Superchip from 95 to 03? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 01-22-2006, 04:27 PM   #1 (permalink)
I'm selling my 95 7.3, can I return it to stock programing, and use the programer on my 03 7.3 or is the programer VIN locked to the 95?
Thanks guys!! I'm new to the form. I have heard lots of good things about this form.
03, F-350, 7.3L, 4x4, auto,
superchip,strait pipe exhaust, and K and N, 4 door, short box
jbsumbc is offline
Old 01-22-2006, 04:35 PM   #2 (permalink)
Re: Superchip from 95 to 03?
The Superchips DON'T VIN LOCK. You'll just have to make sure that you have a 1705 because I believe that the older 1700 programmer only goes up to 2002 [img]/ubbthreads/images/graemlins/shrug.gif[/img].
2003 GMC Sierra 2500HD Duramax/Allison 4x4 standard cab.... 12.11@113.39 #2 so far.....
004wdPSD is offline
Old 01-22-2006, 04:57 PM   #3 (permalink)
Thanks 004wdPSD! Itis the 1705 programer I have. That is great news!
jbsumbc is offline
Old 01-22-2006, 05:00 PM   #4 (permalink)
Hmmmmm. I don't buy it. When I plug my 1705 in my display reads.... "VIN LOCKED"....whats up with that?
captken01 is offline
Old 01-22-2006, 05:07 PM   #5 (permalink)
[/ QUOTE ]]
That is why I asked the question, It said VIN LOCKED when you plug it in to the 95.
jbsumbc is offline
Old 01-22-2006, 05:32 PM   #6 (permalink)
It is Vin Locked until you return the original truck back to stock, then it is unlocked to program another truck. It is designed so you can't program several trucks off one programmer.
2001 F-250 Lariat CC, 4X4, ESOF, 305-70-16 Toyo Open Country A/T, 4" Exhaust, Tymar, DP Tuner Stock/High Idle/40Tow/80Econo/120Race, BTS VB, Gauges(Pyro, Boost, and Trans. Temp), Viper 850 XV Alarm
elevatn is offline
Old 01-23-2006, 08:34 AM   #7 (permalink)
What Elevatn said! Also sell it as it is not a good programmer for a 2003. High EGT, screaming turbo and a loud noisy motor. Had one and went to a custom tune and the truck runs allot better.
2003 F250 Crew 4x4 SRW 3.73, 4" turbo back exhaust with Magaflow 6" tip, DP-Tune 80hp economy, ATS housing, Turbo Master WG controller, turbo timer, 203* stat, homemade Tymar, ZOODAD mod, ITPdiesel overboost regulator, FTVB and Oilguard Bypass.
weantright is offline
Old 01-23-2006, 08:51 AM   #8 (permalink)
anash13's Avatar
Weantright & Elevant are correct.
However, You can return your SuperChip to the factory and they can update there program's within the unit.
I think the cost was $10.00 to have mine reprogramed...most of which was for postage.
Weather there is somthing better on the market at a reasonable price I can not speak too.
But I do wish that some one who know, more on the subject, to chime in here. I am always interested in a "Better Mouse Trap".
2003, E-350, XLT, Chateau, 7-Pass. Club Wagan, 7.3L PSD, 3:55 LS Rear, DP TUNER F-5, AMSOIL TS-126 Air Filter, Fleetguard LF-9027 Bypass Oil filter, Sirius Satellite Radio, Garmin GPS, SuperCrewzer, AutoMeter (Pyro. Trans. Boost)Gauges, 4" Diamond Eye Turbo Back Exhaust, Sonnax valve & Tricululator springs, PML Alum. Tran's Oil Pan, Tru-Cool 4739 Tran's Cooler, ScanGuage Monitor, DAHL 100 Fuel Filter, "Last of the 7.3's".
USMC-(Ret).
You Can't Always Get What You Want, But If You Try Some Times You Just Might Find, YOU GET WHAT YOU NEED.
anash13 is offline
Old 01-23-2006, 09:59 PM   #9 (permalink)
What is the best tuner for the 03, 7.3, with auto? I would hate to start a new thread, I'm new on this form, and you guy's most likly have talked about this befor.
Thanks for the imput!!!
jbsumbc is offline
Old 01-24-2006, 11:17 AM   #10 (permalink)
It depends on what you are looking for. A hand held tuner with the ability to read codes will give you less performance on average. Edge products works good for most people but if you are the ones that it didn't work on then a very bad taste in your mouth for any programmer/chip. I have switch from a Super chip to a custom PCM tune from DP-Tuner. Allot better performance over the 1705 but I needed to add a ATS housing for turbo surge. I went this route for warranty issued saving my stock PCM. Also if you don't have the need to switch between hp levels then single tune is a cheap way. I personally run the DP tuner and would recommend it but there are many great tuners out there. Go for the custom tune and you will not only be safer motor wise but will have more power than most handhelds. Otherwise these same tuners have multi tune chips but at a cost.
