powerstrokehelp.com fuel rail mod - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Closed Thread
Old 10-29-2009, 09:26 PM   #1 (permalink)
Has anyone done this and what gains did you see ? Did it quiet the motor @ all ?
01 4x4 off road . mods to include : fluidamper , big bad wolf turbo w/ banks down pipe mod, 5" pipe to areo resinator muffler , upgraded jasper trans , propane injection , oil cross overs , inline map relife valve , boost fooler , aih delete , pulley kit , flex lite fan , ccv mod , multiple Dfuser sensor eliminators and 18k injector control, custom 4" intake w/ 1200 cfm filter , quadzilla monitor , edge 100 hp programer w/ BD program , cryo slotted rotors w/ hawk pads , 07 header and lights , Lincon style grill , alien patrol bumper (owner is p.o.s.) , 6" super lift , 37" desert grapplers , 20' m.k.w. rims , just bought 6.0 intercooler , airdog 130/75 and ts 6 bank with dfuser programing
johnthepracticalbuilder is offline
Old 10-29-2009, 09:35 PM   #2 (permalink)
Is that the one drilling the banjo fitting? Seems that it would only help under high flow conditions.
2003 7.3 F250 SD SRW Auto DIY intake 285/70 1.5" Leveling Kit TS Performance 75 HP Chip
TTBadDog is offline
Old 10-29-2009, 10:40 PM   #3 (permalink)
I did it , nothing happens
mrwrench is offline
Old 10-30-2009, 03:56 PM   #4 (permalink)
thank you
I'm currently replumbing the the whole fuel system . I've had too many problems with it . The new air dog 130/75 will pump 75 psi constantly . I've concluded that it's a lot easier to push fuel through a larger hole then a small one . Right ?
Old 11-02-2009, 10:27 PM   #5 (permalink)
CSIPSD's Avatar
My Photos: (52)
Take everything you read, or hear about on that website... and delete it from your brain.
05/01 F-250 PSD,200k,AFE2 ,Modded H2e, 6.0 IC,Water Injection, AIH delete, Swamp tuned, GTS Hybrid injectors, ITP Fuel system, Studs, 910 valve springs, Suncoast 4r100,MBRP Duals, 6" tips, 17 Isspro Performax gauge's, 100g fuel tank, 05 mirrors with recon lens, 4" Revtek lift 37-13.50-17 Toyo MT's
CSIPSD is offline
Old 11-03-2009, 10:19 AM   #6 (permalink)
Don't hold back , how do really feel ? Why don't you feel as if this would not be a good mod ? Just bought a cck from dino fuel alt. My new for powerstroke 130/75 air dog will be any day now . I also did a diy tank mod . The only other thing I think I can do would be add larger fuel lines ? As soon as a customers check clears (tomarrow) I'm getting the adrenaline HPOP and 203 stat.
John
Old 11-03-2009, 02:42 PM   #7 (permalink)
ajohansson's Avatar
whats wrong with powerstrokehelp.com? I think the site is awesome! Not all the stuff on their is super great but neither is all the stuff on here!
ajohansson is offline
Old 11-03-2009, 03:36 PM   #8 (permalink)
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
What's wrong with the loud clatter??!!
One of the main reasons I love my truck.....
I had a Lexus Rx300 before.....
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
V10 Tranny cooler + Trucool max cooler
Wicked Wheel-loud little sucker!
DieselStop Boost fooler
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using Superchips 80hp Performance tune.
Wastegate disconnected
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
4'' Ported Housing non-ATS
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Cam,DVD,Nav.,Satelite Music.IPod
Jason smooth topper.
Big air compressor/tank
2 air horns w/ big valves
Quick connect Air hose for any air tool/tires
All work done at DieselTriple.Com-Miami,FL
Here but not installed:ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline
Old 11-04-2009, 03:12 PM   #9 (permalink)
CSIPSD's Avatar
My Photos: (52)
John
Because it does nothing, get a proper fuel system in there if your going to do it.
Dennis at ITP sells the best on the market.
As far as Powerstrokehelp... I would not trust him with a yugo, let alone a powerstroke.
CSIPSD is offline
Old 11-06-2009, 05:18 PM   #10 (permalink)
WOOOAAA! What's with all the hate?? BTW, where's your series of informative videos? I guess I missed that link. At least he stepped up to the plate and invested some time for the powerstroke owner's benefit. How could that guy in Georgia burn your butt so bad that you feel compelled to smear him with insults and derogatory language?
Instead, why don't you point out where his information is flawed and improve all of the ownership experience of your fellow Powerstroke owners while you're at it?
You're entitled to an opinion but please be civil. When you're not, others will form an opinion about you.
2000 F250 2WD 7.3L, 184,000 Miles, 6spd Manual, Hypertech programmer, 4" Flowmaster Exhaust, VegiStroke V3, Custom Vegi Oil Tank and Toolbox, Retrax Rolltop Bed Cover, Al's Liner, ITP Fuel Tank / Pre-Pump Kit, Harpoon Mod, Pioneer Avic-X710BT, XM Sat Radio
Last edited by klhansen; 11-06-2009 at 10:39 PM. Reason: Language..next time a time out (removed insult from quote)
vegoilrecycler is offline
Closed Thread
