Injector upgrade... what else? - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 02-16-2013, 10:20 AM   #16 (permalink)
RIStroker2000's Avatar
Send a message via AIM to RIStroker2000
[QUOTE=BS Hauler;2283321]Machiner1 why did you take out your EBPV. I am thinking about going to the 38R ball bearing turbo and I just wonder if it is worth it to eliminate the EBPV valve and pedistal. Is it worth it in performance gains to loose the temp gain up here in the northern midwest. When we get below 0 up here it takes along time to build water temp without the EBPV. Some of the guys up here said don't do it.[/QUOTE
i havent had a problem with it, sometimes just a longer warm up time abd baby pedal until the motor warms up.. I like not have the EBPV for small personall differences that might not really 'show', but i can tell
2000 7.3 Extended Cab Long Bed Lariat...
nothing crazy, it carries alot of weight, it tows alot.. has all the 'usual' upgrades plus some..
she breaths well, has extra air and fuel
RIStroker2000 is offline   Reply With Quote
Old 02-17-2013, 08:23 AM   #17 (permalink)
GTman's Avatar
Is it worth getting new injectors over remanufactured ones?
2002 7.3L F-250 Crew Cab with 230k miles, 6" mitre cut Grand Rock turbo back stacks, 3-pillar ISSPRO EV2 Gauges (pyro, tranny, boost), AIH delete, 05-07 headlights, much more coming soon
GTman is offline   Reply With Quote
Old 02-17-2013, 06:25 PM   #18 (permalink)
Machiner1's Avatar
I dont know if I would take it out if you are in real cold weather, Mine was leaking a little, and 40 is really cold here, so it wasnt a big deal. I think the only difference was a bit faster spool up, but I kinda miss the sound of the EBPV kicking in. If you listen to some of the guys on here, they tell you to drop it in drive just as soon as the bendix retracts.
If you do that you wont notice the EBPV anyway.
BTW your PCM will pop a low level code it you remove the EBPV. No check engine light, just a trouble code stored in the memory.
Early 99 F350 7.3 250k
SRW single cab 4x4 Auto Trans
4" turbo back w/ 5" muffler
Isspro trans pyro, boost, and HPOP Gauges
Stage 1 single shots from Full Force
Riffraff FRX & HPX
Terminator 500 HPOP
EBPValve delete W/ Blank Pedistal
Kickers all around w/ 10" sub
4" Cold air intake
35" MTs with 1.5" wheel spacers
DP f5 Tuner w/ F8 switch
On board air w/ Air horn
AST Ultra remote start
WMO !!!!
Machiner1 is offline   Reply With Quote
Old 02-17-2013, 06:46 PM   #19 (permalink)
Machiner1's Avatar
Im my opinion, no. If you get them rebuilt properly, they are new injectors. If I understand it correctly, its like putting new tires on your existing rims, vs buying a whole new set of the exact same rims with new tires on them. You get the feeling of new, but I think thats about it. Im no authority on the matter though. Maybe talk to the guys at Full Force. They can tell you exactly what they do to rebuild them. https://shop.fullforcediesel.com/contactus.sc
Riffraff FRX & HPX
Terminator 500 HPOP
4" Cold air intake
WMO !!!!
Old 02-17-2013, 07:46 PM   #20 (permalink)
Fullforce uses all new parts when they rebuild injectors. However other places do not, they will only replace certain parts. I would not hesitate to get remans from fullforce. Other places, I would be sceptical. Some people will only buy new. Everyone has their own opinion, but im fine with reman injectors
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)
PHP/Beans tuned/250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system with RR & FB delete, Pius LASB from Irate, Swamps HVHF IDM.
Autometer Nexus Guages, 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line. Baldwin PA2818(6637) RR Boots/CBillet Plenums, ('06) 26 row Tranny & PS Cooler, LarryB's Genuine Denso Starter
INFRNL is offline   Reply With Quote
Old 02-18-2013, 04:28 PM   #21 (permalink)
Feedback Score: 3 reviews
All 7.3L injectors from FF have new tungsten-coated plungers and barrels, they do not charge extra for worn parts in your cores. All are ballanced to 1%
All reman and new 7.3L injectors come with an 18-month warranty
Thats why we sell Cass's..
We also have everything else thats needed, PM-email if I can get you more info-prices.
Cary
Cary
caryt is offline   Reply With Quote
