STACK'S or STRAIGHT PIPE? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 02-16-2010, 09:34 PM   #1 (permalink)
i curently have a custom built 5inch turbo back system but all my buddies are telling me to go with stacks. i am wanting to know if there is any performance difference or is it just looks?
1999 f-250 4door 4x4
hypertech 3 stage power programer
wide open performance stage 2 injectors
4inch lift with muddking steel radials
wide open performance quick spool turbo
charles1990 is offline
Old 02-16-2010, 10:19 PM   #2 (permalink)
honeydew's Avatar
Its just for looks. My buddies tell me that my truck "needs" a leveling kit. It doesn't.
2001 F250 4X4 CC Lariat, fuelly; modifications: Ford AIS w/ cool_canuck mod & fender sleeve, 4" turbo-back, mechanical wastegate controller set to 24 psi, dp tuner F5 (60e, 80e, 1200 idle, 120r) all with codes option, trans temp, EGT and boost gauges, max cold valve, dieselsite boots and oil crossover line, 203 t-stat, coolant filter, Riffraff FrX, ITP hutch setup & pre-pump filter, Warn premium hublocks, Red-Head steering gear box, Scangauge II, LED glowplug indicator light.
removed: charge pipe foil, Air Intake Heater (AIH), engine cover & bracket
honeydew is offline
Old 02-16-2010, 10:52 PM   #3 (permalink)
My Photos: (19)
I' wouldn't mind having stacks on my truck. Problem is the only way that'll ever happen is if I cut and lengthen the frame by about 8" so I can bring them up between the cab and the bed. That'll never happen.
If you are one of those people who just build something cause everyone else thinks it'll look good, then I guess go for it. Me personally, I build it to be what I want it to be. Stacks sound a little different, definitely look different, but what you want and what other people think.... that's your decision. Or, maybe it's their's....
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline
Old 02-17-2010, 10:54 AM   #4 (permalink)
pwrstrkd's Avatar
Stacks or straight pipe?
Do what you personally want. Stacks are cool and all but what you have works fine. Your not going to get any power gains out of stacks that are better than you have now. Straight pipe sound great too.
pwrstrkd is offline
Old 02-17-2010, 08:13 PM   #5 (permalink)
Stacks look good on some trucks bad on others, its really all personal preference
Smalls is offline
Old 02-18-2010, 12:34 AM   #6 (permalink)
Send a message via Yahoo to escs36
i can appreciate stacks, just not on any of my trucks.
Early Bird Super Duty 230,000 miles, Swamps 200/30%, Beans D66, Adrenaline HPOP, ITP Regulated Return, John Wood Stage 1, DP Tuning, IDM Mod, Diesel Innovations Intercooler, 4" Turbo Back w/MBRP muffler, etc...
escs36 is offline
Old 02-18-2010, 06:55 PM   #7 (permalink)
thanks for the input i think i am going to do a single off set stack i think those look good and i belive in the old sayin (2 for show 1 means business) even though it took me forever to fab up my custom 5" turbo back masterpice
Old 02-21-2010, 06:47 PM   #8 (permalink)
buckmeister2's Avatar
your "buddies" want you to spend money and try things out so they can see how it looks, then decide if they should do it....
Early '99 F250 XLT 7.3 ext cab, SB, 4x4, auto tranny, 153K miles, completely stock. Installed GlowS**t gauges (never again!) and DIY air filter, Tru Kool trans cooler, 4" exhaust, 50 HP chip. Tows 10K 5th wheel.
buckmeister2 is offline
Old 02-23-2010, 08:45 AM   #9 (permalink)
dont have stacks on my truck but I think they are cool as hell but i heard they cause a really bad in-cab drone just something to think about
2002 F250 Super Duty 7.3l Powerstroke Diesel 4x4
AIS Severe Duty Intake
Strait Piped 3.5"
33" Wrangler MTR's
Firestone Air Bags
Glo Shift air pressure,fuel pressure, and boost gauges
and finally after almost a year of owning this little pearl thanks to a member on the site im finally going to have a center seat and console and believe me when you haven't had one that long thats better than gettin programmer I would know cause I traded a programmer for it lol
dieseladdikt is offline
Old 02-27-2010, 10:18 PM   #10 (permalink)
okiethunderlion's Avatar
I am with SMALLS stacks look good on some trucks but not on others.
okiethunderlion is offline
