Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 7.3L Engine
Upgrades and Aftermarket - 7.3L Engine Upgrading and adding aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 05-11-2008, 03:02 PM   #1 (permalink)
MBRP Exhaust Rubbing Tranny Mount
I have the 4" Turboback and I can not get it to stop rubbing on the front tranny support bolt. The bolt has cut into the pipe and i HATE the clunking sound it makes when taking off from a stop. Any ideas?
Early 99 F350 - CrewCab - 7.3L PSD
  • 10" Lift
  • 38" Toyo MT's 38/14.5/16
  • AFE Stage 2 Intake
  • Banks TransCommand
  • Edge Evolution 2
  • MBRP 4" TurboBack
ViperJ is offline
Old 05-11-2008, 05:44 PM   #2 (permalink)
I never had that problem with mine but since I put my TN turbo on and had moved the downpipe for the turbo in stall I now have the same clunking as you describe. My temporary fix for a year and a half has been a piece of an intercooler boot shoved in between the pipe and the bolt and no more clunk. As far as heat from the pipe and the boot I have seen no problem. Some people have beaten a notch in the pipe for clearance but I don't think I want to beat the heck out of my expensive exhaust. Maybe just loosen the whole pipe up and tweak the pipe a bit for more clearance.
Good luck and tell us if you find another way to fix the problem.
"Real Trucks Don't Have Spark Plugs"
2000 F250 Lariat Crew Cab, Island Blue/ Harvest Gold , 7.3 PSD, LWB, 4x4 ESOF, Auto Trans. 3.73LS, 285/75/16,AT/BFG, Husky Liner Floor Mats, AIS/Foam Fender Sleeve Mod. Line-X, Leer 100XL Cap, MOOG Balljoints, Performance Friction Rotors and Z Rated Carbon Metallic Pads, Fumoto Valve, DIPricol Optix Gauges, Pyro,Trans,Boost, A-pillar Pod, MBRP 4 inch T-304 SS Cool Duals, EBPV delete 6.0L Trans. Cooler,Schaffer's Transmission Fluid, BTS Transmission, DP Tunes, Stock/High Idle/40T/60T/80E/120R/140SMK 309.77 hp/605.12tq
Spooling and Cooling by BWD with a Turbonetics Turbo & Spearco Big 6.0 IC
"The Smoke Don't Mean Its Broke!"
Bushwakd is offline
Old 05-17-2008, 02:40 AM   #3 (permalink)
I had the same problem with my '00. I took a 4" muffler clamp, welded a 1" wide strap to it and spaced the pipe where i wanted it and bolted it to the frame rail. I have not had an issue since.
ditty is offline
Old 05-18-2008, 03:35 PM   #4 (permalink)
My Photos: (6)
I am having the same with my MBRP exhaust rubbing! I loosened all the connections and tried to adjust it so it wouldn't rub. Stopped for a week and it started back up, gotta say I know many people are impressed by this brand but I am not impressed with how its rubbing and yes I know how install an exhaust, its not install error. I may have to weld up an additional bracket or something to hold it in place more.
2001 F350 Dually, Crew Cab, 6x6, Lariat, 7.3 PSD
Auto, 4.10's, Camper Package
4.5" DR Edge Lift (soon to go on) Dual front shocks, 33" BFG AT's, 2" rear dually spacers, factory fresh trans
4" SS MBRP Cool Duals, Banks 1.0 Exhaust Housing, Banks Big Head, AIS Intake w/ Fender Cutout
DiPricol Optix Boost, Pyro, Full Sweep Trans Temp
My F350 DRW Pics
TalontedTSi is offline
Old 05-18-2008, 04:01 PM   #5 (permalink)
Not to say that any of you are wrong but I have fixed three of these so far and its not that big of deal. Just loosen the clamp on the turbo, and the first one or two clamps back... adjust it then tighten from the turbo back. I will make life 100X easier with two people! My girlfriend helped me when I fixed mine so just grab anyone, and have them turn a wrench when you say now. You get the fun job of laying on the ground pushin the exhaust with your foot while they tighten the down pipe.
Play around with it guys you'll get em!!
03 F250 SC SB, 7.3, Lariat, MBRP Duals w/ muf delete, Foil Delete, CCV Mod, DIY Intake, Edge Juice w/ Attitude... posturing to get TWildmans!:thumb:, Alpine Touchcreen DVD.
TheDurtyDeez is offline
Old 05-18-2008, 11:16 PM   #6 (permalink)
Supporting Member
detroitfd's Avatar
I have the Magnaflow, and it does the same thing. It's adjusted to not do it now, but it rattled a bit for a day or so until we found it. Like the others said, 2-3 clamps starting at turbo and just move it until it's where you want.
I don't think it's a design flaw, there's just simply no friggin room down there. Try to turn a wrench without bashin your hand. And remember that in most caes, the exhaust is now bigger than OEM, not much, but bigger .
Jerry
My PSD X
2000 Excursion 7.3L PSD 4X4
DP-Tuner F5 : no start, stock, 40T, 80T, 80E - AutoMeter A pillar w/ 3 Phantom gauges - DIY Tymar intake w/ serviceable S&B filter - Zoodad mod - B&M HD Trans rebuild w/ TransGo Shift kit & Amsoil Fluid- BD Triple Disc Billet Torque Converter - Exhaust : 4" Turbo Back (w/ 4" down pipe) Stainless Steel Magnaflow - ATS housing and 4" intake sleeve - Turbo Master Wastegate Controller - Dieselsite HX Oil Crossover - Morse Ceramic brake pads - Monroe Reflex Shocks - Energy Suspension Bushings - IC foil wrap delete - Fumoto Oil Valve - 08' Aluminum Rear Differential Cover - White Night reverse light system - Garmin StreetPilot c340 GPS - 6.o tranny cooler - Dieselsite Coolant Filter - Amsoil Single Bypass Oil Filter w/ Rotella 5W40 synthetic oil - APC white gauge face - Dual in-dash DVD w/ Infinity Reference speakers & Blaupunkt 200A powered sub
TOWING:
2004 Dutchmen 31BH travel trailer
detroitfd is offline
