Overboost Annihilator vs Boost Pressure Relief Valve - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 03-31-2008, 02:04 AM   #1 (permalink)
which is better?Overboost Annihilator mod on my truck, or Boost Pressure Relief Valve fromDiesel Innovations - Products
what are pros and cons to this, which is a recommended mod
Chris 28 00 Superduty srw cc 4x4 288K and going strong
currently-DYI-k&n intake, Inverter, Ranch Hand Frt, Headache Rack, 2 Daylighters, 6" lift on 18"s
bears4x4 is offline
Old 03-31-2008, 09:31 AM   #2 (permalink)
My Photos: (5)
Relief Valve creates a boost leak at higher boost levels in order to fool the MAP sensor. The Overboost Annihilator regulates the boost pressures to the MAP sensor without creating a boost leak. I went with the OA since it doesn't create a boost leak in order to do its job.
Pocket is offline
Old 03-31-2008, 10:27 AM   #3 (permalink)
well there is actually 3 types- sp diesels electrical version, a regulated version like itp's,
and a valve like dieselsites.there is a lil back and forth, about which is best.
dieselsites works just fine. the boost leaks are un-noticable, and have no effect on performance..were talking about needle point hole leak. never heard any problems with them.
the itp seems to be slightly more popular. But it has its qwarks too, most of the problems are, user error install problems. at least a half dozen or more have been sent back...really because the user got the ajustment so far out of wack, and needed dennis to reset it. so if you get that one and order on the phone I would go a head and ask him how much you should adjust it , and when . they seem to work fine when set up correctly and not toyed with.
sp diesels has the same one user had no luck with it and bashed it with a hammer, personally i would have returned it for a replacement, or a refund...others use them fine.
kinda boils down to price, and prefernce.
I would wait to add it, to a list as they are small and can be shipped easy with other things.
as far as preference that is an individual user opinion.
early 99 f350 4x4 crew cab
work in progress
southmike is offline
Old 04-01-2008, 01:17 AM   #4 (permalink)
k thanks
bears4x4 is offline
