stacking chips - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 11-26-2008, 07:36 AM   #1 (permalink)
stacking chips
Have an 2003 F350 7.3 has any one ever stacked chips if so witch ones. Good or bad idea?
cufd412 is offline
Old 11-26-2008, 12:15 PM   #2 (permalink)
You can not stack chips, there is only one location to put a chip. You can not stack a chip on top of a tuner because the chip will make the tune null and void. You can stack a plug in module like a banks 6 gun/edge juice/edge ez/preditor/etc... but the gain +/-10hp is not worth the cost. Just get a chip from DI, DP Tuner or TW and be done with it.
Some will argue, others will agree, few have done it and learned the hard way.
My Truck: Early '99 F350 CC LWB 4X4
Annoy A Liberal
Work Hard, Succeed, Live Happy!
Family of 5 saved by Grace.....
strokin_early_99 is offline
Old 11-26-2008, 06:56 PM   #3 (permalink)
Just to elaborate a little bit on what strokin_early_99 said......
"Stacking" power adders on a Powerstroke usually yields less than stellar results because everything that is done with fuel modules (like the Edge Juice or Banks 6 Gun) is usually incorporated into the programming on a "chip" or a flash programmer (like the Superchips 1705 or Hypertech).
It is not possible to "stack" a programmer with a "chip". The operation of a chip and how it completely bypasses the PCMs internal memory negates any effect of aftermarket flash tuner operation.
You CAN use a fuel module (ICP fooler) in conjunction with a chip or a programmer, but as stated above, it's not really going to do much for you....especially with a Wildman/DI/DP Tuner chip that already incorporates higher than stock injection control pressure (ICP). Too much desired ICP (and not being able to maintain it) will result in default pressures and a check engine light.
However, there are companies such as Edge that capitalize on "stacking". Take the Juice/Evolution combination. They sell you two products to do the same thing that they COULD HAVE DONE with just the Evolution. Instead, they use the Juice to jack up injection pressure and the Evolution to change shift characteristics and fuel control....all of which could have been done with just the programmer. So instead of making $450 on a programmer only, they make $750 or so on two pieces of equipment.
The Juice (or 6 Gun/Striker/etc.) DO do what they claim...they give you a nice little HP increase...but in the end, a custom chip can do much more for not a lot more money!!
Cody
cleatus12r is offline
Old 11-26-2008, 07:05 PM   #4 (permalink)
diesel_brad's Avatar
I wouldn't be doin too much to your 03 w the pmr's in there unless you have a spare engine lieing around
86 F250 6.9 4spd 4x4 6"+315s's(coming soon POWERSTROKE,D60&zf5 )
00F350 Xcab Dually 7.3.ZF6, 4x4 SOLD
94 Lightning, Full Bassani exhaust,underdrive pullys, CAI, new paint w/ stripes
96F350, 4dr, 460, ZF5, 6"lift, 35"thornbirds, banks torque tubes, 3"custom bent exhaust, bbk throttle body, stull grill, clear front turnsignals, lund visor, 3.55gears
1980 F350 PULLIN TRUCK, 429, C6, detroit lockers f&r 10.25/D60 33' BFG muds
diesel_brad is offline
Old 11-26-2008, 08:06 PM   #5 (permalink)
PStroked444's Avatar
Just get a DP, TW or another good name and be done with it. I recomend DP. JMHO
99.5PSD, F250, 4x4, wht. CC, SB, Line-X, 200K+ , 6spd,LUK Ceramic Clutch, Warn Premium hubs, DP Tuner F5 stock/high idle/40T/60T/80E/100hp, Casserly STG1 sticks, DIY TYMAR, No EBPV, 08 Diff Cover, 4"MBRP S/S, Banks wheel*traded for stock wheel*, ATS Housing, HXLine, Zoodad Mod, CCV Mod, AIH removed, Shimmed fuel, Isspro Boost Guage & Pyro Guage, 2" Level Kit, Firestone Air Support Springs, BFG AT k/o, CB Galaxy DX949, DUAL Antennas, Lead Foot came stock
1998-F150 4x4, LB, K&N, No Kitty, 24LB inj, CB...Wifes ride.
94 Mustang GT, Red, Black Saleen rims, T-5, intake, exhaust, cam, 24LB squirts, tuned, last of the 302...
PStroked444 is offline
Old 11-28-2008, 10:45 AM   #6 (permalink)
what is wrong with the 2003 7.3 engines? The motor is stamped 2002.
cufd412 is offline
Old 11-28-2008, 10:56 AM   #7 (permalink)
Guys thanks for the info. I'm looking at doing a little not a lot. I have a landscaping business and pull a trailer weighing about 6500 lbs. about every day and trying to get the most mileage out of it. I have an Edge Evolution that I got from a friend for $50.00. I have a DIY intake and 4" exhaust turbo back with a Jibson muffler. I thought about selling the Edge and getting a TW or TS chip. Any pros or cons for eather one. Again thanks
cufd412 is offline
Old 11-28-2008, 12:01 PM   #8 (permalink)
I have a TS I bought on Ebay for $250. It came with these settings: stock, high idle, 50, 75, 100, and 140. They say thats what the horsepower ratings are but it's impossible from just a chip. It definetly woke it up, and makes it shift better. I know a guy that custom burns the TS chips and for $50 he reset my settings im just telling you what the positions are idk the hp ratings now : stock, 50, 75 lopes a little, 100 kicks OD up to 55mph, 140 same but lopes like crazy it shakes the whole truck it is awesome. People don't think much about Powerstrokes but when you pull up to the sled it sure sounds like you have one hell pf a truck. lol I'm happy with it my truck has 220,000mi on it and the tranny didn't like it cuz I hot rodded on 140hp to much, but if you are easy on it you will like it. All I have done is a cold air intake, custom TS, and 3.5" straight pipe from turbo back and I get 25psi out of the turbo now.
97 Stroker
ehrminator is offline
Old 11-28-2008, 01:45 PM   #9 (permalink)
Anyone that runs a chip on the top tune without gauges needs the grey matter between their ears examined .......That is a big
A 97 with a 3.5" turbo back?.......................3" is a PITA but a 3.5" is another story
Annoy A Liberal
Old 11-29-2008, 04:19 PM   #10 (permalink)
Nothing wrong with the motor except PMR's or powdered metal rods. They are the biggest weak link in the late 7.3's. Most people say to stay under 400 rwhp with PMR's. or you might be adding a "window" to the block. But some will argue and I have seen pmr's let go in a completely stock motor.
Get gauges and a DP-tuner or Diesel Innovations custom chip. That would be your best bet.
2001 F350 CC LB 4x4. GDS Ballbuster turbo, AFE Stage II intake, Banks Intercooler, Suncoast TC, MBRP stainless 4", DI 4 position chip(needs reburn), Autometer gauges, zoodad mod, HX oil line, blow-off valve, DR 4.5" lift, 35" bfg mud terrains.(R.I.P)
332hp and 785tq - 4/1/2006 at Performance Diesel (w/o Banks ic and AFE stage II intake)
2007 Dodge 2500 CC SB 4x4 5.9L picked up (5/01/07)
5" stainless magnaflow, cfm+, quad boost fooler, smarty SR, Silver 62, DTT Billet 48re, AD 165, Spearco CAC, KORE race suspension, 35" terra graps on 18" XD HOSS.
tx_silverstroke is offline
Old 12-01-2008, 04:18 PM   #11 (permalink)
I've got guages DiPricol boost, EGT, Trans. I will look into getting a DP chip.
Thanks a lot for the info. I will keep it on the low HP settings if that might happen to the motor.
cufd412 is offline
