Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
My headlights got screwed up in a sand storm and now need to be replaced.
I have heard you can use the newer style headlights(sorry I don't remember from what year) Are these a direct replacement for the the 02 style or are modifications required? how hard is this to do? and approx how exspensive?
Sorry for all thje questions, but if I don't ask I won't learn.
Thx for any help
DD
Your 02 are the clear crystals. So I assume you mean the 05 and up with the turn signal/headlight combined. It is not a direct swap. Many have done it. It involves cutting the header panel out or replacing it with the 05 and up one. Also changing the headlight harness plugs. Both of which are not difficult I am sure. (the header is only something like 100.00 I think. And plugs are available in a kit from Gosracing, click here -->Splash (SPLASH? But the link works....)along with the heavier wire harness for higher wattage bulbs if you wish.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics!'03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
Unless they changed in 02 from 01, my 01 doesn't have crystal clear headlights.
Check ebay and then check vendors for them. Lots of options. I thought they changed to clear in 03 or 04? But those are direct swap before 05 as mentioned.
Clear in 03-04..get ebay or Ford ones ..don't get later ones they have cheap bulb connectors that limit higher wattage bulbs to be used. Get a set of Hella 80-100w 4k Kelvin bulbs and their harness, fantastic light!
Cary
Cary
Cary, do you have a source for these? I have bought cheap stuff from ebay (you get what you pay for), and wouldn't want to cheap out on headlights. The bulbs sound interesting - need a relay and larger guage wire?
New truck: 2002 PSD 4x4, CC, XLT, F350 dually. Air bags, 6.0 trans cooler, Fleetrite ELC, ISSPRO guages, DB HT starter (no more), Superchips 1705 tuner, Reese Titan, AIS, IPT pre-pump filter kit, in-tank mods, and much more to come.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, IPT pre-pump filter kit.
I believe 02 and up for the crystals, 99,00 and 01 were the "Fluted" lenses...
You can do the 05-07 headlights, a little trimming is all that is needed. Dfuser.com is where I got my kit from. It comes with the pigtail to change bulbs, headlamps and the necessary hardware for mounting.
2001 F350 CC LB 4x4. GDS Ballbuster turbo, AFE Stage II intake, Banks Intercooler, Suncoast TC, MBRP stainless 4", DI 4 position chip(needs reburn), Autometer gauges, zoodad mod, HX oil line, blow-off valve, DR 4.5" lift, 35" bfg mud terrains.(R.I.P)
332hp and 785tq - 4/1/2006 at Performance Diesel (w/o Banks ic and AFE stage II intake)
2007 Dodge 2500 CC SB 4x4 5.9L picked up (5/01/07)
5" stainless magnaflow, cfm+, quad boost fooler, smarty SR, Silver 62, DTT Billet 48re, AD 165, Spearco CAC, KORE race suspension, 35" terra graps on 18" XD HOSS.
Jim is correct, they changed the headlights to the clear crystal in 02, and you are correct about the 05 and up style, I am going to check out the website that tx silverstroke mentioned to see what the got.
Thx for the info guys.
The 05-07s are nice. I have heard some say the lighting is not quite as good as the clear crystals. (However I want them for looks!) I have seen how much they have to cut out to put them in, also then not all points of support are there for them. For the 100.00 or so it costs to get the new header panel. It may be worth it for piece of mind? (Granted I have never seen one installed with the header cut out, to see if there is any vibration ect.... from the lights) It may be just fine......
Looks aside the 05 and up housings are not what anyone that wants "light' should install. The housing uses The H13 and is quite possibly the stupidest design for a bulb ever foisted on the public. The terminals are so small that they overheat, even at stock wattages, and melt the plastic housing of the connectors. Higher than stock wattage bulbs are offered, but not recommended.
Cary
Never mind the crappy bulb design....they are UGLY.
Well, if you mean the 08's are ugly, yes, I personally love the 05-07s,
