Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 7.3L Engine
Upgrades and Aftermarket - 7.3L Engine Upgrading and adding aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 11-04-2009, 05:34 PM   #1 (permalink)
still getting CEL after installing boost relief valve
i am still getting a CEL after installing a boost relief valve. i started to get the light after installing the Edge J/A. i am guessing a weak HPOP, but was looking for some advice
02 white CC LB SRW 7.3. Edge J/A, AFE Stage II, 4" straight exhaust, WW, TM wastegate, billet TC, TransGo Tugger II, 203 therm, AIH delete, HX mod, engine boot kit, ZooDad, 2.5" front shackle, 2.5" front springs, SS brakelines, 5" rear block, rear airbags, ProComp traction bars, 37 12.5R17 ProComp X AT's on 17x9 ProComp 7089, painted door handles, billet grille, DEH-P650 Pioneer head unit, 400watt amp, 10" sub, 08 mirrors.
pictures
harmonjustin is offline
Old 11-04-2009, 09:47 PM   #2 (permalink)
woodnthings8's Avatar
Is the light staying on or does it go out after a few minutes? What code are you getting? If you are getting P1211 that means the ICP pressure was less than desired for a set amount of time, usually a few seconds. Is the light coming on at about 24-25 psi of boost?
2002 F-350 CCLB 4X4, HD4R100 , 4" Diamond Eye exhaust, Powerslot rotors, DP Tuner-F6, Autoenginuity, KCM S.S. HPX Line, S&B Filters intake, Autometer gauge pod, Inovations canopy,Banks Big Head wastegate actuator, 6.0L Trans Cooler, Zoo-dad, Dieselsite Coolant Filter, DVD and always looking to do more....
woodnthings8 is offline
Old 11-05-2009, 02:35 AM   #3 (permalink)
i haven't pulled the codes. it will come on when i have boost as low as 9 psi. the ligt stays on for a couple of minutes then it will go out.
pictures
Old 11-05-2009, 08:30 AM   #4 (permalink)
That doesn't sound right, you will have to pull the codes to see what it is giving you. Could be a oil issue, but need a code to verify what is going on.
Old 11-05-2009, 11:05 PM   #5 (permalink)
My Photos: (10)
Mine does that too. I don't have the boost fooler or anything, but it'll do it with less than 15psi. I just installed a HPOP pressure gauge and that thing will stay low for a long time and then I get the light. It'll stay on for a while and then go off. That's probably what's happening. Your tune is firing your injectors faster than what the stock HPOP can handle. I guess you could do one of three things. 1. just drive it and don't worry about it (mine's been that way for a couple of years now). 2. get a new tune that will fix the issue. 3. Get a better than stock HPOP and never look back!
Like I said, mine's been doing it for close to two years now and it hasn't seemed to hurt anything. I would like to get an Adrenaline HPOP but I just don't have the money right now.
'02 F-350 "Babe The Big Blue Truck" 4x4, Ext. Cab, 8' bed
DP-Tuner 80T, ATS Compressor housing, DIY intake, openair CCV, 80HP 'pane shot, SBC DD all ceramic clutch, ISSPRO boost/pyro gauges, 4" lift, 255/70R22.5 tires, brake linelock, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, and who knows what else... oh and a Kennesaw Mountain front bumper (now tried and true)
'66 Bronco "Big Little Monster" - 5.0L EFI, AOD, D20, 3.5" WH sus. lift, 3" body lift, 35" BFG muds, Stock Dana 30 front with Lock-Rite, disk brakes, Warn Hubs, Stock Ford 9" rear with mini spool
BTBBT is offline
