need help! best chip/tuner???? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 07-03-2009, 08:21 PM   #1 (permalink)
lukyroll777's Avatar
I'm havin problems with the torque converter because of my bully dog chip I have installed in my truck.I'm now looking to get rid of this chip and install something new. Its a 2000 f-250 superduty, any suggestions for a tuner or chip for the truck? custom vs. regular?? I'd appreciate any info, thanks
lukyroll777 is offline
Old 07-03-2009, 10:11 PM   #2 (permalink)
DP Tuner is a good choice. I run one with 6 positions.
Sold 02 F350 Lariat CrewCab Toreador Red/ Silver DRW LB AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 859,532 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 F350 XLT SC DI DRW 5Speed 314,000
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
Sold 62 Corvair 95 Bus
92 Buick deuce and a quarter
03 Ford Windstar- Granny Hauler
HighwayPrisoner is offline
Old 07-04-2009, 12:39 AM   #3 (permalink)
i've looked into that website before. How exactly do you go about picking the settings? how much did yours cost? is it worth the price?
Old 07-04-2009, 01:00 AM   #4 (permalink)
woodnthings8's Avatar
First you choose which tuner you want, either the f5 @ $199 or the f6 @ $299. The difference is the f6 you can download new tunes and install them yourself. The f5 requires you to send the chip to them to have more added. As far as which tune to get, that is a personel preference to what you use the truck for. I got this as my setup. No-start, Stock, Decel, 60 HP Tow-codes, and 80 HP Econo-codes. Most everyone gets the 80 hp econo as there daily driver tune. Lots get the 120 race or 140 extreme but I think the 80 hp econo provides. Plenty of safe power that will keep you from breaking a stock powertrain. I tow about 9k so the 60hp code should be all I need but I think I might also get a 40 hp tow code for pulling in the mountains to keep temps down. The codes run about $45-50 for the average ones. If you send Jody your current mods he can put the tunes that have been on other trucks with similar mods. You can also do one of his live tune sessions if he comes to your area and you will get custom tunes for your truck as he drives around with you tweaking it to match your exact mods.
Ken
Powerstroke Acronyms
TSB Information
woodnthings8 is offline
Old 07-04-2009, 06:20 AM   #5 (permalink)
well the 60 tow and the 80 econo sounds good but i love smokin people around town. I have a K&N cold air intake and an aeroturbine exhaust, do you think the 140 hp tune is safe to run?
Old 07-04-2009, 01:09 PM   #6 (permalink)
I don't think Jody would sell it to you if it is not safe. But you will find that the stock HPOP and injectors will be taken to the limit with it. I know lots of guys runn it and love the power it gives. I've been in trucks with it and have seen other diesels try to keep up, but they just can't seem to do it. I think if you use the 140 to play occasionally you will be fine, just remember the trans is the weak link iin our rigs, You may be looking at getting a BTS in the future. Welcome to PMS!!!!!!!!!
Ken
TSB Information
Old 07-04-2009, 03:38 PM   #7 (permalink)
ok, how would i go about getting a new tranny? are there certain specs to ask for or is it more of just a straight upgrade?
Old 07-04-2009, 07:43 PM   #8 (permalink)
With BTS or John Wood you just tell them what you do and they will build it so fit what you need. Both are pretty close to the same price and offer a great transmission. Which one you use is up to you. Most use BTS as he is in Arkansas and JW is in California. Both will have a wait list so if it is something you want to do I would suggest you get the ball rolling now to get the proverbial "golden ticket". I know here in Washington state there is a shop that installs BTS transmissions so where you live might have a similar deal. Either way give them a call and tell them your intentions and they will hook you up with a trans that more than likely last your lifetime. Plan on spending around 5k on the deal by the time you get the trans, a new cooler and synthetic fluids.
Ken
TSB Information
Old 07-06-2009, 10:42 AM   #9 (permalink)
Browning01's Avatar
DP tuner son, I had a superchip before and my new DP blows it away! I will also warn you on the tanny, 4000 miles after I got my tuner, the tranny was done.
