ok guys need your advice again....not sure what i should do.... - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 11-19-2009, 01:01 AM   #1 (permalink)
ok well i made the mistake of having my diesel shop install my brandnew DP Tuner...and suprise suprise they fried my PCM, they say they installed the chip and ran the truck and ran fine... I have not had anyother problem with this shop and have been going here for years...I talked to Jody and he said the only way to fry the PCM is if the shop installed the chip wrong, and left the key in the ignition, which he clearly says NOT to do....anyways i got a new PCM put in, and my mechanic is trying to talk me into buying a Banks Programmer with 3 programs in it ( the kind you plug in to change programs) anyways im kinda torn between getting the Banks or installing my Dp Tuner myself??? i just want a lil added HP for when i tow....Im sending the chip back to jody this week to make sure its not fried as well. so do you think i should keep the DP or go banks..i dont want to fry another PCM .....all of your thoughts and opinions are really appreciated guys, thanks!
Nick
PS....yes i know the DP tuner is a easy install but i had the truck in the shop for some annual maintenece so i figured id have them throw it in.....bad idea!!
1999 F-350 Dually 7.3 diesel lifted 8.5inches 37x13.50 xtream all terrains
Just Installed a DP Tuner F-5 chip, with stock, Decel, 60 Hp Tow, 80 HP econo and 120 HP performance and WOW!!! k&n airfilter Road Armor front bumber Warn 15000 winch Shift Kit, Beefier tourqe converter. Kenwood Indash Navigation, Sirius Radio, Back up camera, Kodiak Electric Steps HID Conversion Kit..
Next up is Gears!
buzzy12 is offline
Old 11-19-2009, 02:06 AM   #2 (permalink)
boomboom's Avatar
I think your mechanic helped you enough. I would stick with the DP tuner and install it yourself it's easy. The directions are pretty SIMPLE to follow IF you can follow simple directions unlike some people..
boomboom is offline
Old 11-19-2009, 02:14 AM   #3 (permalink)
I have the DP-Tuner and the Banks chip. The Banks keeps things like TC lock up and shift points about the same as stock settings. Jody changes all that stuff in his programs. I like my Banks chip, but I think I like the DP-Tuner better. If I want to change tunes, I just push a button and voiala, different tune. And best of all Jody has excellent customer service. Can't beat that.
2000 F250 7.3L Auto. CC 4X4 Lariat SB, 3.5 Fab Tech lift, 16X10 Typhoons 305/70/16 BFG's, AFE Stage2, Banks Big Head, Banks Exhaust, Bellowed up-pipes, Quadruple gauges, Wicked Wheel, Trans Go shift kit, Eaton TrueTrac, DP-Tuner F5, Stock, 60T, 60E, 80E, 120R.
JamieWS6 is offline
Old 11-19-2009, 02:29 AM   #4 (permalink)
Deputy Diesel's Avatar
After they buy and install a new pcm for the truck you drove in there for your annual maintnence. just take it home and install the dp there is alot of good info and alot of good reviews on every psd site about these products how could you go wrong with that?
03, ext cab, dually, 4x4, lariat, 6 grip, 7.3L, DP Tuner 60tow 80econ 120race 140extreme, southbend con O, mbrp cool duals,afe stage 2, Custom PDR feed pipes, PDR Super GTP hybrid turbo, Custom drop front hanger and shackle leveling kit , 315/75/16 BFG Mud terrains, steel 2inch rear dually spacer, 10inch wide single front wheels spacer removed
1954 Dodge M43 Military ambulance, built 360, 4 speed, 39inch militaries
87, f250, d60 front, 6 inch lift, 37's on 20's, 5.9L cummins all the mods, nv4500, southbend fe, s300, 5inch exh.
97 suzuki tl1000s two bothers exh all the mods.
85 honda 250sx trike. 3 wheelin 4 life!!!!
Deputy Diesel is offline
Old 11-21-2009, 10:30 AM   #5 (permalink)
stick with the dp tuner. maybe some peeps in your area could drink beeres and help, guide, you through the install. its easy, just follow the directions and go slow. this is no place to get all rammy or flustered. just easy does it, one step at a time and its done.
Somedays its just not worth chewing through the restraints
2011 F350 CC lariat ultimate dually with nav, line x, more mods comming
Y2K 4x4 250 PSD Xcab, auto, way too many mods to list Broken March 2011, written off due to collision
Crazy_Canuck is offline
Old 11-27-2009, 02:39 AM   #6 (permalink)
Layson's Avatar
My Photos: (28)
Nick
I would just stay away from this shop....
01 F350 CC LB 4x4 SRW,(w/forged rods), 12.5" Lift, OUO Traction Blocks, Dynatrac Prosteer Ball Joints, SPYNTEC Conversion, 40"ToyoMT, 22"MKW M19's, Hybrids, GTP38R 1.15, BTS Chip, Spearco, Headstuds, 910 Springs, 4" exhaust, Coolingmist Water Injection, BTS Tranny, 6.0 Trans cooler, 05' Conv. w/ Mirrors, AFE2, Isspro Guages, ORU Diff Covers, Hella 500s, Transfer Tank, AMP powerstep, Heat Extractor Hood, custom paint, billet badges, Train horns, Recon lights, strobes!
Truck Pics
Old Truck Pics
Layson is offline
Old 11-27-2009, 06:52 AM   #7 (permalink)
BLOWINSMOKE99STROKE's Avatar
stay away from that shop and banks! where are you located? maybe someone can help you with the DP, and refer you to a more reliable shop!
EARLY 99 F350, CREW CAB, LONG BED. 4X4 7.3L AUTOMATIC. EDGE JUICE W/ ATTITUDE. 4" EXHAUST, NO MUFFLER, 6" TIP, COLD AIR INTAKE, BD: CCV KIT (WON ONLINE, THANK YOU BD). DVD PLAYER, PS2, IN DASH TV, POWER INVERTER, 2-10" INFINITY SUBS IN PORTED BOX. CLASS 5 REESE TOW PACKAGE, FLIP UP GOSENECK HITCH. CB/PA, WITH DUAL TRUCKER WHIPS. TOW MIRRORS, AND CAB LIGHTS, RECON LED TAILGATEBAR W/ REVERSE LIGHT, BUG GUARD AND WINDOW VISORS. 05 GRILL AND HEADLIGHT SWAP, 08 TAILGATE, 285/75 BFG ALL-TERRAINS, SHACKLE LEVELING KIT, AND BILSTIEN SHOCKS. 5% TINT ALL THE WAY AROUND, AND 50% ON THE WINDSHEILD.
SOON TO COME: 08 TAIL LIGHTS, CLEAR CABLIGHTS, RECON ESCALADE STYLE 3RD BRAKE LIGHT, STROBE LIGHTS, PROJECTOR BACKUP LIGHTS, 33X12.50 BFG ALL TERRAINS ON BLACK DICK CEPEK 17" RIMS, EDGE EVOLUTION PROGRAMMER (STACKED), RAPTOR HIGH PERFORMANCE FUEL PUMP, HIGH PERFORMANCE HPOP, POSSIBLY 10" STACKS!
BLOWINSMOKE99STROKE is offline
