SES indicator questions? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 03-24-2008, 11:26 AM   #1 (permalink)
ajohansson's Avatar
I recently did the ITP reg retrun with fuel bowl delete as part of a major upgrade to my veggie system. I left the plug for the bowl heater sitting in the valley. At the same time I plugged the AIH and now have the code for the MAT Sensor Fault (1118), AIH fault (0541) and I am getting the SES light. I expected the AIH fault and possibly the MAT fault. Do these normally set the SES indicator? I thought they just gave the code. The only other code I have is the 0603 but I have a programmer so that makes sense. Where is the temp taken at? I assumed it was taken right at the heater. Did I forge to plug something back in? Is this a normal reading after the AIH delete? Thanks.
ajohansson is offline
