Superchip VIN Locked!! - Diesel Forum - TheDieselStop.com
post #1 of 21 (permalink) Old 09-03-2006, 05:45 PM Thread Starter
RPMOffroad's Avatar
Ok today i found a superchip programmer at a flea market for hardly anything so i bought it to see if it would work. plugged into my truck and it works perfect looks brand spankin new, but its VIN locked of course so i was wondering if superchips can unlock it so i can use it. Got the box (which is somewhat ruff) that it came in and the instruction book and all. thanks
2000 F-350 PSD SRW - 8" BDS Suspension, Bilsteins all around, 40/13.50R20 Procomp Xtreme A/Ts, 20x10 BMF NovaKanes, Warn bumper with 15,000lb warn winch, swamps single shot f* mes, H2E turbo, wipeout headstuds, 3.5" H2E Downpipe to 4"-5" exhaust then to some 6" BLACK mitre cuts, Boost-Pyro-Trans-Oil pressure gauges, regulated return, modded idm, DP-Tuner 6 position chip
, Yukon 4.30 gears front and rear, Homemade Traction Bars, Dieselsites billet thermostat housing with 203 degree thermostat.
RPMOffroad is offline
post #2 of 21 (permalink) Old 09-03-2006, 05:46 PM
Banned
My Photos: (38)
Re: Superchip VIN Locked!!
Maybe if you give them a sob story and beg them, but I wouldn't count on it.
gregrob is offline
post #3 of 21 (permalink) Old 09-03-2006, 06:21 PM
I agree its like telling microsoft you bought a Windows CD on E-Bay but it didn't come with a key.
2011 F-350 ECSB 4x4 Lariat Sterling Gray Metallic. 51,000 mi
Mods: Silver Star Ultra bulbs, M&S Mini-Maxx, MBRP "Race" Exhaust
North East Mid-Atlantic Diesel Club:
#51
MrPlowJr_EZ_V is offline
post #4 of 21 (permalink) Old 09-03-2006, 07:44 PM
For almost as much as a new one they will reprogram it. They know that someone is probably still running that program. Don't waste your time and money just call Jody at DP-Tuner and get awesome programming.
2002, F350, Lariat, CC, LB, PSD, QLJ5, A/T, ESOF(with hub disable switch), LS, Off Road pkg, AIC, Jordan 2020, X-monitor, IAH removed, Fuel pressure shimmed, DP-Tuner 80 econo, acetoned badges, 315 BFG's on Alcoa's, 4"DPPI exhaust, Sonnax/Tricumulator, DIY BIG air filter with ZooDad, Bilsteins, EBV removed, WW, Proflex SS sleeves over the orange manifold hoses, MAP connected to adjustable pressure regulator, EBPS connected to intake manifold, Red line disconnected, Modified factory wastegate, 200 amp large case alternator, AutoEnginuity, Chris Thompson, SoCal Biodiesel Users Group member, Soon to have a bunch of goodies from Riffraff Diesel.
Duzitall is offline
post #5 of 21 (permalink) Old 09-03-2006, 07:45 PM
Maintain's Avatar
At least you can still use it as a code reader [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2001 F250 CC/SB Platinum
11.62 @ 115.79
SWAMPED
Maintain is offline
post #6 of 21 (permalink) Old 09-04-2006, 09:51 AM
NCHornet's Avatar
Use it as a code reader and get a real tune from Jody!
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
NCHornet is offline
post #7 of 21 (permalink) Old 09-04-2006, 10:26 AM
Their solution will be "Buy a new one". I had my PCM fail several years ago with the SCMT tune on it. I called up SuperChips to ask them what could be done. I even had the paperwork from the PCM replacement, they didn't care.
Now in your case it's obvious that someone loaded the program onto their truck and figured they didn't need the tuner anymore. God help them if it goes to the dealer tuned.
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline
post #8 of 21 (permalink) Old 09-04-2006, 06:21 PM
JimTJr's Avatar
My Photos: (20)
Being "Vin Locked" could Jody still put any tunes on it? ( I belive he does that, puts tunes on some of the SCMTs,,not sure if they are special ones or not,,but what the hey,, the tunes would be better than the original ones I bet!!)
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #9 of 21 (permalink) Old 09-04-2006, 06:35 PM
My Photos: (14)
Send a message via AIM to edub32
I do believe that Jody uses the SCT Xcal2 to put his tunes on.
2001 F350 7.3 SCLB 4x4 Off-Road SRW
- DP Tuner, Tymar intake, 35" BFG Mudders on 16x10 Mickey T's, Superlift 6" lift, DiPricol 3 gauge Pillar, 4" SS DP to 5" sidepipe to 6" Chrome tip, WW, Panasonic Deck with 4xInfinity References, Overboost Elim., CCV
edub32 is offline
post #10 of 21 (permalink) Old 09-04-2006, 10:09 PM
JimTJr's Avatar
My Photos: (20)
I didnt know which one he used,, didnt know if he had the capability to reprogram a regular SCT or not,,,[img]/ubbthreads/images/graemlins/shrug.gif[/img]
JimTJr is offline
post #11 of 21 (permalink) Old 09-04-2006, 10:21 PM
My Photos: (22)
SCMT and SCT are two totally different companies.
Hammer
Check out what I recently bought:
I still have the:
2001 F250 Lariat CC/SB 4x4 7.3 auto
TERMINATOR HPOS...Ceramic coated Garrett GTP-38R with BBHA & GDS outlet...DP-tuner Big Oil Program...ITPdiesel Fueling and overboost regulator...6.0 CAC...AFE Stage-II PG7... Magnaflow 3.5dp/4exh...5R110 TC, BTS VB, John Wood pump mods, & V10 cooler...Schaeffer's 9000 5w-40...Oilguard bypass...and other stuff
On the shelf collecting Dust: <font color="green"> Stainless Grill Overlay </font>
<font color="red">
</font>
Get Your Tuning Here:
and your Fuel kits here:
TheHammer69 is offline
post #12 of 21 (permalink) Old 09-04-2006, 10:38 PM
Cool_Canuck's Avatar
My Photos: (12)
Nope. I asked Jody about reprogramming my SuperChips. Said no can do.
I asked SuperChips about modifing a couple of things. Said they could but won't.
2011 f250 XLT 4X4 Crew Cab.
SOLD - 2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/
; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED;
Cool_Canuck is offline
post #13 of 21 (permalink) Old 09-05-2006, 06:26 PM Thread Starter
RPMOffroad's Avatar
I already have a 6 pos. chip just bought this thinking i could resell! They said $200 and they could reprogram it to work on any truck! How much are one of these things worth it looks brand spankin new?
post #14 of 21 (permalink) Old 09-05-2006, 06:38 PM
brett_kartracer's Avatar
The reason why they want so much to program it is because they usually sell each of their tunes for a set price. So if you need to have all six positions reprogrammed you have to pay that price times six!
I bought a 16 position chip. I only bought three programs, so it cost about $380.
-Brett
2001 F-250 Powerstroke, Automatic. Zoodad mod, Airaid filter, muffler delete, Boost fooler, Edge Evolution, Turbonetics 0.84 turbo. Best 14.88@88MPH, 314hp@617trq.
1989 F-250 7.3 IDI N/A, 5 speed, no muffler. Injector Pump turned up 145*.
brett_kartracer is offline
post #15 of 21 (permalink) Old 09-05-2006, 06:50 PM Thread Starter
RPMOffroad's Avatar
the 6 pos. chip in my truck is fine i just bought this superchip programmer cheap to resell and wanting to know how much it is worth! this isn't for my truck!!
