Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
I'm in the process of gathering parts to upgrade my early '99 turbo to the later design. Does anyone know if I can reuse the early '99 down pipe? A quick check at the PowerstrokeShop.com only shows one flavor of the down pipe, and that got me thinking that maybe I could reuse the one I've already got.
2011 F450 King Ranch, Royal Metallic Red, BW Turnover Hitch, Torklift Camper Tie Downs
Early 99 XLT F350 4X4 SuperCab Long Bed SRW
Mods: AIS Intake, BTS tranny, DP Tunner, Isspro A Pillar Trans Temp, Boost, Pre Turbo EGT, 19.5" Vision Heavy Hauler Wheels, Michelin XDS2 Tires, GTP38R Turbo, Non EBPV Turbo Pedestal, DI Intercooler, DI Uppies, DI HP Oil Cross-over, DI Regulated Fuel Return, BW Turnover Hitch, Rear Hellwig Stabilizer Bar, Rear Timbren Suspension, Moog Ball Joints, 2009 Al Rear Diff Cover, Banks 4" Monster Exhaust with Power Elbow, Torklift Camper Tie Downs, Tekonsha P3 Brake Controller
I've got a 99.5 engine sitting here if you need any parts, also have the dp too. Its been cut to get it loose from the rest of the exhaust but its defiantly usable.
I compared the early and late side by side. The late is positioned nearly 2 inches higher. The early pipe should still connect. the trans. dipstick is also higher on the late to clear the higher downpipe, It will likely need to be tweeked as well. Just my opinion, but I do not think stock for stock the late turbo can be considered an upgrade. I've driven both and the early feels more powerful and responsive in stock form.
Early '99 PSD SRW 4X4 GTP 38R, DI intercooler, Stealth SRP1, DS regulated return, Stock injectors, Ford AIS intake, DP tuner, 203 t-stat, Gauges, coolant filter, Amsoil bypass.
ATS trans and converter, 31 row cooler, external filter, 4.10 ARB Lockers, Traction Bars, 33" Toyo MT, tons of other stuff.
2005 Harley front end, Trail Ready, Daja Design, Vision X
as far as after maket exhuasts go..there is no diff in the 99's that i have ever seen..
unless you go to an h2e turbo but that comes with its own dp.. total different for any truck.
early 99 f350 4x4 crew cab
work in progress
I am looking at buying a f 250 7.3 diesel 1999 Ford. I am new to trucks.
I am told that the oil pressure drops to nothing when the rpms fall below 2000 is this a huge problem? and how can it be fixed... when the rpms stay above 2000 everything is normal. What does this mean. And what do I need to fix it? a new oil pump? sensor? any advice would help. and is it difficult to change an oil pump? in this model?
Your better off beginning a new thread, but if this truck has that symptom, it could just be the LPOP, (Low pressure oil pump) Not hard to replace really from what I hear. (Never had to do one yet, thank you) It could also be a bearing wear issue though I imagine.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics!'03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
means have it checked out by a mechanic ...as in inspected ie I am looking to buy this truck not replaced...
sure it may cost a bit ..not much , and if the owner doesn't want you to..he is hiding something.
you need to make sure the engine isn't dusted or anything radical..
bad ball joints , even hubs are common bad trannies , blown head gaskets, turbos, trannies etc are uncommon and a problem.
lpops are not bad..dont go bad often either.
but you do have to pull the damper to get to them I believe .
or should I say those who put on fluid dampers often change to the melling lpop just for heck of it.
the melling isn't leeps and bounds better but has a better design.
work in progress
