Prestone Flush/Fill Kit - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 11-20-2009, 11:14 AM   #1 (permalink)
Exclamation Prestone Flush/Fill Kit
Is the Preston Flush/Fill Kit safe to remain installed? The cap is just a hose bid PVC cap with a rubber gasket. If it is, it could also be used to connect a coolant filter instead cutting another hose or using the thermostate plug. Anyone have any problems leaving it installed?
F-250 2000 4x2 SC SD Long Bed, 6-speed, American Racing 'Kong Wheels, Glasstite Camper Shell & Vintage Airstream gone...! Replaced with vintage Pop-up Sunlight Truck camper that fits in garage.
klutz1 is offline
Old 11-20-2009, 11:37 AM   #2 (permalink)
boomboom's Avatar
The nice thing about connecting the return line to the overflow bottle is you can see the flow coming from the filter. If the flow slows way down you know your filter needs changing . IMO I'd rather not leave flush kit in, I've seen them leak over time.
boomboom is offline
Old 11-20-2009, 11:42 AM   #3 (permalink)
I'd rather remove it and install a regular hose Tee in it's place to connect the filter to.
444-4D is offline
Old 11-20-2009, 12:50 PM   #4 (permalink)
SmokeyWren's Avatar
My Photos: (44)
My Prestone coolant flush tee has been installed for about 8 years and three or four coolant flushes. The only problem with that is the double-female connector you need to screw on a garden hose gets misplaced, and you have to buy a new kit just to have that connector.
SmokeyWren is offline
Old 11-20-2009, 01:57 PM   #5 (permalink)
Makes sense Smoky. I saw your filter set up and it looks good to me.
klutz1 is offline
Old 11-20-2009, 03:38 PM   #6 (permalink)
I keep mine in my tool box but I may need a new one anyway. The one I have might be 30 years old. I also use a hose extension so I don't have to have that double sided connector spraying water under the hood. I probably won't use it when I flush my truck anyway.
444-4D is offline
