Programmer Help - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 05-05-2006, 09:00 AM   #1 (permalink)
Programmer Help
Ok so this may sound a bit odd but... I purchased my truck (1997 F350) used and was told that it has been chipped which leads to my questions.
1. How can I tell if it really has been chipped or not?
2. Is there anybody around the Seattle area with a programmer that can take a look at my truck and give me an idea what the setting are? I would really like to know if I could get a bit better mileage out of it.
Thanks and sorry for the newbie questions.
Perry Turner
1999 F350 4x4 DRW Crew Cab LB 6sp manual - stock
perryt is offline
Old 05-05-2006, 09:48 AM   #2 (permalink)
Re: Programmer Help
Perry Turner
To see if it has a chip in it, you will need to remove the emergency brake bracket and pull it aside and look at the pcm, if there is a chip there it will be obvious.
Here is a detailed article on how to install a chip, just follow the part about the e-brake and you'll be able to tell.
Look here
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
