Stack on outside of bed? - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 01-14-2010, 12:36 PM Thread Starter
Ky_0686's Avatar
I tried posting this under general aftermarket but no replies so far. Have any of you tried or know someone who has tried to put the stack on the outside of the bed near the cab corner? I found this photo on google and was wondering why 99% of stacks are in the bed. Anybody have any photos or experience with this? BTW, this truck is huge, CC, Sleeper, long bed, dually
Google Image Result for http://img1.classistatic.com/cps/po/091115/822r4/6295b60_27.jpeg
2002 F-250 CC LB 4x4 7.3L 183k mi
Pace Edwards Roll Top Cover
2-12" 500W Pioneer Subs w/ 760W Amp
Muffler is Gone!
DIY 6637 Air Intake
Hutch and Harpoon mods
1990 VW Jetta 1.6L NA 5sp 224k mi
Beater with a heater commuter car
Slower than hell, but cheap on fuel.
Ky_0686 is offline
post #2 of 12 (permalink) Old 01-14-2010, 12:57 PM
honeydew's Avatar
Seems like it would look odd without that sleeper cab to break up the lines of the truck. Should be an easy to install though. My exhaust guy has stacks like that on both his shop trucks (gassers).
Hope it looks better than this guy's outside stacks.
2001 F250 4X4 CC Lariat,
; modifications: Ford AIS w/ cool_canuck mod & fender sleeve, 4" turbo-back, mechanical wastegate controller set to 24 psi, dp tuner F5 (60e, 80e, 1200 idle, 120r) all with codes option, trans temp, EGT and boost gauges, max cold valve, dieselsite boots and oil crossover line, 203 t-stat, coolant filter, Riffraff FrX, ITP hutch setup & pre-pump filter, Warn premium hublocks, Red-Head steering gear box, Scangauge II, LED glowplug indicator light.
removed: charge pipe foil, Air Intake Heater (AIH), engine cover & bracket
honeydew is offline
post #3 of 12 (permalink) Old 01-14-2010, 01:01 PM
aekrogh's Avatar
if you want to put the stack on the out side of the bed, you have to go down and under the frame rail. It requires more bends and more plumbing. It also is a catch point, like in a car wash or brush or parking bollard and it lowers your ground clearance at the point the pipe goes under the frame rail. It can be done and I have seen it on a couple of flat bed trucks. good luck and hope it works for you.
I do understand why you want to go outside the box, with your role top it would make it a challenge. I am pretty happy with my exhaust exiting our the passenger side rear corner....right into the widow of my favorite rice rocket.....but that is another story.
Late 99 SD PS CC SB 4x4 Lariat. 7.3l TS 6xchip Stock-140hp , Banks 6gun, Full Banks Gauges, 4"SS turbo back exhaust, UMP Intake w/ Donaldson Filter, Auburn posi F&R 3.73, ATS Trans W/ 5Star converter and CoPilot, 18k trans cooler, Dynatrac FreeSpin front hub kit, ITP oil X over, ITP boost regulator, Aero Fuel Tanks Replacement 55 Gallon tank, New timing cover,oil pan,oil cooler, water pump,turbo petastel, reman HPOP, new fuel filter housing, slotted brakes all 4 corners W/ Ceramic pads, Adjustable trac-bar, Front 1.5" level kit only. 226,000 miles 10/1/09 Best mpg 27.3..Norm city 15 mpg hwy 20+
Early 99 CC LB 2WD Manual 6....Stock 228k (11/09) and running strong, only repairs Clutch, water pump, alternator. K&N FIPK since 36k and loving it!
2006 CC LB 4WD Lariat 6.0l 5R110 Stock 178k (12/09) "Dad's" 3 injectors and GP harness(12/09) Dynatrac Ball Joints, New ERG and 2 injectors (6/10)
aekrogh is offline
post #4 of 12 (permalink) Old 01-14-2010, 01:06 PM
aekrogh's Avatar
the expensive way of going outside the box
aekrogh is offline
post #5 of 12 (permalink) Old 01-14-2010, 02:23 PM Thread Starter
Ky_0686's Avatar
honeydew: I read on another forum where someone said that mustang looked like the love child of a mustang and a peterbuilt, what with the mirrors and horns.
aekrogh: I didn't think about the necessary bends under the frame rail. I don't usually do anything where I need lots of clearance, but it would be my luck that I'd tag something with it and rip it off. I saw that Dodge earlier too. I think that it looks really good. I know nothing about body work except from shows like Trucks! and I can only imagine the time and effort, but its definitely unique.
