Problem installing Superchip 1705 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 05-18-2006, 11:53 AM   #1 (permalink)
I'm new to the forum, but have been reading for a while. I am trying to install a Superchip 1705 on my 02 7.3. When I installed it, the display said it needed an update. I tried it on a 99 7.3 and it said the same thing. I bought this thing used off one of these sites so I don't have a receipt to send it in to Superchip for the update. Without the receipt they charge $200.00 for the update. Has anyone had this problem or have any suggestions? Thanks.....
2002 Crew Cab Lariat Short Bed 7.3l
Superchip 1705
Walker BTM , Ford AIS w \ Zoodad
9" LCD DVD Player , Wood Grain Dash Kit
knsh913 is offline
Old 05-18-2006, 12:09 PM   #2 (permalink)
rdvit94's Avatar
Re: Problem installing Superchip 1705
I would call who ever you bought it from and tell them it doesn't work, maybe they still have the reciept.
2001 F-350 XLT, CC, LWB, 4x4, Auto, Off-Road, DP-Tuner (stock-40-80-120), SP Diesel Air Intake, MBRP 4" Exhaust, Banks BHA, TAG, Dieselsite BRV, AIH Mod, 203 Stat, Sonnax/Tri Kit, Tank Mods, Redhead Steering Gear, DB Electric Starter, Di Pricol Gauges in A-Pillar, 3.5" Custom Lift, 315/75/16 BFG ATs, Delta Toolbox
Truck Pics
rdvit94 is offline
Old 05-18-2006, 07:54 PM   #3 (permalink)
Are you sure the previous owner returned their truck to stock before selling it to you? It may be VIN locked.
http://community.webshots.com/user/roadfrog
Cheers,
Chris
FOR SALE! 2002 F350 CC 4x4 SB Lariat Blue & Silver, General AT2 295/75/16's on 16x8 Panther Rims, KYB Monomax Shocks, Euro Style Tail Lights, billet fuel door, Putco chrome handles, Autometer Z Gauges & Pillar Pod, Billet Grill, Bullbar, JVC KD-AR870 head unit, Sirius, MEI Reference Series 600 Watt amp with 6.5" Alpine DD Drive F17C components front, 6.5" Jensen components in rear, Better Built truck box, auxiliary backup lamps, acetoned badges, blacked out lower weld seams, Dodge auto-dimming rearview mirror, Avital alarm system, heater by-pass mod, in-tank, harpoon and pre-pump mods, 5" SS exhaust tip.
2002 Acura el (only available in Canada)
2002 Fleetwood Wilderness 31G
1988 Campion Allante, 19.5' w/ Merc 5.7 litre
Roadfrog is offline
Old 05-19-2006, 10:05 AM   #4 (permalink)
If the previous owner didn't return it to stock, it would say it was vin-locked as soon as he plugged it in.
Kenny
2001 F350 PSD CC SRW Auto w/3.73's, BD Torq-Loc and Torque Converter Lockup LED light, Pac-Brake, Turbo-Back "Duals", Line-X, Three Gauge Dash Pod with Isspro EV's, AFE Magnum Force Intake kit, ATS Turbo Shroud, Royal Purple throughout, Edge Evo set at "Extreme" with a 29ft Alpenlite and 16ft Harbercraft following behind.
The New Kid is offline
Old 05-19-2006, 03:54 PM   #5 (permalink)
Even if you have the receipt they will charge you $200. I asked.
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 05-20-2006, 12:53 AM   #6 (permalink)
I have a SCMT that I've been using since 2001 when my truck was new. It was pretty good. Recently my PCM failed ( I don't know if it was caused by the SCMT or not) so I got a replacement PCM from DP-Tuner.com with an 80hp econo tune flashed on it. Jody at DP-T told me the Superchip 80hp program was about equal to his 40 hp tow program. I thought...yea right. The first time I drove it was [img]/ubbthreads/images/graemlins/eek.gif[/img] quite a suprise. Dang, he knows what's up! My truck starts, runs and shifts better than it EVER has before.
I suggest you call Jody Tipton at DP-Tuner and spend less of your money for more performance.
Chris
2002, F350, Lariat, CC, LB, PSD, QLJ5, A/T, ESOF(with hub disable switch), LS, Off Road pkg, AIC, Jordan 2020, X-monitor, IAH removed, Fuel pressure shimmed, DP-Tuner 80 econo, acetoned badges, 315 BFG's on Alcoa's, 4"DPPI exhaust, Sonnax/Tricumulator, DIY BIG air filter with ZooDad, Bilsteins, EBV removed, WW, Proflex SS sleeves over the orange manifold hoses, MAP connected to adjustable pressure regulator, EBPS connected to intake manifold, Red line disconnected, Modified factory wastegate, 200 amp large case alternator, AutoEnginuity, Chris Thompson, SoCal Biodiesel Users Group member, Soon to have a bunch of goodies from Riffraff Diesel.
