Idle Fluctuation - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 05-31-2006, 10:40 PM Thread Starter
Idle Fluctuation
Sometimes at idle I am experiencing a 50-75rpm fluctuation. Doesn't do it a lot, but when I stop the truck and put it in park and let it idle for 10sec. and then it will fluctuate for 5sec. then smooth out. Running higher fuel pressure seems to help, and it will just randomly do it. Any ideas or is it nothing to worry about. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2011 6.7L-CCSB- 325/60/20 BFG A/T's- 20x10 BMF's Satin finish
Icon 4.5" Lift
2008 6.4L-CCSB- On 35's with 20x10's BMF
All bolts on's- 12.9 at 102mph
2010 6.4L-RCLB-Race Truck
Dirty Diesel, Elite Diesel, Spearco, Suncoast, Powerstroker67, Industrial Injection, PMF
Track times to come..
Klutch is offline
post #2 of 6 (permalink) Old 06-01-2006, 09:51 PM Thread Starter
Re: Idle Fluctuation
Anyone?
Icon 4.5" Lift
Klutch is offline
post #3 of 6 (permalink) Old 06-02-2006, 01:24 PM
Kanman's Avatar
When is the last time you changed your fuel filter? Also, I would look for boost and or vacuum leaks.
Kanman is offline
post #4 of 6 (permalink) Old 06-02-2006, 02:16 PM
My Photos: (19)
check your fuel filter and make sure the drian plug is closed
Thanks, Gabe
1999 Red F-250 PSD 4x4......AKA Your Daddy!!!!
99 F-250 PSD 4x4, CC
4" Straight piped
3 gauge pillar... Boost Pyro Tranny
DI-GTP38R BB Turbo
DI-Mini Me injector's
DI Performance 6 Pos chip
DI Performance Fass 150/180 Fuel System
AIM-Raggingbull03
lildevil02 is offline
post #5 of 6 (permalink) Old 06-02-2006, 04:30 PM
ponyboychris's Avatar
Mine stumbled slightly when I first bought it like you are describing. I had a loose IC clamp on the cold air side. Cranked it down and it went away.
2002 F350 XLT, 7.3L, 4x4, LB, SRW, Crew Cab, 3.73's, BTS Trans "BTS BUBBA" , 6.0 tranny cooler, DP Tuner
NS, stock, 60HP tow, 80HP econo, Autometer Ultralites on pillar & cubby, Ford AIS w/Zoodad, '08 Aluminum Diff. Cover, 4" MBRP Exhaust, Heated Tow Mirrors, Warn Premium hubs, AIH Delete, Go's Headlight Harness, IC Foil Delete, Homemade CCV mod. The Silver Bullitt
2006 33' Courgar 5'er W/4 wheelers in tow
2003
Explorer XLT - Mom's Taxi
1990 Honda - the 27 MPG daily beater
1967
Mustang FB on blocks - my other toy
ponyboychris is offline
post #6 of 6 (permalink) Old 06-03-2006, 08:02 AM Thread Starter
Thanks for the info. I've talked with Jody and he thinks it's programming. Says it's some times is hard to nail down the idle trying to hunt for where it should be with hybrid/singles unless you do live programming. But I will check the things you've mentioned,thanks again.
Icon 4.5" Lift
Klutch is offline
