Stock Intercooler with plastic end tanks? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 05-04-2006, 10:16 PM   #1 (permalink)
when, if at all did ford make the switch from the all aluminum end tanks to the plastic tanks on the intercooler.
i was looking at stuff on blackclouddiesel.com and happened to notice the 7.3 to banks 6.0 intercooler and it showed a stock intercooler next to it, which happened to have plastic end tanks just like the radiator does.
just for S&G's i looked at mine today while i was replacing the mount for the fuel filter cover (didn't take it off and broke it while doing my ats housing) and noticed that mine has nice big aluminum end tanks welded to the core. should i investigate further to see if the former owner changed the intercooler to an aftermarket one, or did ford make a production change.
1999.5 (5/99) F-350 SC, LB, ZF-6, 4X4: ATS Compressor Housing, BBH, K&N FIPK & Drycharger, DP Tunes 60T, Isspro Pyro & Boost, 4" MBRP & Delete Pipe, AD's (for now) ITP HPX, OBA & Reg Return, AIH Delete, Oil Guard, Couple Dongles
Oil Pan @ 133,000
PSN rocks my world [img]/forums/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
ITowBoats is offline
Old 05-04-2006, 10:19 PM   #2 (permalink)
Re: Stock Intercooler with plastic end tanks?
The 6.0 has plastic ends but the 7.3 is all Aluminum.
2001 F250 Lariat, -SOLD-
460/950 Corrected Prior To Water Injection and Spearco IC.
13.974 @ 95.65mph
2008 Cummins Truck Fest 4WD Diesel Champion
'07 Duramax Classic, Leather, Sunroof, Bone Stock.
DZacc is offline
Old 05-04-2006, 10:20 PM   #3 (permalink)
clamgulch's Avatar
You've got the stock cooler. My early 2000 excursion has aluminum tanks too.
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
clamgulch is offline
Old 05-04-2006, 10:27 PM   #4 (permalink)
Late 2000 is when Ford switched to plastic tanks. So some very early 2001s had aluminum end tanks. The Oracles early 2001 had plastic tanks, when we installed his 6.0 CAC.
FOMOGO
2001 F-250 Lariat, Black, CC, SB, 2WD
304 hp and 627 tq on Dunbars Dyno
2001 F-250 XL standard cab, beater, hauling trash... Stock except for a 60 horse flash...
304hp and 617 tq on Dunbars Dyno
2001 F-250 Xl Standard cab, project truck...
Custom Tunes by DP-Tuner, Custom Fuel System by ITP Diesel, Custom Trans by BTS
Ford Makes It - International Shakes It
Dubco1 is offline
Old 05-04-2006, 10:28 PM   #5 (permalink)
My Photos: (22)
early super duty 7.3's had all aluminum and then switched to plastic. My 7.3 CAC that I pulled out of my 2001 has plastic tanks.
Hammer
Check out what I recently bought:
2002 Quicksilver Z06 Corvette
I still have the:
2001 F250 Lariat CC/SB 4x4 7.3 auto
TERMINATOR HPOS...Ceramic coated Garrett GTP-38R with BBHA & GDS outlet...DP-tuner Big Oil Program...ITPdiesel Fueling and overboost regulator...6.0 CAC...AFE Stage-II PG7... Magnaflow 3.5dp/4exh...5R110 TC, BTS VB, John Wood pump mods, & V10 cooler...Schaeffer's 9000 5w-40...Oilguard bypass...and other stuff
On the shelf collecting Dust: <font color="green"> Stainless Grill Overlay </font>
<font color="red"> Carolina PSD club </font>
Get Your Tuning Here: www.DP-tuner.com and your Fuel kits here: www.ITPdiesel.com
TheHammer69 is offline
Old 05-04-2006, 10:38 PM   #6 (permalink)
so is an early one with aluminum tanks better off than the plastic ones if your not going to swap to aftermarket
Oil Pan @ 133,000
Old 05-04-2006, 10:42 PM   #7 (permalink)
My Photos: (22)
I would say most likely yes.
Hammer
I still have the:
Old 05-04-2006, 10:47 PM   #8 (permalink)
My 99.5 had aluminum then when it got in its lil accident, it was replaced with the plastic end tank version. The body shop said he couldn't get the original version.
1999.5 F350 CC LB AT 4x4 Dually, Burgundy/Black, MBRP 4" Stainless exhaust, IssPro gauges, Jody Tipton 4 pos chip, BB Turbo, Big ol' hybrids, DI stainless reg return, Not Big oil but let's call it "MEDIUM" oil for now 140,000 on stock tranny b4 she puked, BTS in its place
416 HP/860 TQ
1969 SS396 Chevelle &lt;--- fave toy
http://community.webshots.com/user/pipewhiner
AllDieselMotorsports
pipewhiner is offline
Old 05-04-2006, 10:52 PM   #9 (permalink)
so i should hang onto it? just from the pictures the plastic tanks look like they're alot more restrictive than those big cast aluminum tanks on mine
Oil Pan @ 133,000
Old 05-04-2006, 11:20 PM   #10 (permalink)
Banned
My Photos: (38)
My IC def has plastic tanks.
gregrob is offline
Old 05-04-2006, 11:53 PM   #11 (permalink)
FOMOGO
How much larger was the 6.0 CAC than the original 7.3 CAC with the plastic ends? Does it help much with egt's
2003 7.3 PSD, TERMINATOR HPOS, DP LIVE TUNED, ITP Reg. Return, Spearco, DI up-pipes, PI coverter & TransGo tugger, AFE-II, 4" MBRP, Duramax fuel cooler, 20K on the clock
JMS1 is offline
Old 05-05-2006, 09:33 AM   #12 (permalink)
How big is big? My stock CAC has aluminum tanks but they aren't big IMO. In fact I would describe them as small and flat. You might have an aftermarket CAC.
444-4D is offline
Old 05-05-2006, 09:43 AM   #13 (permalink)
Really all depends on how much boost you plan on making, the plastic tanks are not good for aftermarket turbo's that are pushing 40 lbs of boost regularly.
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