Duzitall is offline
Old 06-02-2006, 04:35 PM   #7 (permalink)
Problem solved, I contacted the seller and he had the receipt. He faxed it to me, and I mailed everything to Superchips with a check for $12.50 for return postage. It was less than a 2 week turn around! I have the programmer installed in my '02, I have it on the tow-safe mode and like it so far.......
Superchip 1705
knsh913 is offline
Old 06-02-2006, 06:13 PM   #8 (permalink)
Parts Jimmy's Avatar
Pump that 90HP program in there and you will like it better.
2000 F350 SRW Supercab 7.3 PSD
4" MBRP Exhaust with Donaldson M085171 Muffler,
SCT X3 w/DP-Tuner 60T-80T-80E ,
Transgo Equipped 4R100, Autometer Guages,
Donaldson/Motorcraft Air Induction System,
Ford AIC, Northstar 8.5 Adventurer,
Timbren Overloads, Code L Front Springs,
Bilstein Shocks, BFG Commercial TA Rubber,
Hella 700FF Driving Lights
6.0-6.4 PSD Motorcraft Filter Comparison Video
Fuel Quality Video
Parts Jimmy is offline
Old 06-02-2006, 08:09 PM   #9 (permalink)
Pappy19's Avatar
My Photos: (6)
Bye bye tranny.
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Magnaflow, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i, MagHytec rear dif cover.
2007 Lincoln LT (wifer's grocery getter),Superchip,Magnaflow duels, K&N dropin, Leer Browning Special
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies.
pappy's truck
Pappy19 is offline
Old 06-02-2006, 10:01 PM   #10 (permalink)
Matt Calley's Avatar
I have been running the SCMT 110hp program in my truck for the last 130k miles. No problems. I am at 160k miles and wondering if I should replace the tranny before hunting season when I start pulling the travel trailer again to the hill country. Diesel Innovations is just 30 minutes away from me and I have had the itch, its justs hard to drop that much do-rey-me on something with the stock tranny holding up so well.
2002, F350, Crew Cab, XLT, 4x4, PSD, Auto, Black Tinted Windows, Aluminium wheels, Manual Locking Hubs and shifter, adjustable pedals, 6 Disc CD Changer, Towing Package, Camper Package, Rubber Floors, Highway Products custom toolbox / dog kennel combo, 2 1/2 inch Pro Comp Front Leveling Kit, Banks 4 inch Monster Exhaust, Triple Pillar Gauge mount with Isspro Pre turbo pyro, turbo boost and tranny temp gauges, Isspro Turbo Temp monitor, Ranch Hand Bumpers front and rear...Bullnose up front...10inch drop in rear, Warn 12000 winch, Bilstien Shocks.
ATS Tranny, ATS 5 Star Torque Converter with V10 Aux cooler, DI High Performance Alum intercooler, DI 6 position chip, DI Ceramic Up-pipes, DI High Pressure Crossover Rail Kit, Engine Mounted Fuel Pressure Gauge, Garret GTP38R Powermax BB Turbo, AFE Stage II intake.
397k miles and strokin for 500k. Still using original glow plugs and injectors. Been running 1 qt of Pennzoil 2 cycle oil with every fill up since the inception of ULSD.
Matt Calley is offline
Old 06-02-2006, 10:20 PM   #11 (permalink)
Pappy19's Avatar
My Photos: (6)
Before I would spend $4000 on a new tranny system, if it is running good, I would add an additional tranny cooler, a Transgo Tugger shift kit, and Maghytech tranny pan. I would also change the fluid to all synthetic, like Amsoil Racing fluid or Mobil 1. Just make sure it is rated correctly.
pappy's truck
Pappy19 is offline
Old 06-02-2006, 10:28 PM   #12 (permalink)
I ran Mobil 1 Synthetic in the tranny its whole life up until last week. When I changed it I went to Valvoline due to time restraints and not having synthetic at hand. Will probably go to Amsoil shortly.
Old 06-06-2006, 03:53 PM   #13 (permalink)
Our tuning has trans programming in the program. We do not recommend using a shift kit with our tuning.
Ron
rrapp@superchips.com
SUPERCHIPS is offline
Old 06-07-2006, 11:38 AM   #14 (permalink)
My Photos: (5)
Better to leave the line pressure stock and mod the tranny internaly. Forget about the bigger tranny pan as well.
1999.5 cc dually
69 mustang, 472", c/4
9 sec alky injected bracket bomber....
529" in the works as we speak
Richter69 is offline
