P1690 code? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 12-02-2007, 08:40 PM   #1 (permalink)
P1690 code?
SO I checked for codes the other day and I got a P1690 code what would you say is the problem. (I did see it has to do with the wastegate)
It's a 1999 F250 7.3 auto 2 wheel drive.
Dan
Dan
1999 F250 7.3 Auto
Over 265,000 miles
2007 Superduty face lift
bigblockranger is offline
Old 12-02-2007, 11:19 PM   #2 (permalink)
F350_6's Avatar
Re: P1690 code?
From the service manual:
KH2 DIAGNOSTIC TROUBLE CODE (DTC) P1690
DTC P1690 indicates that the PCM has detected a failure on the WGC circuit.
Possible causes:
short to ground
open in harness
damaged connection
damaged WGC solenoid
damaged PCM
blown fuse
Disconnect the WGC solenoid harness connector.
Key on, engine off.
Measure voltage between pin 2 (KEY PWR) on the WGC solenoid harness connector and ground.
Key off.
Is the voltage greater than 10.5 V?
Yes GO to KH3
No REPAIR open in (KEY PWR) circuit 16, or INSTALL a new fuse. RESTORE vehicle. CLEAR DTCs and RETEST.
Hope this helps.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 393,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350_6 is offline
Old 08-30-2008, 02:10 PM   #3 (permalink)
Ok I have a question where is the WGC solenoid located?
Also what will this do open and close the wastegate?
I cleared the codes the other day and just turning the key on showed the code.
Also where is the fuse located for this, I did have a CD for the truck but it's someplace but here right now
Our truck seems to be running rich so I wonder if this might be part of the problem.
Dan
Dan
1999 F250 7.3 Auto
Over 265,000 miles
