Powerstroke High Pressure Oil Crossover Hose - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 08-01-2007, 01:00 PM   #1 (permalink)
indystroker's Avatar
What does this consist of? There is hydraulic hose's of all sizes and fittings where I work. I'm sure I could make it. How long of a hose, what size hose, size of fittings...etc?
Indystroker
01 F-250 4x4, XLT, Crew Cab,
AFE Stage II Intake
TS Chip w/ PHP Tunes 40HT,80DD,120R,140 Xtreme
Auto Meter Gauges
ITP Fuel Tank/Pre-Pump Kit
Riffraff FRx Crossover
Gutted Turbo
Riffraff SS X-over
DIY CCV
4" Turbo Back w/Donaldson M085171
Warn Hubs
Sonnax Kit
indystroker is offline
Old 08-02-2007, 12:49 PM   #2 (permalink)
Re: Powerstroke High Pressure Oil Crossover Hose
Does anybody have one of these or is everybody keeping tight lipped about it?
Indystroker
AFE Stage II Intake
Auto Meter Gauges
Gutted Turbo
Riffraff SS X-over
DIY CCV
Warn Hubs
Sonnax Kit
Old 08-02-2007, 01:20 PM   #3 (permalink)
I just seen one last night. All it is , is a piece of ss tubing and some fittings to connect the heads together. It was one of the sponsors here on the site, around $65.00
Dan
03 F-250 XLT oxford white\Arizona beige met. exc cab, 4x4 SCT Excal II, AFE stage II intake, CCV mod, Foil deleat mod, Reg fuel return system, Hutch mod, Harpooned, Boost fooler, 4" diamond eye turbo back exhaust, Chrome step bars, 06 American Spirit 2 horse trailer. Other go fast goodies that can't be mentioned
" Here kity kity "
skylinedan is offline
Old 08-02-2007, 01:57 PM   #4 (permalink)
FionaThe02PSD's Avatar
My Photos: (12)
Check with Dennis at ITP. He has a SS hard line that is awemsome!
2006 Dark Slate F350 CC LB 6X6 Lariat Tow Boss Complete with training wheels.
Vegetarian, an old indian word for bad hunter!
K&N Intake, Coolant filter, Recon smoked LED litght: tail, Clearance, Center bumper, 3rd brake, Fat fender, Pressure pro TPMS, Firestone air bags, Alpine/Infinity/Polk sound system, Autometer Phantom EGT,Trans,Boost gauges above the rearview mirror.
For the BEST in performance parts and accessories ITP Diesel
Arizona Powerstroke Group
FionaThe02PSD is offline
Old 08-02-2007, 02:41 PM   #5 (permalink)
I had one built. They are -5 o-ring ports in the head. NAPA has the adapters for about 3 dollars each (weatherhead part number C5315X6X5), and the hose ends and hose (rubber version) is available at any hydraulic supply store 4000psi hose if i had to do it again I'd use 45 degree fittings. The hose and fittings are 3/8 or -6 AN/jic.
2002 Royal Blue F350 SuperCab Lariat 4X4 Dualie
428,000miles and counting!!!
02bluestroker is offline
Old 08-02-2007, 03:41 PM   #6 (permalink)
Thanks 02bluestroker...thats what I was needing to know.
Indystroker
AFE Stage II Intake
Auto Meter Gauges
Gutted Turbo
Riffraff SS X-over
DIY CCV
Warn Hubs
Sonnax Kit
Old 08-02-2007, 09:54 PM   #7 (permalink)
Thats where I saw them.
Dan
" Here kity kity "
Old 08-03-2007, 08:29 AM   #8 (permalink)
sarnall2's Avatar
Feedback Score: 2 reviews
I agree, I'm running Dennis' hard line. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2001 Platinum Edition F250 SuperDuty 4x4 Lariat Build Date 02/01 - My pics
Traded the above 01 for a 2006 Harley Davidson Edition 6.0L F250- CC, SB, 4x4-NICE! With only 23,358 miles
Upgrades So far: SCT Livewire w/extreme from Innovative Diesel and a set of Elite's Billet fuel and oil filter caps.
sarnall2 is offline
Old 08-03-2007, 08:54 AM   #9 (permalink)
Did you notice anythng better, I did the same basic idea with my fuel system last night. Run a peice of 5/16" tubing from back of drivers head to the front of pass. head, ties the system together. can't say if it does any good.
Dan
" Here kity kity "
Old 08-03-2007, 09:07 AM   #10 (permalink)
sarnall2's Avatar
The HPX Line- yes I did. It quieted the motor a little when everything balanced out.
sarnall2 is offline
Old 08-03-2007, 10:35 AM   #11 (permalink)
quieter here too
Old 08-03-2007, 01:12 PM   #12 (permalink)
My Photos: (12)
Quiet is a thing of the past for me but I noticed the most improvement with ITP's Regulated Return. Couldn't believe how quiet and smooth it actually made my truck.
Old 08-03-2007, 01:26 PM   #13 (permalink)
I'm thinking thats next on the list , my mod I did last night with the fuel ine seems to have sprung a leak . I,m gonna try and see where from,just have a nice drip drip from the back.
Dan
" Here kity kity "
Old 11-16-2009, 12:58 AM   #14 (permalink)
To anyone who may stumble upon this thread and pick up on this idea to cross-connect the fuel rails as mentioned ... without a full conversion to a regulated return system, this modification doesn't offer any benefits.
The fuel rails are already "cross-connected" at the fuel bowl because each fuel rail has it's own supply line connected to the same source. Cross-connecting the fuel rails at their ends with no supply from this line (and no forced flow through it) leads to the possibility of an air bubble remaining or at the very least ... no effect whatsoever. It is _possible_ that this could provide more fuel to the #8 cylinder that tends to get starved normally (8 fires after 6 in the firing order and they are located next to each other on the fuel rail). This configuration connects 8 to 1 through the cross-connect. The firing order has 6, 8, and then 1 which is also the order in which they are physically connected.
This cross-connect line could be effective at preventing fuel starvation if it included an accumulator. That is more trouble than it's worth. This proposed modification, in my opinion, is not beneficial.
Scraph is offline
Old 11-16-2009, 11:30 AM   #15 (permalink)
fxdwgi's Avatar
Uh.....this thread is about tying togther the high pressure oil between the heads, not the fuel.
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Draw Tite Fold Over Gooseneck * Reese 15K Sliding 5er * Gauges Whited Out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM * ITP Pre-pump * One Very Understanding Wife*
I AM AN AMERICAN, SO I DRIVE AMERICAN.
fxdwgi is offline
