John Wood Valve Body or Sonnax Kit...Which One? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 11-13-2009, 08:33 PM   #1 (permalink)
indystroker's Avatar
If a person doesn't pull very often. If any at all, would the Sonnax kit work ok to keep the tranny going, or is the John Wood valve body that good? If I pull anything, it would be a 6'x10' trailer at the most. Price wise, im leaning towards the Sonnax kit. Any insight would be appreciated.
Indystroker
01 F-250 4x4, XLT, Crew Cab,
AFE Stage II Intake
TS Chip w/ PHP Tunes 40HT,80DD,120R,140 Xtreme
Auto Meter Gauges
ITP Fuel Tank/Pre-Pump Kit
Riffraff FRx Crossover
Gutted Turbo
Riffraff SS X-over
DIY CCV
4" Turbo Back w/Donaldson M085171
Warn Hubs
Sonnax Kit
indystroker is offline
Old 11-13-2009, 09:21 PM   #2 (permalink)
tattoocharlie's Avatar
My Photos: (5)
i bought the sonnax parts myself,valves,springs,line press mod valve,about an hour of work and a nice firm shift.if you use the sonnax get the .427 line press mod valve and only use one shim on the valves.GOOD LUCK
2002 f250 lariat 7.3 200k(motor has 170k)
original 4r100 tranny....200k and counting
knock on wood......
tony wildman chip......
stock,economy,daily,towing,extreme,smoke.
red elc good for 150k
4r100 1-2 2-3 3-4sonnax accumulator valves,.427 sonnax line pressure mod valve
4.125"yes thats 4 1/8" diy tymar intake(size matters...lol)
AIH delete,ccv delete,zoodad mod,
4" exhaust no muff
built my own leafs for 4.0 of lift!!!!!!
18" xd bronze revolvers with 325 nittos to wrap them
isspro pyro and boost guages on pillar mount....
tattoocharlie is offline
Old 11-13-2009, 09:31 PM   #3 (permalink)
I have a FTVB and love the way it shifts, very quick and firm, but not too firm.
02 SWB CC 4x4 auto, AIS, DPTunerF5, FTVB, 4" Banks Monster SS Exhaust, HPOXover, AirDog, Amsoil ByPass, Centramatics
blackout is offline
Old 11-13-2009, 09:56 PM   #4 (permalink)
What do you mean by this? I'm unfamiliar with it.
Indystroker
AFE Stage II Intake
Auto Meter Gauges
Gutted Turbo
Riffraff SS X-over
DIY CCV
Warn Hubs
Sonnax Kit
Old 11-13-2009, 10:37 PM   #5 (permalink)
MonteC's Avatar
Sonnax. Thats what i use.
MonteC is offline
Old 11-14-2009, 06:41 PM   #6 (permalink)
MonteC's Avatar
In the accumulator body sonnax uses different accumulator valves and you can fine tune each shift for desired shift firmness with little round shims. Dont use over 3 shims, i dont even recommend using 3 shims, ive done it before. Gave me whip lash!
And the line modulator valve is in the accumulator body as well. I cant remember what the stock ratio is, but upgrading to the .427 is a good step, even if you have a .427 stock, the sonnax one is steel. Ive seen the oem valves wear out BAD, because the oem is a steel valve with an aluminum sleeve.
MonteC is offline
Old 11-14-2009, 07:25 PM   #7 (permalink)
I've looked at the kits from Diesel Innovation and other places, but haven't seen anything about shims or .427 modulator valve. Its just listed as Sonnax Valve - Tricumulator Springs Kit. Where are the shims and the .427 valve obtained?
Indystroker
AFE Stage II Intake
Auto Meter Gauges
Gutted Turbo
Riffraff SS X-over
DIY CCV
Warn Hubs
Sonnax Kit
Old 11-15-2009, 12:12 PM   #8 (permalink)
fxdwgi's Avatar
I put a JWVB in when I replaced the transmission. I have no experience with the sonnax kit and can only comment on the valve body, but I love it. Shifts are quick, firm and seems to work well with my converter and F5.
