program surprise, now what? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 01-29-2007, 01:12 AM   #1 (permalink)
Mudraga's Avatar
My Ex was stacked and I didn't know it! (at least I think so)
I was having a problem with my engine stalling on every trip (not the way a CPS stalls). It would start right up again each time. Someone suggested it could be my Edge EZ. So I disconnected it and VOILA! No more stalling. Funny thing is, I didn't notice any loss of power after disconnecting. Still smoked plenty when I got on it. Then, the coup de grax (sp?) was when I reset my overhead computer. It was reading about 2x the actual mpg before I disconnected it (~33mpg). Well after resetting it, it STILL reads way high, now its saying about 29mpg. So I put one and two together: lots of power + lots of smoke + messed up overhead = program or chip. Right?
SO...now what? First I guess I need to know what exactly I have right? So I'll look and see if there is a chip installed. If so, will it have a manufacturer logo on it? Like DP Tuner, or Superchips, etc.? And what if there is no chip? Is there a way to find out what program or at least what brand of program has been uploaded to it? Can I take it to Diesel Innovations and have them look into my computer or what?
2002[1/02] Excursion 4x4 Ltd. PSD,Unknown program, K&N GenII FIPK Air Filter, straight pipe exhaust, Autometer Z Series pyrometer and boost gauges, Air Lift SuperDuty air bags with Load Controller II onboard air system, Sonnax Tricumulator, HX hose.
Mudraga is offline
Old 01-29-2007, 01:27 AM   #2 (permalink)
NorCalDiesel's Avatar
Re: program surprise, now what?
I take it you bought it with the Edge EZ already installed.. If so the previous owner may have also had an Edge Evolution. Those will backup the stock programming and install one of three programs, tow, performance or extreme. You would not be able to tell other than by using the Evolution to return it to stock. Just a thought
2002 X PSD, Billy Boat 4", AirRaid, Gillett Diesel Service Turbo, High Output turbo exhaust housing, KCM HPX Crossover, ITP Overboost Annihilator, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp
DP-Tuner 6 pos No Start - 140 Aggressive
Thanks Jody and Diane
Super Heavy Duty / Triple Disc 4R100 built by Jim Galatioto at ATO Transmissions in Sacramento.
NorCalDiesel is offline
Old 01-29-2007, 10:06 AM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (44)
I suspect David Lott can look at your PCM and tell whether it's a stock program or a tuner program. If it's a tuner program, he can probably re-flash it back to a stock program. But before you do that, be certain there is not an Edge Evolution tuner stuck behind or under the back seat. If you find one, that's probably the culprit. The Edge folks are fond of "stacking" their products. [img]/ubbthreads/images/graemlins/eek.gif[/img]
My edge Evolution doesn't smoke at all on the tow setting, but it smokes like a freight train at the higher-HP settings. So if you're getting black smoke without a chip, it's probably from a tuner program of some sort - maybe an Evo.
SmokeyWren is offline
