map sensor location - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 12-31-2006, 08:30 PM Thread Starter
map sensor location
install gauges (auto meter ) where do i hook boost hose to was told map sensor if so where is it located also where to install tranny temp gauge for auto trans tjis is all for 02 ford f250
thanks for info you guys are great
brethart is offline
post #2 of 6 (permalink) Old 12-31-2006, 08:34 PM
Re: map sensor location
passengerside firewall..hose runs between MAP sensor and intake horn.
Proud to be a sponsor of thedieselstop.com
Test Fleet
2001 F350 Crew Cab 7.3L
2004 F250 Crew Cab 6.0L
2004.5 Dodge Ram Cummins
2006 Jeep Liberty CRD
2007 ML320CDI
Soon To Be 2007 Dodge Ram 2500 6.7L
"Can your Resistor do this?"
spdiesel is offline
post #3 of 6 (permalink) Old 12-31-2006, 10:29 PM Thread Starter
is installation about the same as faq says under gauge install for 94 -97 even though mine is an 02 is trans sending unit to install trans temp in sam location as picture in faq sorry dont know how to make it a link to put it in post
thanks
brethart is offline
post #4 of 6 (permalink) Old 12-31-2006, 10:33 PM
Lay down underneath the truck and look at the driver side of the tranny pan. You should see a small bolt that is the same size as the tranny temp sender...it goes there.
Mark
2002 Quad Cab/ Short bed/ BTS Auto/ Ford AIS Intake/ BTS 6 Pos. chip/ DI boost relief valve/ 4in DP no muff all the way back/ Bob's IC boots/ Bob's A/C bypass valve/ Bob's coolant/tranny filter/ 3 Yellow Tops Optimas under the hood/ HID's/ Switched GP's/ And a Really big wish list!
pilot4life is offline
post #5 of 6 (permalink) Old 01-01-2007, 12:07 PM Thread Starter
anywhere i can see a picture of boost hose where your supposed to teed in to i think i found it but not for sure thanks
brethart is offline
post #6 of 6 (permalink) Old 01-01-2007, 01:19 PM
See is this Picture works for you.
03 F250 SD PSD Lariat 7.3, FX4 Crew Cab Short Box, 3.73 Gears, Auto Tranny, Jody Tipton 80 HP Econo Tune, Turbo Back 4" Exhaust W/5" Tip, Home Made Tymar, Isspro Gauges, T/C Lock Up Switch, 203 Degree Thermostat, Coolant Filter, Upgraded Headlight Wiring Harness, Diode Mod for Dims, Bilstein Shocks, Kenwood Head Unit, Sirius Radio, Valentine 1
Down South is offline