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Draw Tite Fold Over Gooseneck * Reese 15K Sliding 5er * Gauges Whited Out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM * ITP Pre-pump * One Very Understanding Wife*
I AM AN AMERICAN, SO I DRIVE AMERICAN.
fxdwgi is offline
Old 11-18-2009, 12:13 AM   #9 (permalink)
My Photos: (5)
i got everything for mine at a local tranny supply shop
knock on wood......
4" exhaust no muff
Old 11-18-2009, 01:55 PM   #10 (permalink)
We do some light, but tough towing, seems like always in the mountains. John put my valve body together with a combination of Sonnax parts and parts from a Trans-go tugger kit. I have no idea which parts were Sonnax, other than some springs and a hydraulic piston/valve. I just know it works very well.
Late 99 Dp tuner E80,T60,T40. JW trans. Rancho 9000xl, Helwig Sway bar, 2004 Rad w/AT cooler, 08 diff cover
MikeJ60 is offline
Old 11-18-2009, 02:58 PM   #11 (permalink)
My Photos: (5)
sonnax
ok,youll need the tricumulator spring kit,1-2 shift valve,2-3 shift valve,3-4 shift valve(shims come with valves)and the line press mod valve .427,i was told by a ford tranny guy that the .427 is what to use,there is a .500 but that seems to be too much.also the toque on the valve body is 100 inch pounds,i did say inch.
knock on wood......
4" exhaust no muff
Old 11-18-2009, 07:02 PM   #12 (permalink)
MonteC's Avatar
I like to use the .500 in tow trucks or for crazy people who love extra firm shifts and plan to beat on the truck hard.
99 (5/98) F350, PSD, CC, LWB, DRW, 6SPD, 2WD, 4.11 TRUE TRAC, RED, S&B, MBRP 4", ISSPRO EV2 EGT/BOOST, DP TUNER F5.
MonteC is offline
Old 11-18-2009, 08:09 PM   #13 (permalink)
Powerstrokin400's Avatar
My Photos: (18)
I'm a big John Wood advocate. I'm makin' big power, towin' big stuff, and I've broken 2 trannys in the past. I Mean BROKEN (Snapped the input shaft clean, like butter), grenaded some other stuff too. After John Wood built a trans for my specific purpose, NO PROBLEMS. And, I've got bigger tires and makin' more boost than before. Rock Solid Products. Give him a call. He'll give ya the right info. He's a former Ford Engineer. (760)356-9421 or jwtt.com. Check it out........
P.S. The trans shifts nice. Not too hard, just right!!!
2003 F250 XLT 7.3L, Auto, FX4, Crew Cab, Long Bed, 6.5" Pro-Comp all spring lift & Firestone HD Rear Air Bags, BFG KM2 37x12.50x17 tires on Eagle 17x10 Rims, 4" Turbo Back Exhaust & muffler delete, Bully Dog Programmer @ 120 Hp setting ALWAYS, Machined & Bellowed International Up-Pipe Kit, Autometer Overhead Gauges (Boost, Pyrometer, Trans. Temp), Custom Pre-Filter Ram-Air with K&N filter, "John Wood" Custom Stage I Transmission, 6.0 Billet 3 Disk T/C, External T/C Lock-up switch, 6.0 Trans Cooler, Hughes Racing Deep Structural Pan, and a few more goodies. Now spinnin' AAM Rear & Dana Spicer Front 4.30:1 Gears with Warn Premium Locking Hubs.......I do a lot of towing.(13,000 lb 33' Toyhauler & 21' Ski Boat). 84,568 miles as of 11/09
So. Cal. Fireman
IAFF Local 2342
Other Rides:
2006 BMW 330i Sport
1992 Camaro RS 5.0L, 25th Anniversary
1990 Mustang LX 5.0 Sport, 5spd., 25th Anniversary
Powerstrokin400 is offline
