Should I Chip it? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 12-25-2012, 07:19 PM   #1 (permalink)
Jwyow865's Avatar
Should I Chip it?
I have a 2000 7.3 and it is all factory except 4 inch from turbo back. I really want to step up the performace. So obvious choice is a chip ive been looking at a ts performance 6 position chip.
wanting opinions on if these hurt engine longevity. engine already has 245k on it. and honestly just wanting some black smoke. my idi smoked like crazy. just wanting to hear of other 7.3 owners experience. heard lots of 6.0 horror stories know all about that any advice welcomed
Jwyow865 is offline   Reply With Quote
Old 12-25-2012, 08:09 PM   #2 (permalink)
chuckster57's Avatar
Welcome to the Diesel Stop.
Your going to get lots of different opinions from lots of different members running lots of different tunes. In my opinion Like anything else, proper use and respect shouldn't have a noticeable reduction in the lifespan of your engine. Make sure you include gauges in your budget, so you can monitor things.
Sent from my iPhone using AutoGuide.com App
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline   Reply With Quote
Old 12-26-2012, 12:58 PM   #3 (permalink)
Feedback Score: 3 reviews
X2...you must use guages..Custom tunes will be better than std TS tunes. If a Auto a chip may just take it out with 245k miles on it..
IF I can help please PM or email me.
Cary
Cary
caryt is offline   Reply With Quote
Old 12-26-2012, 06:36 PM   #4 (permalink)
Justin@DP-Tuner's Avatar
Good tunes will help you out tremendously. I would also recommend adding gauges when you install a chip.
We can get you setup with a chip and some tunes if you would like.
DP-Tuner
For Your Tuning Needs
www.dp-tuner.com
Like us on Facebook!
828-221-0076
justin@dp-tuner.com
Justin@DP-Tuner is offline   Reply With Quote
Old 12-27-2012, 07:55 AM   #5 (permalink)
Jwyow865's Avatar
Thanks guys trans is a reman from ford with 35k on it. I have trans temp boost gauges and want to add egt but worried about drilling into manifold. The thought of shavings in the turbo makes me cringe
Old 12-27-2012, 08:11 AM   #6 (permalink)
RT
RT's Avatar
Don't worry about that - there are several different techniques to greatly minimize or eliminate that. I used a vacuum cleaner next to my drill bit. When I got through, I used a magnet in the hole and tapped all around - nothing made it into the hole using the vacuum. Plus, think how many hundreds of thousands of us that have done this and had no problems.
I am sure the custom tunes from Caryt are great - all of his products are. I don't have any personal experience with them, but I do with the DP-Tuner. That is the best thing I have ever done to my truck. You will absolutely hate yourself for waiting this long to do it.
"IF YOU CAN'T FIX IT WITH A HAMMER, YOU’VE GOT AN ELECTRICAL PROBLEM"
RT is offline   Reply With Quote
Old 12-27-2012, 12:03 PM   #7 (permalink)
There really is no need to worry about metal shavings. Most, if not all, will come falling down on you while drilling.
Just do not put the EGT probe in the downpipe like some people do. The temperatures there are about 300* cooler than your manifold/cylinder temperature.
DP-Tuner
www.dp-tuner.com
828-221-0076
justin@dp-tuner.com
Old 12-27-2012, 12:21 PM   #8 (permalink)
Jwyow865's Avatar
Ok that was the next question lol if I could be in the down pipe with the probe
And also what is so different in the standard tunes on the ts versus a custom tunes if its made for the 7.3 how much more custom can it get just a question not real familiar with the tunes
Sent from my SCH-R950 using AutoGuide.Com Free App
Old 12-27-2012, 01:09 PM   #9 (permalink)
RT
RT's Avatar
The tunes are custom written to your upgrades, transmission, driving needs, etc.
Old 01-03-2013, 10:42 PM   #10 (permalink)
You can drill while the truck is running and all the metal shavings will be blown out (and onto you, so where safety glasses) as you're drilling. Not that big of a deal really.
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, bed carpet/bench inserts, Rhino grill guard, CCV Canister Style Mod, AIS w/sleeve, Fuel filler mod, GOS headlight harness, Hella 80/100s, 02-04 Headlights, Rancho HD stabilizer, 06 Telescoping/heated mirrors with C-Btr Mirrors, Hella FF1000, Htr Bypass valve, front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV, BTS Tranny, 26 row tranny cooler, Bilstein shocks, Amsoil bypass oil filter, Donaldson ELF7405 oil filter, billet thermostat housing.
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DTRS and BPP kill switches, DIY "pitstop" switch.
http://community.webshots.com/user/l...host=community
losfinch is offline   Reply With Quote
Old 01-05-2013, 10:32 AM   #11 (permalink)
Get gauges. Dp- tunner is good. I have on. It wakes the truck up.
2000 F250 crew cab long box
Banks exhaust, bighead, trancommand, boost gauge trans temp, pyrometer(post turbo)
Dp-Tuner 60& 80econ 60& 80 tow
Strictly diesel overboost annihilator
jobeperformance intake
dieselsite 203 t stat, coolant filter, evans coolant
38r with bank-bighead installed, diesel site non ebv flange international up-pipes coated, diesel site engine boot-kit, non-ebv pedestal
strictly diesel regulated fuel return kit 65psi.
new fuel bowl
CMF+ intake
isspro ev2 pyrometer(pre turbo), fuel pressure, coolant temp, HPOP gauge Matt
Matthew Harris is offline   Reply With Quote
Old 01-05-2013, 11:06 AM   #12 (permalink)
Mark Kovalsky's Avatar
My opinion, backed by 29 years of automotive engineering experience, is that yes, this will hurt your engine's longevity. How much it will hurt it is an open question. That depends on many factors. One of the most important factors is how you drive it.
Mark
Mark Kovalsky is offline   Reply With Quote
Old 01-06-2013, 11:38 AM   #13 (permalink)
Well my old '95 has now got 280k miles on it, chiped day one 45k miles pulling a 35' 5th wheel then had stage 2's for about 100k miles...now stage 1's for the new owner last 40k. Getting 18-19 hy 16 town.
Cary
Old 01-07-2013, 04:47 PM   #14 (permalink)
My Photos: (5)
I would chip it. But, if you drive it like a hot rod, then I imagine you will shorten the life. I was hesitant to chip mine and waited until after the warranty was done. I think that was at about 65k miles or so. I drive mine like a grandpa and then zip around in my old BMW.
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, scangauge, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, PHP 50t and 80p, currently 100,500 miles. truck Pictures
clydesdale is offline   Reply With Quote
Old 01-14-2013, 09:26 AM   #15 (permalink)
Jwyow865's Avatar
Ended up going with a 6 position ts switch but how do I get custom tunes on the chip
