Intercooler/Nitrous questions - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 04-01-2008, 12:18 PM   #1 (permalink)
I was reading through the install instructions and Zex recomends to install the fitting 1-2ft away from the motors intake manifold and to position the hole towards the motor. Does anyone know which intercooler tube I should drill? Also, they recommend to mount the bottle length wise with the truck but there's not enough room except in the bed to install this way. I'm a little paranoid that it will get stolen. So I'm left with two options in the cab sidways or in the toolbox sideways. I want to mount it sideways in the cab on the transmission hump will this give me any trouble with its location?
99.5 f-250 supercab long bed psd ZF5 swap 4x4 viper blue leveling kit ts 6 position chip banks bighead diy intake 6" stacks zex nitrous
Sinful Rides is offline
Old 04-01-2008, 02:00 PM   #2 (permalink)
thuglike's Avatar
I have mine mounted on the passanger side frame rail. As far as the hole goes if you have a single stage, drill the ic pipe after the cooler.(passanger side pipe) Point the jet hole in the same direction as the air flow.(toward the turbo)
'00 F-250 X-cab 4x4: Powered by DI PERFORMANCE
Best run to Date: Spring Fling-706/1400- ALL FUEL/ 12.21 @ 110.45 Diesel Nationals (all fuel)
thuglike is online now
