Mine is lying on the inner fender. Has been for about 50k. No issues what-so-ever. You sure that's the issue? Or are you talking about a different sensor? We don't have MAP(MAF) sensors on these trucks.
'66 Bronco "Big Little Monster" - 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
