Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
I'm getting ready to swap out my stock injectors with a set of stage 1' single shots from Full Force. At the same time I'll be dropping my tank to hutch mod it... which has me considering other upgrades as well.
Thinking about a regulated return fuel bowl delete...
If you could only do one thing to compliment those new stage 1 single shots what would it be?
2000 F-250 Lariat PSD 4X4 Auto CC SB 326,000 miles, 4" Super-Lift/Fierce Attitude M/T LT31575R16's
Tymar intake, 4" turbo back MBRP exhaust, AIH delete, AC mod, ISSPRO gauges, 5 position DP tuner, FFD Single Shot Stage 1's, FrX, Hutch/Harpoon Mods, Monsterbox Tranny, Tru-Cool Max
yea, stock turbo... for now. that'll be my next project, probably a WW, bellowed up pipes, and new intercooler boots.
After studying several of the regulated return systems, I just ordered the Riffraff FRx kit and a rebuild kit for the stock FPR. Didn't see no need in paying the extra $$ for an after market regulator if there ain't nothing wrong with the stock one. Thanks for that eye opener, RT.
Shameless plug, I still have my ATS housing for sale in the 'for sale' section.
__________________ '02 F-350 "Babe The Big Blue Truck" 4x4, Ext. Cab, 8' bed, SRW
DP-Tuner 80T, Stage I single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
If you are giong to want to run Hi Power tunes with these new injectors, you probably wont see thier full potential without an upgraded HIPOP.
Early 99 F350 7.3 250k
SRW single cab 4x4 Auto Trans
4" turbo back w/ 5" muffler
Isspro trans pyro, boost, and HPOP Gauges
Stage 1 single shots from Full Force
Riffraff FRX & HPX
Terminator 500 HPOP
EBPValve delete W/ Blank Pedistal
Kickers all around w/ 10" sub
4" Cold air intake
35" MTs with 1.5" wheel spacers
DP f5 Tuner w/ F8 switch
On board air w/ Air horn
AST Ultra remote start
WMO !!!!
Riffraff FRX & HPX
Terminator 500 HPOP
4" Cold air intake
WMO !!!!
if yours is weak why not? upgrade it, if its not then you dont need it (so ive been told (or read) here, quite a bit... BUT, machiner1 did you put yours in AFTER your 1's? you still on stock turbo?
2000 7.3 Extended Cab Long Bed Lariat...
nothing crazy, it carries alot of weight, it tows alot.. has all the 'usual' upgrades plus some..
I my memory is working correctly, you will not gain anything from a T500 or other pumps unless you are currently having issues. My 250/100's will run just fine off a stock pump. These single shots are less demanding that the stock splits.
I am running a stealth srp 1.1 and if there was any improvement, I did not notice anything. Way too many people claim you will see a huge improvement...thats a crock of crap.
I have done some of my own minor non-scientific testing on various items people claim to make a difference....you will be wasting money on many of them.
get your injectors, plug the chip back in When you get it back from Jody and enjoy your truck. Do not go making a bunch of changes all at the same time. Baby steps is the way to go so you can see how ea upgrade/mod truly reacts.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)
I did swap my pump out at the same time my injectors were being rebuilt into stage 1s. I have also heard that going form split shots to the single shots will reduce the requirements of Hi pressure oil, but I was advised by multiple people that If I wanted to run the 120 or 140 tunes, I would want to upgrade the pump. Mine already had 240k on it, so I didnt put much thought into it.
Riffraff FRX & HPX
Terminator 500 HPOP
4" Cold air intake
WMO !!!!
Machiner1 I have question. My 02 only has 121,000 miles on it and it runs perfect. I am ready to do a bunch of up grades at the same time. Would I be better off having my injectors rebuilt into stage 1s or just buy them and turn mine in for cores. It just seems a waste to send in perfectly good injectors for cores. Was it cheaper to have yours rebuilt?
Much cheaper to have them rebuilt. I purchased my Stage 1 rebuilds thru DP-tuner because they don't charge for the new tunes if you buy thru them, but I still shipped my injectors directly to Full Force Diesel. You can deal with Full Force directly, and I think you get a free t-shirt, but I don't think it was any less expensive. The cool thing about sending you injectors in beforehand is that Full Force will rebuild YOUR injectors and turn them into Stage 1s. You get YOUR injectors back and the turnaround was about a week for me. Full Force rebuilds these injectors every day, and they did an awesome job. Service was great and my injectors came back to me packaged up like they were brand new.
A few important things to remember:
1) Your upgraded injectors will require different programming to run properly. If you don't have a tuner, you will need one. Make sure that you tuner company understands what you are planning to upgrade on you truck, and find out if they are capable of supplying tunes to meet you needs.
2) Not all rebuilt injectors are the same. Pensacola Diesel sells Rebuilt injectors dirt cheap. STAY AWAY!! They don't replace half the stuff that a company like Full Force does.
3) Don't just order everything online because the website looks good and is easy to use. Call the company and feel out their service department and expertise before you spend you money with them.
Riffraff FRX & HPX
Terminator 500 HPOP
4" Cold air intake
WMO !!!!
Machiner1 why did you take out your EBPV. I am thinking about going to the 38R ball bearing turbo and I just wonder if it is worth it to eliminate the EBPV valve and pedistal. Is it worth it in performance gains to loose the temp gain up here in the northern midwest. When we get below 0 up here it takes along time to build water temp without the EBPV. Some of the guys up here said don't do it.
