OBD-2 software vs. Auto Enginuity software - Diesel Forum - TheDieselStop.com
post #1 of 20 (permalink) Old 04-22-2005, 05:08 PM Thread Starter
My Photos: (13)
Anyone with knowledge of both? both these products are over my head at this point, but i want to purchase one. which to get is my question.
Tim
'97 F350 crew cab 4x4 lwb xlt 5 speed 225hp
'95 F250 reg cab 2wd xl auto 215hp
75f100 is offline
post #2 of 20 (permalink) Old 04-24-2005, 10:08 AM
Tom S's Avatar
My Photos: (20)
Re: OBD-2 software vs. Auto Enginuity software
Tim, I have the AutoEnginity tool. Unfortunately I have only been able to play with it a little as my truck has been apart waiting on some injectors. I have used the tool on some Ford cars and on one 2000up truck. It works excelent on the cars and worked fine on the newer truck. I even recorded a bunch of parameters for that truck on a dyno run. I tried it on a 97 truck and it was giving me some problems when I tried running the KOER test and a Contibution test. It did work well on the gather data mode. Once I get my own rig up and running I will know more. Jay at AutoEnginuity assures me that the older trucks and the newer one run on identical code so there should be no problem. We did not try pulling the chip to see if that made any difference. If I were you I would wait a little longer and make sure the older trucks are working up to par with the AutoEnginuity tool and then go that route. AutoEnginuity reads HPO in psi which is darn nice and AutoTap does not with a PC home version. I got mine from Chris at http://members.cox.net/kcmdieselperformance/ and was happy with the service. A second place I would not hesitate to do with business with is ITP a sponser here. I am hoping that Menace adds a few comments to this thread. You may want to take a look at this page http://www.itpdiesel.com/ScanTool.shtm.
Tom
Tom
96 F250SC 4X4 AUTO
F-6 live tuned, BTS Transmission, TN BB, Stage One Injectors, Custom electric fuel,
Banks Intercooler, Cowl Hood,
PMF RSK V and B code springs
Tom S is offline
post #3 of 20 (permalink) Old 04-24-2005, 11:39 AM
JimTJr's Avatar
My Photos: (20)
I second with what Tom said.. I purchased the Autoenginuity version with ENHANCED FORD,GM, And Turdyoda [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] Well ,,it came with it [img]/ubbthreads/images/graemlins/shrug.gif[/img] Anyway I have only had a chance to mess with MY PSD and two others,, one was a 97 and We also had some trouble with keeping connected. Jay will work with you night and day to get you up to speed on this stuff..very good customer support [img]/ubbthreads/images/graemlins/biggrin.gif[/img]. If you want a very expensive code reader,,then Auto tap is the way to go I guess.. but if you want to do some extensive in your garage diagnostics,,and monitor major systems ect...then AUTO ENGINUITY is the only way to go!
(On edit I know I am "Slamming" Autotap..I have never used it,,I have researched it some,,and only passing on what I have read on here and my bit of research...I DO OWN the AUTOENGINUITY one obviously)
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #4 of 20 (permalink) Old 04-24-2005, 04:08 PM Thread Starter
My Photos: (13)
thanks Tom and Jim.
i had heared only good about that software.
i had only recently heard of the OBD-2 from Alex Pepper.
obd-2.com
didn't know if anyone was famiular with it.
Tim
75f100 is offline
post #5 of 20 (permalink) Old 04-24-2005, 04:14 PM
Jim, how much $$ is the Auto Enginuity for the PSD to use on a labtop? Im thinking of getting it. And does it come with the hardware to hookup to the OBD port.
2001 white F250 sc xlt psd," DI regulator kit, DI BIG fuel system, DI Mine-Me injectors, DI ATS BB Turbo, DP Chip,DI Valve Pressure Release,DI-adjustable IDM mod ",Terminator 2 HPOP R-IPR, APR studs, 910 valve springs, BTS Trans&Converter,6.0 Intercooler, AFE Stage 2 with zoodad,Power Elbow, Bully Dog full 4" exhaust with 5" tip,Fluidampr, hx mod,203t-stat, CCV mod, Fumoto Oil Valve,Cool-Max Trans Cooler, Autometer Phantom Gauges,Bilstein shocks, Rancho5406 stablizer, Edge 4" lift kit, Rear RoadMasters active suspension, EGR Slotted & Crossed Drilled Rotors with Carbon/Kelvar brake pads, Welds Cheyenne 8s, Roll & Lock bed cover, Sylvania SilverStar 9007& 9005s, Chrome Billet Grill, 2003 Clear Headlights, APC Clear corners, APC Euro rear lens, APC gas & brake peddles, Acetone Badges, Chrome Door & Tail Gate Handles, Oakley Seat Covers, Viper alarm, Cyclops Fuel Cut-off alarm.
joediesle is offline
post #6 of 20 (permalink) Old 04-24-2005, 05:19 PM
JimTJr's Avatar
My Photos: (20)
Yes it comes with the hardware for the OBDII port. If you dont have a serial port on your puter ,,then you will need a serial to usb adapter. Jay sells them with his software if you need it..but a tad pricey. I got mine off ebay for 10.00 ..works fine.
