Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Your caps lock is killing me!!! Anyways, First, get the 10K mod squared away. Then, grind a 4-40 Socket Head Cap screw down. (available at any fine hardware store) untill the head is about .070" tall. You will need calipers for this. I went to .085" on mine, which is good for about 72 PSI. Then you need to remove the puel regulator housing which is located on the fuel bowl, and outlets toward the driver side of the truck. You may need to pull the powerstroke plastic cover off to see it. It is held on with Torx head screws. Your to do list on your sig looks pretty incredible. I wonder how your nitrous is going to work? [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
all the socket head screw does is increase the spring rate, thus the fuel pressure. i bought the shim kit from diesel innovations that comes with a bunch of different thickness shims.
2010 350 Lariat CC SB 6.4 loaded... Truxx leveling kit with an Icon adjustable trackbar, 20X10 XD Monsters with BFG 285X65X20 AT KO's, S&B intake, H&S Blackmaxx with DPF/Cat delete and MBRP Cool Duals. Sound by Ford DVD/Nav/Sync, Audio Control, JL Audio, and Focal.
SOLD:
'02 Lariat CC SB Edge hanger leveling kit, 16X10 M/T Classic lock wheels, 315/75/16 BFG AT KO's, DPPI duals, 4 gauge pod with autometer C2's, AFE Stage II intake, wicked wheel, ATS housing, Banks Big Head, complete Dieselsite boot kit, BTS valve body, DP-Tuner F-5 chip, ITP boost regulator, ITP regulated return kit, KCM HPX line, Supercrewzer Badges. Sound by: Alpine, MB Quart, Image Dynamics, and Audio Control
The screw is the poor mans shim kit . you probably have one in your tool box, An old post last year said to use a BB, but that runs the pressure on my truck to about 100PSI.I used a screw head about 3/4 of the BB height and made one or two adjustments to it(filing the screw off) to get it to the desired pressure . Also when installing the shim put a little grease on the spring end to help holdit while assembling.
New Misstress:'05 F250 6.0 w/ 36,000 miles all stock.
Sold w/351k miles: '01 Dodge 3500 Edge Comp Drag Box
SOLD with 201k Miles: '99 F-250SD, 2WD,7.3L,JODY TIPTON 80HP PMT1 PERFORMANCE CPU,FUEL REG.SHIM set at 78# .
Buy the kit from Diesel Innovations. I wouldn't mess around with shims (screws) that are going to rust out in a matter of months. I believe they also have instructions on their site.
[/ QUOTE ] You could buy a stainless 4-40 screw like I did, I bought 3 of them and ground them to different thickness' but the first one i put in was .065 thick and it gave me exactly 70psi so I left it alone after that. The three screws cost me less than a buck at my local hardware store. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2001 F-250 CC shortbed 4x4 3.73 Ls,MBRP 4" 409 SS, AFE stage 1,Garrett GTP38R,DI's regulated fuel return,Dieselsites' 203* thermostat and Billet housing,AC heater bypass kit,CCV Mod,Fumoto drain valve. AIH delete, Zoodad,Autometer Ultra lite boost, trans, and pyro,<font color="red"> Jody Tipton 120hp tune,</font> Sonnax kit,air pressure regulator in MAP line set at 22psi.1987 Mustang LX 466 cui big block 621 hp 9" rearend spooled and disk brakes,etc....$$$$$$
