intercooler upgrade - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 09-28-2009, 10:43 PM   #1 (permalink)
intercooler upgrade
I have a 7.3 and want to upgrade the intercooler. Is a Banks 6.0 a better upgrade than a 6.0 Ford intercooler? I found a Banks(new) at a good price?
Your replies have always helped me. Keep up the good work.Thanks
2000 Ford,Lariet,F350,P/S,auto,3.93l/s.diff,longbed,4in.exhaust(turbo back),dash mount gauges(boost,tranny temp,exhaust temp(pre-turbo),Amsoil 15w/40 syn.oil with dual-bypass filter,in-line trannyfilter,coolant filter, 6.0.tranny cooler,20k Reese 5er hitch,mods( ccv,203deg.thermo,pre-tank,in-tank,aih,un-do Ford cackle-fix(replace LL8,reprogram pcm) ,wicked-wheel, EPBV gut,reg.fuel return,pressure set 62psi.,hpx kit,dptuner 5position.chip,modified air intake w/Donaldson B085011 air cleaner,tranny rebuilt (JohnWood ).
ronchyhiker is offline
Old 09-29-2009, 06:28 PM   #2 (permalink)
Banks is very overpriced unless it's used. Spearco and DI have performance intercoolers that will outpreform the Banks but if the price is right...
2001 F250 Lariat, -SOLD-
460/950 Corrected Prior To Water Injection and Spearco IC.
13.974 @ 95.65mph
2008 Cummins Truck Fest 4WD Diesel Champion
'07 Duramax Classic, Leather, Sunroof, Bone Stock.
DZacc is offline
Old 09-29-2009, 07:17 PM   #3 (permalink)
ckanderson's Avatar
At what point is an upgraded intercooler needed?
Also, how much of a power increase are we talking?
Thanks!
2002 F-250 7.3 4x4
1964 Nova 400 w/350
ckanderson is offline
Old 09-29-2009, 09:08 PM   #4 (permalink)
m4jockey's Avatar
Yeah, I'm thinking about a new intercooler as well to drop my EGTs while towing. Is there a best intercooler?
02 F-350 LB Dually 4x4 gauges, DP Tuner, Turbonetics turbo, AFE 1 Proguard, 4' TB exhaust. Ugly ZoodDad,
m4jockey is offline
Old 09-30-2009, 12:49 PM   #5 (permalink)
Intercooler might be warranted if you want to drop egt's but power increase will be negligible. For the same money you would do better upgrading the chip, exhaust, intake...The 6.0 intercooler can be purchased very cheap if you want to go that route. If you go ahead with the upgrade, get the 6.0 intercooler. It bolts right in.
13.974 @ 95.65mph
DZacc is offline
