new torqe converter ,now flashing O/D light and no first gear - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 08-10-2009, 08:59 AM   #1 (permalink)
dtsthx's Avatar
so finally got new converter in and now OD light flashes and the automatic gear shift not working with no first gear
i did bypass all trans lines hooked up to radiator and ran new hose from new 6.0 cooler to two trans lines by powersteering pump
any one have ideas where to look for problems
2001 F-350 larait c.c. s.b. 4x4 auto, keenwoodkvt915 in dash dvd 7inch screen ,1 alpine Rtype 12 woofer 1500 watts,pheniox gold mono block class d amp, scorpion BOX, level kit,mr taillight foglight highbeam kit, stock ford 18's on contie's, rancho 9000ES shocks ,6.0 transcooler, derale trans pan ,ccvdiy mod ,zoo dad , powerstrokehelp.com FUEL mods , hood insulation delete ,foil delete , high presure oil x pipe, DP tuner F-6 = 900rpmEBV, drive-thru tune ,EBV Engine brake tune,40tow ,60 econo, 80econo , supersmoke (use with OD) , 100hp, 120race 140agrresive, 3 pilier pod , pyrometer, 2trans temps inside tranny/outside ,boost,diy cold air6637 & 45 degree 4 inch alum.8"x8" , JEG'S 4" downpipe to 5" exhaust flopro 6"tip , dfuserA.I.H.plug, Extreme diesel Xwheel , (commin soon banks technicooler )
dtsthx is offline
Old 08-10-2009, 09:22 AM   #2 (permalink)
MilitiaAir's Avatar
Send a message via MSN to MilitiaAir Send a message via Yahoo to MilitiaAir
Sounds like its in limp mode.. Id double check the harness is plugged in all the way. Check the codes... Solonoid pack could have checked out... Easy fix just expensive part...
2000 F350 Lariat CC SRW 4x4 7.3 Turbo 4R100, 130K, Icon 8in Lift, EPBV Delete, AIH plug, HPO X-over line, CCV Mod, TS 6 pos Chip, 37x13.50x18 toyo MT's, Coolant filter kit, spin on trans filter kit, 203tstat w/ billet housing, MBRP 4in turbo back, 03 power heated tow mirrors, S&B Intake, Dpictol boost,pyro,tranny,hpop gauges, HID headlights, 08 rear bumper 95 F-350 CC SRW 4x4 7.3L Turbo E4OD 305K, Transgo Shift kit, Edge 100hp program, Warn Premium Hubs, K&N drop in, Blue Cam sensor, 105 gal Aux Tank, FPR Mod, CCV Mod. New Injectors than will be sold...
MilitiaAir is offline
Old 08-10-2009, 01:42 PM   #3 (permalink)
westvandude's Avatar
Just checking, that you poured at least a pint of atf into the new converter before installing it otherwise the pump may not prime. You can test flow by unhooking the return line from the trans and putting that into a bucket. About half a minute for a cup of atf at idle. Did you have anything else apart besides pulling the trans and refilling with atf?
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, Adrian Tavano's triple disc converter, transgo tugger HD2, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler & tru-cool trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, bug deflector, tint, 08' alum diff cover, clear corners & tails, silverstar bulbs, Xtreme XT855 reverse lights, 1500w inverter, Tekonsha Primus, EQX, Epicenter, Autotek MM4000.1D, 2x Audiobahn AWT12X, 2/0 cables, JVC KD-AVX44 El Kameleon dvd deck, 12.5" flipdown video.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. Custom fiberglass hifonics 12" sub & 280w usacoustics amp. Tint is next.
westvandude is offline
Old 08-10-2009, 01:54 PM   #4 (permalink)
dtsthx's Avatar
this was my first qeuss when i did the banks trans command and broke the harness on passanger side it did the same thing .
when i getoff work i will double check all harness connecters.
so would by passing all stock radiator translines effect this ?
or is it the new three disc HD tourqe the couse
I DID CALL ANDRE AT EDGE RACING CONVERTERS AND HE SAID 1-2 QAURTS WOULD BE FINE . I PUT 2 IN THE WHOLE TRANS,TORQE,DEEP TRANS PAN,AND 6.0COOLER TOOK 21 QUARTS TOTAL
THANKS TO ALL AT THE DIESEL STOP.COM
dtsthx is offline
Old 08-10-2009, 02:01 PM   #5 (permalink)
Yes, if the solenoid pack electrical connector wasn't in all the way it's possible to toast the trans from what I've read. So check that first. Not likely it's the converter as new ones should be bench tested by the manufacturer.
