Project: Reliable Hauler - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 12-22-2012, 02:59 PM   #16 (permalink)
Justin@DP-Tuner's Avatar
Originally Posted by toyomatt84 View Post
No problem. I love the help, Justin.
No problem. Feel free to contact me if you ever have any questions.
DP-Tuner
For Your Tuning Needs
www.dp-tuner.com
Like us on Facebook!
828-221-0076
justin@dp-tuner.com
Justin@DP-Tuner is offline   Reply With Quote
Old 12-23-2012, 01:20 PM   #17 (permalink)
toyomatt84's Avatar
Well, if you have any input on the modifications I listed above (good and bad), I'd love to read it!
I'm honestly enjoying this truck rather thoroughly. I'm a pretty tall/broad guy (6'2" and 265lbs), and it "fits" me rather comfortably.
*free hugs*
toyomatt84 is offline   Reply With Quote
Old 12-23-2012, 01:30 PM   #18 (permalink)
Sportscraft's Avatar
If your looking to go green then WVO might work but if your looking for reliability and power tuners I'd stay away from it like people said. Even filtered its still greasy and gels up if it gets cold etc. Just too likely to gum up the system IMO. That 7.3l is an awesome engine so why risk it with and alternative fuel. Also most power adders/tuners aren't necessarily designed to work with it. Definitely check with them first your you might really screw up the engine. If your looking for clean power a methanol or propane system might be a better set up.
Sent from my iPhone using AutoGuide.com App
2012 F450 Crew Cab DRW, 4.30LS, Lariat Ultimate, FX4, Chrome Package, Snow Plow Prep, 5th wheel prep, LineX Spray In Liner, Cable Lock. Black Clear Coat with Monotone Black Int!
Sportscraft is online now   Reply With Quote
Old 01-02-2013, 12:13 PM   #19 (permalink)
sasha_j's Avatar
I'll be looking at this thread in the future. I'm looking for a tuner as well for my F-450, which, I think, starts out de-tuned from the factory.
Regards,
Sasha J
http://www.laura-n-sasha.com/
1999 F450 7.3 PSD CC 4x2, Roll-A-Long Hauler Bed, 15,000 GVWR, 26,000 GCVWR, PacBrake PBRX exhaust brake, HP625 frame mount compressor, 5 gallon air tank, AIRSAFE 25K Air hitch & KSH 80 Gal Aux Tank/Tool Box, aft OEM 25 Gal Fuel Tank
http://www.thedieselstop.com/forums/...f-450-304.html
2006 FR Sandpiper Sport F37 Toyhauler, 16K GVWR, 7K axles, 17.5" Wheels, 600W Solar
SOLD: 2005 F350 SuperDuty 6.0 PSD Auto Crew Cab Long Bed 4x4 SRW Lariat
sasha_j is offline   Reply With Quote
Old 01-02-2013, 05:29 PM   #20 (permalink)
Some tunes will definitely help wake the truck up.
DP-Tuner
www.dp-tuner.com
828-221-0076
justin@dp-tuner.com
Old 01-03-2013, 10:37 PM   #21 (permalink)
About the CCV mod thing. I know I did it and thought it was great at first and all but regardless of what others say I swear it was the last straw on the proverbial camel's back that started my oil seals leaking. I hate even bring it up because there are some pretty strong opinions about it. Buy my 2 cents worth is that if I was to do it all over again...I wouldn't. I'd just leave it the way it is and not worry about it. That money could go towards a lot more important and NEEDED items. Like the AIS filter system. That's money well spent....just don't get talked into the fender sleeve kit (it didn't gain me anything and I still had to do other mods to the front snorkel tube (like removing it completely) in order to get max airflow under full throttle conditions. Good luck and welcome!
PS Any 7.3 with under 100K is just barely broken in :-) You should be good to go for a long time if you take good care of it.
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, bed carpet/bench inserts, Rhino grill guard, CCV Canister Style Mod, AIS w/sleeve, Fuel filler mod, GOS headlight harness, Hella 80/100s, 02-04 Headlights, Rancho HD stabilizer, 06 Telescoping/heated mirrors with C-Btr Mirrors, Hella FF1000, Htr Bypass valve, front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV, BTS Tranny, 26 row tranny cooler, Bilstein shocks, Amsoil bypass oil filter, Donaldson ELF7405 oil filter, billet thermostat housing.
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DTRS and BPP kill switches, DIY "pitstop" switch.
http://community.webshots.com/user/l...host=community
losfinch is offline   Reply With Quote
Old 01-06-2013, 10:30 PM   #22 (permalink)
WVO works good on my 90 F250 with the golden fuel system but not sure how well it works on your truck which is newer. I would only recommend doing it if you have an easy and reliable source for oil like knowing someone who owns a restaurant that goes through a lot of oil. The Golden Fuel System is great and they are very helpful with install/trouble shooting advice but their video is outdated in terms of how easy it is to get oil. It used to be easy when restaurants needed to pay to get rid of it. Now people are paying the restaurants so they can use the oil to make biodiesel and sell it. It is great not to have to pay for fuel but it is a lot of work to put the system on/ keep finding free cooking oil and trouble shoot when something goes wrong.
Chris90F250Diesel4x4 is offline   Reply With Quote
Old 01-27-2013, 01:51 PM   #23 (permalink)
toyomatt84's Avatar
Well, I took delivery on a Diamond Eye 4" turbo back stainless exhaust, Ford AIS intake, CCV mod, and the DieselSite coolant filter. I also got the truck's little amount of rust replaced and painted.
I also through a Sony XAV-64BT in for a headunit and 4x Alpine speakers to make the stereo sound a little better. I'll probably throw a small sub in to round out the audio, though.
Next on the list of to-do's will probably be the Line-X and re-working all of the wiring that's in the engine bay and in the cab (there's a little bit of a wiring mess from the previous owner). I'm thinking a neat way to group up some of the added fuses and wiring, would be to go junkyard roaming for an additional fuse box. That way, it'll look somewhat "factory" and be able to house additional fuses for future additions. All the trailer wiring will probably go through it, as well. Something else I'm going to probably invest in, will be a back-up siren. I was backing out of a parking spot in town the other night, when some drunk people came out of nowhere and blithely walked behind the truck. Good thing I've got good reactions, and I stopped before hitting them. I did put a Broadway 400mm rear-view mirror on, as well. That helps a ton with the blind spots.
*free hugs*
Old 01-31-2013, 05:08 AM   #24 (permalink)
silvermullet's Avatar
tuneing is the way
to get all that metal down the road , and enjoy every minute of it . we havn't used the stock tune , ever since the introduction to the deisel aftermarket tuneing . thats all we got our truck for too , was to haul the car . its been my daily , since we got it . this site hooked us up with the answers to make it work best . couldnt imagine , wouldnt try , doing anything to truck without it . someday we mite even have a turbo diesel chevelle , if it was up to the kid , it would already be in fabrication . congrats , on your find . looks like a real jewel .
2000 F250 PSD 7.3 CCLB A/T wrecked by red light runner 2/16/13 & still not fixed ... but its looking like the good hands are gona give it a shot . still cant believe there putting a new frame under it . it looks like a bomb went off in that body shop . theres truck pieces parts everywhere . . .
silvermullet is offline   Reply With Quote
