MODS FOR MORE LOW END TORQUE? - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 06-19-2005, 10:56 AM Thread Starter
Hi,I have a 99 F-350 PSD,manual,4X4 with 156,000 mi.I'm probably going to sell itbut if I don't I might be interested in doing some mods to get more low end torque(not that it needs it).I use the truck to plow snow and tow a 3,000 lbs trailer.I had a Western Diesel chip air intake and exhaust but it was unreliable,the engine would just stop for a second from time to time.i took evry thing out and returned it to stock.The truck has to be 100% reliable.Also what mods would give the most return for the money?Thanks,1 basic guy.
99 F-350 4X4 PSD Manual,B.F.Goodrich Commercial T/A Traction LT235/85R/16E
1 basic truck is offline
post #2 of 12 (permalink) Old 06-19-2005, 12:02 PM
Re: MODS FOR MORE LOW END TORQUE?
An adjustable stage 1 10k mod by SP diesle. I have mine for sale.PM me if interested.
2001 white F250 sc xlt psd," DI regulator kit, DI BIG fuel system, DI Mine-Me injectors, DI ATS BB Turbo, DP Chip,DI Valve Pressure Release,DI-adjustable IDM mod ",Terminator 2 HPOP R-IPR, APR studs, 910 valve springs, BTS Trans&Converter,6.0 Intercooler, AFE Stage 2 with zoodad,Power Elbow, Bully Dog full 4" exhaust with 5" tip,Fluidampr, hx mod,203t-stat, CCV mod, Fumoto Oil Valve,Cool-Max Trans Cooler, Autometer Phantom Gauges,Bilstein shocks, Rancho5406 stablizer, Edge 4" lift kit, Rear RoadMasters active suspension, EGR Slotted & Crossed Drilled Rotors with Carbon/Kelvar brake pads, Welds Cheyenne 8s, Roll & Lock bed cover, Sylvania SilverStar 9007& 9005s, Chrome Billet Grill, 2003 Clear Headlights, APC Clear corners, APC Euro rear lens, APC gas & brake peddles, Acetone Badges, Chrome Door & Tail Gate Handles, Oakley Seat Covers, Viper alarm, Cyclops Fuel Cut-off alarm.
joediesle is offline
post #3 of 12 (permalink) Old 06-19-2005, 03:47 PM
If you want 100 percent reliability then you need a PCM reflash from Jody Tipton at DP Tuner. Its the best money you can spend for the results. I just got mine reflashed last week and boy what a difference a little tuning can make.
FOMOGO
2001 F-250 Lariat, Black, CC, SB, 2WD
304 hp and 627 tq on Dunbars Dyno
2001 F-250 XL standard cab, beater, hauling trash... Stock except for a 60 horse flash...
304hp and 617 tq on Dunbars Dyno
2001 F-250 Xl Standard cab, project truck...
Custom Tunes by DP-Tuner, Custom Fuel System by ITP Diesel, Custom Trans by BTS
Ford Makes It - International Shakes It
Dubco1 is offline
post #4 of 12 (permalink) Old 06-20-2005, 12:58 PM
A Turbo Air Guide (TAG) should help with low end perfomace and turbo spool up. You might also consider the Banks Six-Gun or Big Hoss chip for more power.
2001 F-250 Crew, long box, 4x4, Big Hoss level-5 Chip, Turbo Air Guide (TAG-II), Ford AIS air intake with foam sleeve, Monster exhaust, Aeroturbine, exhaust Guide, 6.0L intercooler, Di-Pricol Optix gauges, IHC CPS, Premo Oil Refiner, Banks Exhaust brake, SmartLock, Banks Quick Turbo, Six-Gun.
2000 Excursion PSD limited, Banks Big Hoss level-5 Chip, Turbo Air Guide (TAG-II), Banks Transcommand, UNI 2-stage foam air filter, 4" aluminized exhaust with 4" down pipe and 2 Aeroturbines.
97 F-250 Powerstoke 4x4 Banks Power Pack etc.
2006 VW Jetta, PD TDI, not modified yet[/i]
carnut57 is offline
post #5 of 12 (permalink) Old 06-21-2005, 05:56 PM
Have you done any dyno runs with the TAG?