Well who knows what I'll do, I might just but a 4" MBRP turbo back on it and keep the wife and neighborhood happy. Or at least slighty more happy than stacked. Thanks guys!
Muffler is Gone!
DIY 6637 Air Intake
Ky_0686 is offline
post #6 of 12 (permalink) Old 01-14-2010, 02:33 PM
fordsforever73's Avatar
My Photos: (24)
Feedback Score: 2 reviews
That Mustang looks like a "Smokey and The Bandit" wanna be.
2005 F-350 CC, LB, 4x4, Dually, 6.0 Powerstroke, Torqueshift, 4:10 Gears. Gooseneck and rear pull hitches. "Truck Covers USA" roll up aluminum tonneau cover. Putco Boss Running Boards. Aluminum finned diff covers. Bilstein HD shocks. ProComp steering stabilizer. XRF ball joints. NC Hornet CCV mod. RCD egr delete kit. AirDog fuel system. Strictly Diesel's regulated fuel and coolant return lines kits. Amsoil oil bypass (by NUC Motorsports) and homebuilt coolant bypass kits. CFM intake elbow. ARP head studs with factory gaskets and all upgrades. FICM by Ed with Atlas 40 tune, DC Power 185 amp alternator, MBRP 304SS "Cool Dual" exhaust system. SCT Livewire tuner with pyrometer. Autometer 'A' pillar gauges (Boost/Trans temp/Pyrometer/Fuel Pressure). 850 CCA Motorcraft Batteries. Using Rotella T-6 synthetic oil. Upgraded degas tank and cap. Hayes deep aluminum trans pan. GoGo Diesel modified direct clutch solenoid. Retro Solutions HID head and fog lights. High idle mod. Jimmi-Jammers. +More.
fordsforever73 is offline
post #7 of 12 (permalink) Old 01-15-2010, 01:45 PM Thread Starter
Ky_0686's Avatar
I found this photo of a truck at Bandimere, apparently they required all of the vehicles there to have some kind of stack because the soot was getting some signs dirty, it's temporary and at the rear of the truck so it doesn't really give the same impression.
Google Image Result for http://image.dieselpowermag.com/f/events/0911dp_diesels_on_the_mountain/30950418+w200/0911dp_07+diesels_on_the_mountain+exhaust_turn_up_ pipes.jpg
And this kid doesn't seem like the diesel type, flip flops and plaid shorts? maybe I'm old fashioned but somebody should take his cummins away
Muffler is Gone!
DIY 6637 Air Intake
Ky_0686 is offline
post #8 of 12 (permalink) Old 01-15-2010, 01:51 PM Thread Starter
Ky_0686's Avatar
Honeydew, can you get a couple of photos of your exhaust guys shop trucks? If its not too much of a problem. I am trying to decide if I kept the pipe size smaller 4-5" and then maybe threw on a set of fender flairs if it wouldn't look quite so sore thumbed. I sure can't find any other pics on the net unless their ridiculous like that 'stang or worse. I really wish I had photoshop.
Muffler is Gone!
DIY 6637 Air Intake
Ky_0686 is offline
post #9 of 12 (permalink) Old 01-15-2010, 02:25 PM
honeydew's Avatar
Sure, I should be driving by his shop over the weekend.
honeydew is offline
post #10 of 12 (permalink) Old 01-16-2010, 04:11 PM Thread Starter
Ky_0686's Avatar
hey thanks, I really appreciate it. Thats why I really like these forums, everybody helpin each other out!
Muffler is Gone!
DIY 6637 Air Intake
Ky_0686 is offline
post #11 of 12 (permalink) Old 01-17-2010, 05:18 PM
honeydew's Avatar
Neither truck was there this weekend and the shop looked like it might not be operational...
I'll check again sometime this week during business hours.
honeydew is offline
post #12 of 12 (permalink) Old 01-18-2010, 08:19 AM Thread Starter
Ky_0686's Avatar
well, thats the way things can be during this wonderful economic period. Thanks though, I really appreciate it!
Muffler is Gone!
DIY 6637 Air Intake
Ky_0686 is offline