2001 F250 7.3L White 4X4, Lariat Crew Cab, 7 1/2" Superlift, Mickey Thompson Classic lock Wheels wrapped in Dick Cepek 325/80/16 tires, 05-07 Grille and Headlights, wood dash kit, Pioneer Flip out DVD player, Cobra CB mounted under the 4x4 switch, DP-TUNER WITH STOCK, NO START, 80 ECON and 140 AGRESSIVE, DIY Intake with napa 6637 filter, IC Foil delete, new aftermarket tranny with sonnix shift kit and triple disc billet Torque converter, 4" Magnaflow Turbo back exhaust, Plantdrive wvo kit with 75 gallon external L shaped heated tank in the bed, Racor filter inline before the stock one, 146,000 miles
Browning01 is offline
Old 07-06-2009, 12:55 PM   #10 (permalink)
jlau6888's Avatar
How would a Dp Tuner affect a ZF 6 speed? Is the clutch the only thing i need to upgrade or do i need to work on the internals too?
jlau6888 is offline
Old 07-06-2009, 04:22 PM   #11 (permalink)
klhansen's Avatar
My Photos: (169)
The ZF6 is a HOSS tranny. It'll handle just about whatever you throw at it. The pilot bearing needs attention, because if it goes out, it will take the tranny with it, starting at the input shaft bearing.
Clutch is another story though. The stock clutch will go out quicker if you start drag racing, etc. If you're careful to get it fully engaged before romping on the go-pedal, it'll last a bit longer.
There are good aftermarket clutches available. SouthBend sells some good ones, but be aware that there's no such thing as an all-around clutch. Some are good for pulling heavy loads and others are good for daily driving. Call them up and ask what they'd recommend based on your driving style.
Hard or no-start? Check Here
klhansen is offline
Old 07-06-2009, 10:35 PM   #12 (permalink)
Well I use a Dp tuner i have 80 econ, 120 race and 140 agg race. I love it my dad had a superchip and he would struggle to hang with me on my econ tune when he was on extreme. He ordered one the next week. And not to mention the 80 econ is awesome. You would have a hard time getting me to try another chip. And For your tranny... it will last as long as you drive smart. The harder you are on it the faster it will go. I drive mine like I stole it but its a weekend warrior slash rice eater.
blacksmoke03 is offline
Old 07-06-2009, 10:43 PM   #13 (permalink)
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
Dang, looks like I have to get a DP tuner myself, I wonder if it really makes that much of a difference, what are these guys doing that the other famous and big tuners are not?? anyone?
Putting their knowledge to good use instead of advertisings??!! they don't need it, happy customers do it for them............gotta get me one soon!!! anybody got a F5 for sale???
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
V10 Tranny cooler + Trucool max cooler
Wicked Wheel-loud little sucker!
DieselStop Boost fooler
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using Superchips 80hp Performance tune.
Wastegate disconnected
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
4'' Ported Housing non-ATS
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Cam,DVD,Nav.,Satelite Music.IPod
Jason smooth topper.
Big air compressor/tank
2 air horns w/ big valves
Quick connect Air hose for any air tool/tires
All work done at DieselTriple.Com-Miami,FL
Here but not installed:ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline
Old 07-06-2009, 10:48 PM   #14 (permalink)
My Photos: (23)
are you sure??!!
Des your transmission change normal and the tq converter locks up much later while on stock mode, w/o a tuner? it the answer is no, then is not the tuner, like I told you on the other thread you started, I used 3 diff tuners and they all make it shift the same...
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
Old 07-06-2009, 10:49 PM   #15 (permalink)
My Photos: (23)
BTW, you guys w/ DP tuner, does your 4R100 shift like ours?? goes to O/D soon and tq converter locks soon while you are trying to "go" only to find out that the tranny does not agree with your style of driving...........hate it w/ a passion.
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