Most run into the radiator trans cooler and then into the 6.0 cooler. No idea if the 6.0 cooler by itself has enough capacity but you got trans temp gauge right? If all this happened right after you buttoned up the trans after putting in a new converter then the lines are not an issue.
Have you got an OBD-2 code reader for the trans light?
Old 08-10-2009, 03:03 PM   #6 (permalink)
TransBrain's Avatar
Sounds like something electrical is not plugged in. There are also a couple of speed sensors on top of the trans that are often forgotten to be connected after a trans R&R that will cause limp mode. The others would be the solenoid pack and the MLPS. Try disconnecting each and reconnecting. Otherwise, a scantool will be necessary if you can't seem to find something disconnected.
TransBrain is offline
Old 08-10-2009, 07:43 PM   #7 (permalink)
Mark Kovalsky's Avatar
That's not right. Fluid in the converter has nothing to do with the pump priming. If the pump didn't prime then NOTHING in the trans would work.
Another one that's wrong. It should be 1 quart in 15 seconds. That's 8 times more fluid than you specified.
Mark
Mark Kovalsky is offline
Old 08-11-2009, 01:34 AM   #8 (permalink)
Right-O. Forgot to say, that was with my trans totally cold so most of the flow would be using the bypass. Hot is a different story, as you mention.
Old 08-11-2009, 03:41 AM   #9 (permalink)
dtsthx's Avatar
thanx for the info
IT WAS THE BANKS TRANS COMMAND one pin had slipped out of the harness
so after running a trans cooler in seires for 2 1/2 to 3 years with some heavy pull's and some first gear desents from 10,000 feet , some green light pull's with a pullovers with a warning ticket RELEASING TO MANY PARTICALS by the UHP ( more than fair warning) the tranny fluied was almost black and smelt burned
So i decided with the new cooler i think is a 6.0 cooler but the add said for a f450 f 650 BUT ITS BIG three times as big , that i would just run it solo and see if it cuts back on burning.
i think the flow was not enogh!!
the new one solo cooler today ran in low 90's the temp was 30 degress low in stop in go traffic
and the torqe converter kicks butt
i hope the tranny holds up this weekend is ELK ARCHARY opener and i am headed to th high uinta basin 9,000 to 10,000 feet up by kings peak kinda
THANX AGAIN TO ALLAT THE DIESELSTOP
dtsthx is offline
Old 08-11-2009, 07:23 AM   #10 (permalink)
No, that's not right either.
The bypass only works when the cooler is plugged. There is no thermostat in the bypass, it only works on pressure. Cold temperatures (until it's way below zero F) won't make the bypass open.
Mark
Old 08-11-2009, 12:15 PM   #11 (permalink)
Ok.
So in your opinion is the flow more when the atf is hot vs at room temp, because it loses viscosity @ temp?
Old 08-11-2009, 02:23 PM   #12 (permalink)
No, flow should be just about the same hot or cold. Either temperature there should be one quart in 15 seconds.
Mark
Old 08-12-2009, 01:31 AM   #13 (permalink)
dtsthx's Avatar
temps have been 30 degress lower around town
so mark what would cause the almost black fuid ?
i tryd to upload some pictures but i cant figure it out
dtsthx is offline
Old 08-12-2009, 07:15 AM   #14 (permalink)
Black fluid means it has been severely overheated. Often that happens from a slipping clutch. If that is the case the only solution is to rebuild or replace the transmission.
Mark
Old 08-12-2009, 10:37 AM   #15 (permalink)
Mark
How hot does the fluid get at the clutch during a normal full throttle shift on a healthy trans?
444-4D is offline
