need to save up some coin at least see if you can gather up ~$50 for a homeade 6637 filter setup...
2002 F-250 Super Duty Super Cab Short Box 4x4
7.3L PSD, 4R100 Automatic, 3.73 LSD Gears,
, Tymar Intake, Muffler Delete,
285/75-16 Yokohama GeoLander A/T II Tires,
Tekonsha Prodigy Brake Controller
2006
269BH Travel Trailer
Fever is offline
post #19 of 40 (permalink) Old 09-01-2007, 11:11 PM
I second that FEVER..
Throw away the K&N, they are crap and too harmful for diesel engines.
Ironhide is offline
post #20 of 40 (permalink) Old 09-01-2007, 11:13 PM
Or this is a good option for a complete replacement..
http://catalog.powerstrokeshop.com/partl...&catalogid=3670
Ironhide is offline
post #21 of 40 (permalink) Old 09-02-2007, 12:21 AM Thread Starter
The AIS kit sure is nice..... keep saving. Hopefully it'll still be on sale in a couple of months.
post #22 of 40 (permalink) Old 09-02-2007, 01:03 AM
Sounds like you might have a BTS tranny, what kind of records does Brian have, can he tell you if he did the tranny from VIN?
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
post #23 of 40 (permalink) Old 09-02-2007, 06:37 AM
My Photos: (5)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: arisley</div><div class="ubbcode-body">Sounds like you might have a BTS tranny, what kind of records does Brian have, can he tell you if he did the tranny from VIN? </div></div>
Doubt it, he doesn't have my VIN. Maybe a serial number off the trans.
BTW that purple paint changes color when you overheat the trans. So there's a reason for that paint.
Pocket is offline
post #24 of 40 (permalink) Old 09-02-2007, 07:11 AM
NCHornet's Avatar
I don't believe the 01's have a drain plug on the TC, I believe 2000 was the last year for it. Don't know if I would have bought a truck with a K&N in it, you may have gotten a great tranny and a dusted engine. Not to scare you though, check your turbo fan and see if it has any chipped or rounded edges, hopefully the PO was a city slicker in LA, and not driving much out in the desert!!
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
NCHornet is offline
post #25 of 40 (permalink) Old 09-02-2007, 08:01 AM
rms0726ea's Avatar
I've got the same torque converter (purple PI) - there's no drain plug. Enjoy the new toy!
, 2003 7.3L F250 Lariat, Swamps 175/146 single shots, MBRP exhaust, AIS w/fender sleeve & Zoodad, ISSPRO A-pillar 3 gauge kit(pyro/boost/tran temp), DiPricol HPOP & Fuel, oilguard bypass filter, CCV mod, extreme duty tranny (by Jon Faubion-Richter69), BTS (PI) Torque Converter, AIH delete, 6.0 trans cooler, van turbo w/wicked wheel, Gutted EBPV,
, HX mod, Bilstein Shocks, Firestone Ride-Rite air bags w/compressor,
, Schaeffer's 15W-40, ITP in tank mod/pre-pump filter, Harpoon mod
rms0726ea is offline
post #26 of 40 (permalink) Old 09-02-2007, 08:35 AM
Even some early '02s had a drain in the T/C. Mute point though since he has a rebuilt '01. If it were mine I sure would like to know who's rebuild I had in there. I don't know how you would find out without contacting the "repo-ed owner" and I doubt he would be happy to talk to you about it.
Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
MOUNTAINMAN444 is offline
post #27 of 40 (permalink) Old 09-02-2007, 09:26 AM
JimTJr's Avatar
My Photos: (20)
Maybe you can see if Brian writes the date on his transmissions, I will look at mine to see if I can see any writing on it when I get back under it to put the UP-Pipes back on. If you got a BTS, heck, you got 4,000+ more for the truck. Brian may be able to tell from the date, what he did. Also Being in CA, it most likely was a "Shipped" one if it is a BTS. So he wouldn't recognize the truck, (Yes, I think he does remember alot of them,,,)Even though he works on so many now,,,,
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #28 of 40 (permalink) Old 09-02-2007, 09:50 AM
Kevin,
Just for a frame of reference my 01 (built in 00) transmission replaced with 41k miles in 02/03 can't remember but later than 01 has a drain plug on my TQ.
FYI ..
Two ideas when combined together will always make a third better idea!
I don't have to be wrong for you to be right.
Kent
@235K miles @ 071127
&gt;202K miles @ 070828
2001 F350 7.3 PSD SD CC DRW Lariat, 4R100 (replaced at 41k w/rebuilt by dealer), 3.73, FX4 ESOF, Long Box - 3rd CPS. CPS in Glove Box MOD. K&N Filter. 6.0 OTA Cooler. Green to Red Coolant. Water filter. 203 T-stat. Fumoto Valve. Monroe Gasmatic Shocks.
techkdb is offline
post #29 of 40 (permalink) Old 09-02-2007, 11:11 AM Thread Starter
The writing is on the passenger side of the tranny where the bell housing starts. Black fine marker.... I better take another look. LOL
Ya, I'd be interested to know who did the rebuild and what parts are in it. Feels like maybe a valve body but who knows on the rest.
I haven't looked to see if it's the OE cooler or a larger one yet.
Maybe Brian from BTS keeps serial numbers from the trannies? Have to look.
Yes, I think it was mostly babied it's whole life. The receiver hitch has very little wear, barely any rust from safety chains on it either. My buddy thought it may have pulled a trailer on occasion but nothing heavy or frequent use. Not a scratch on the exterior and interior is in very good shape too. Like you said, looks like an LA truck.
post #30 of 40 (permalink) Old 09-02-2007, 12:36 PM
ELLIOT02's Avatar
If your turbo fins are clean and smooth it sounds like you got yourself a decent rig. BTW my '02 had a drain plug on the TC but it was replaced around 70k miles by Ford,and I don't know about the original TC's status.
'02 Black F-350srw Lariat. 7.3/CC/SB/OR. BTS tranny with 6.0 cooler,coated TN bb1.00 w/Hi-flow outlet,Non-EBP ped,BWD coated/bellowed up-pipes,D.P Tuner.F5(stock,Hi-idle,60tow,80econo,120race),4" SS Magnaflow,BDS stabilizers ,Fluidampr,AFE Stage2w/PG7&pre-filter,Spearco 6.0 IC,PML pan,HPOX,Airdog,ITP reg.return,MAP Maximizer,8 spring front, BFG 315/75/16 AT's,DTS 4.56LS gears,Mag-Hytec cover,Dieselsite SS ESOF lines,coolant filter,203* stat w/billet&Fleetrite,Optix fuel on column,Ultra-Lite trans,pyro,boost on pillar.All fluids Mobil1,Energy polys,Centramatic,Fumoto,Billet,Line-X,Husky box,Extang,EGR,Alpine,Viper,Dynamat,Sirius,PIAA,Hu sky-Liner,Bilsteins. Door ding,overhead console,Snowman,Zoodad,Harpoon,AIH,Marinco,CCV,foi l mods. Hawks and Powerslot cryo's
ELLIOT02 is offline