The link above,,from TOM S...to KCM Diesel Perf. is where I got mine. Call him and check pricing...
Had a great deal when I got mine. Tell him your from The Diesel Stop.
JimTJr is offline
post #7 of 20 (permalink) Old 04-24-2005, 05:35 PM
Jim thanks, well do.
post #8 of 20 (permalink) Old 04-28-2005, 08:37 PM
Tom S's Avatar
My Photos: (20)
Finally got to try out the tool today. I had a couple of disconnects when I tried to watch too many sensors at the same time. It ran the KOER and contribution tests just fine. I recorded a couple of runs too. It was working very good for those. It does a nice job wathcing ICP duty cycle, HPOP, mass fuel desired, map pressure and exhaust back pressure. I like it.
Tom
96 F250SC 4X4 AUTO
Tom S is offline
post #9 of 20 (permalink) Old 04-28-2005, 08:43 PM Thread Starter
My Photos: (13)
Tom
soundsgreat, but i thought they were working on the "disconecting" problem? nothing yet?
if it gets straghtened out, i'm getting it.
Tim
75f100 is offline
post #10 of 20 (permalink) Old 04-28-2005, 09:01 PM
Tom S's Avatar
My Photos: (20)
I was trying to watch 9 sensors at once. I cut back to 6 andit worked fine. I recorded 3 runs driving around with no problem. I have data recorded now for map, hpop, exhaust back pressure and mass fuel all on one sheet. It stayed connected for at least 20 minutes driving around.
Tom
96 F250SC 4X4 AUTO
Tom S is offline
post #11 of 20 (permalink) Old 04-29-2005, 03:40 AM
Bought mine today from ITP. Should have it next week.
2000 Excursion PSD Ltd. 4x4, Modified Ford AIS,Di Prical gauges, Edge Evolution. SUVLights headlight harness. PSD Badges, Walker BTM,Lund Moon Viser, Putco SS Grill, ART Rotors, Hellwig Swaybar. Bully Dog shift Enhancer. ATS Deep tranny pan. 6.0 tranny cooler. AIH Deleted.
Bubbagm is offline
post #12 of 20 (permalink) Old 04-29-2005, 05:37 AM
DZLJIM's Avatar
Tim, I've been playing with my OBD-2. You can get real-time data from any of the computers inputs, pretty handy to have. Also buzz and contriubution tests. My biggest complaint is there's no manual how to use it, and very little help from the maker. I know it can record data but haven't figured it out yet. It takes alot of time sitting in the driveway with the truck running trying to figure it out. Wonder if the other one is easier to use?
Just an FYI.
Black, '96, F-350, 4x4, Day Cab.
Black/Silver, '97, F-350, 4x4, CC Short Bed.
for some redneck engineered projects.
DZLJIM is offline
post #13 of 20 (permalink) Old 04-29-2005, 07:14 AM Thread Starter
My Photos: (13)
thats the reason for this thread. i'm software stupid and am no sure of the diff in the 2 except for the price, which there is a big diff.
Tim
75f100 is offline
post #14 of 20 (permalink) Old 04-29-2005, 08:11 AM
Has anyone tried the Auto Enginuity on a truck with a modded IDM? Also does it display ICP in psi,volts or both?
AlanB
97 PSD f250 4x4. 06 common rail conversion in the process.
<span style="color: red">cummins conversions by Rockin S performance </span>
AlanB is offline
post #15 of 20 (permalink) Old 04-29-2005, 09:26 AM
Tom S's Avatar
My Photos: (20)
It displays ICP in both volts and PSI. I sent you the runs I recorded to your email Alan. I don't have a modded IDM so not sure on that. You are welcome to try it out any time you would like to make sure it does what you want. It did not like CH's truck for some reason but worked fine on mine. It only had a problem when I tried to record data from 9 sensors. It worked fine with 6. It is easy enough to use that Lisa was running the program and recording the runs with about a minute of showing her how it works.
Tom
96 F250SC 4X4 AUTO
Tom S is offline