2000 PSD Crew Cab Dually 4x4w with leather
4" Turbo Back Exhaust
AFE Stage 1
29' Sand Piper Toy Hauler w/front sleeper 11.5klbs Loaded.
JoeCar is offline
post #6 of 12 (permalink) Old 06-21-2005, 07:12 PM
Before purchasing any Banks products be sure and read the other threads on here concerning their products!
01 X Ltd Modified with all the usuals, X-code/350 blocks and springs
03 X Ult Ltd-wifes-unmolested,X-codes/350 blocks
05 38' Keystone Hornet Retreat
jjtproperty is offline
post #7 of 12 (permalink) Old 06-22-2005, 11:08 AM
superchips tuner gives a bunch more low end power. unreal.
air intake and exhaust doesn't do much for low end tho.
99.5 Superduty Crew 4x4 6 speed Smokewagon
Pizza cutter tires, Tymar, BTM, DP
If it don't run, chrome it.
drmiller100 is offline
post #8 of 12 (permalink) Old 06-22-2005, 11:12 AM
imelmo's Avatar
Here ya go
Everything you would need.
2002 F-250 Lariat 4x4 crew-cab short-bed automatic, lots of stuff from DI Performance (Diesel Innovations)713/984-9441, Terminator hpop, ATS trans, and some good help from Chris Pitre at Pitre Automotive of Lafayette, LA 337/945-8049 (and a few other great sponsors) pm me for any details; Best time on 37's = 13.09 @ 102mph, #2 only;12.18 @ 111.71mph on Da Juice
Current Project: '86 Toyota regular cab, full tube chassis, fully built 7.3 Diesel Innovations Powerstroke engine and Terminator hpos
imelmo is offline
post #9 of 12 (permalink) Old 06-22-2005, 05:42 PM
GSXRTURBOQUAD's Avatar
Get a good Hot chip with no timing advance(DI, DP, TS, etc..), Exhaust, Good air intake system, and of course Big Oil(the largest low end gain you will see, with the proper programming). [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
95 F350 Crewcab4X4: TE Twin Turbo(BB fed by a Precision Hybrid from BWD), Industrial Injection BD Injectors, DIIC with custom stainless 3" piping, Terminator HPOS, DI headstuds, BTS tranny, TruCool 40GVW cooler, DP LIVE TUNED F5 with Extreme ICP(ya, it works)!, Custom fuel system, MagHytec diff cover.
01 F350 Regcab4X4: soon to be shortened.
97 F350 Regcab4X4: Twin Turbo's, lots of fuel and oil.
02 Excursion4X4Limited: Wifes ride: Terminator HPOS2, DP Tuner F5
SDRCM #7
GSXRTURBOQUAD is offline
post #10 of 12 (permalink) Old 06-23-2005, 02:47 AM
What you had was some of the best baseline mods you could ask for. If the contacts on the chip where not clean it could cause the truck to stop as could a loose chip. This would be a bigger problem with the jaring from snow plowing. A AIS intake and tag may help as would a 31/2 down pipe. Do you have gauges? If you reprogram the PCM (Jody) you don't have to worry about chip contact problems.
DENNY
1999 F350 CC SRW LB 4X4 SIX SPEED.
DENNY is offline
post #11 of 12 (permalink) Old 06-23-2005, 08:40 PM Thread Starter
Thanks guys.
DENNY,sir,i got rid of the Weatern Diesel stuff befor I started plowing.
Who makes a good exhaust?
Are any of the mods going to adversley affect the longevity of the engine?I have a manual trans.I've had two problems,hyd.line went and the slave cyl.broke,is there any thing that can be done to beef up the trans?Thanks,1 basic truck.
post #12 of 12 (permalink) Old 06-24-2005, 12:45 AM
The trans is pretty strong. The weak point is the stock clutch/pilot bearing/lever arm. I would upgrade with a luk clutch and kevlar pilot bearing. Make sure you have gauges to keep track of your EGTs, Any increase in HP can shorten motor life depending on how hard you push it but, there are lots of modded trucks living a long life.
DENNY
DENNY is offline
