Locking Hubs 99 F350 Dual Rear Wheels - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 02-07-2008, 04:44 PM   #1 (permalink)
I have a 99 F350, My four wheel drive stopped working, one of My Hubs has two broken splines in the hub assembly. I have Warn locking hubs that state Free and Locked. I went to order new ones and found that Warn does not support any of their hubs in Ford trucks with dual rear wheels, and niether does Super Winch. I contacted Warn and said that you can use thier hubs at your own risk, but must do some milling to the front wheel spacer and sent them photos of mine, and they basically said I should just use the Ford OEM locks, which where quoted as $298.00 each. Anyone have any suggestions?
Ryan
RyeGuy is offline
Old 02-07-2008, 04:53 PM   #2 (permalink)
Raul@Stealth Automotive's Avatar
My Photos: (6)
Ryan
hey bud... i havnt found anyone making hubs for the DRW applications... the hubs i have sold people had them machined to fit.... not sure how much it would cost you to get them machined to fit but if its under 100 bucks you can prob get the warn prem hubs and have them done for the same price of the OEM ones
-Raul
Raul@Stealth Automotive is offline
Old 03-01-2010, 09:18 AM   #3 (permalink)
I have been told it cost about 40 dollars. But I have a DRW 99 as well and installed the warn premium in mine this weekend. Tested them already in the mud and work great. The trick is you have to remove the wheel spacer. It is hour glass shaped so that you cant just slid them in but if you remove the spacer, install them and then put the spacer back on over them it WILL fit. It turned a 15 min job into a 45 min job but it is super easy
mr.dunne is offline
