Superchips leads to missfire/shaking engine... ideas? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 01-11-2007, 05:02 PM   #1 (permalink)
I let my friend try out my superchips so I can sell it and buy a real chip.
Half way through the day he stops back, with a horrible running truck. He said it ran fine, until he stomped on it (he did many times before), and it instantly set a code. It also idles bad, and all around runs like crap.
Is this missfire a direct relation to the programmer? The truck is a 2001, has 52k miles on it, and a recent CPS change.
The only code it has is a PO603 KAM something or other, that apparently is normal, though it never came up on mine.
I'm going to get a OTC scan tool tonight, and do the buzz test, but any other ideas?
BTW.. all different levels of programming, back to stock, and OTC scan tool didn't fix the problem. The KAM code comes up instantly, and the misfire is still there.
Thanks,
Joe
Joe92GT is offline
Old 01-11-2007, 06:28 PM   #2 (permalink)
Re: Superchips leads to missfire/shaking engine... ideas?
I did some more testing, and it looks like injector number 2 is failed. My guess is that it was failing, and the programmer helped it along.
Before I go pulling everything apart, any other ideas?
Heres what I found:
cylinder contribution test gave code P0266 Cylinder 2 contribution/balance fault
KOEO test gave code P1272 High to low side open cylinder number 2
KOER test gave code P0476 exhaust back pressure control vavle
Thanks,
Joe
Joe92GT is offline
Old 01-11-2007, 08:20 PM   #3 (permalink)
I would bet that the uvc harness is coming apart. I would get a new updated one from ford.
Master Certified Diesel Tech
1999 F-350 4 door long bed 4x4. 4in lift, deaver springs, fox shocks, dynomite injectors on the way, dp tuner F5, dual 7.3 fuel pumps, Spearco retrofit intercooler, custom regulator return kit, ceramic coated IH up pipes, 5in mitre cut stacks, custom front bumper. Terminator High Pressure Oil!
<font color="red">Black Widow Diesel exclusive Turbonetics Towing Compound turbo kit-In testing. More info available soon at
www.BLACKWIDOWDIESEL.COM</font>
]http://community.webshots.com/album/557759938HUntVs]
www.BlackWidowDiesel.com
www.TerminatorEngineering.com
sanddrag69 is offline
Old 01-11-2007, 08:35 PM   #4 (permalink)
69mach1377's Avatar
I'm guessing you lost a sale...
2000 F250 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, Fully gaged, Cold air intake mods beyond zoodad, Stacked tuners, 4" Exhaust w/dual 3.5" outlets, 295/75/16 BFG ATs on 8" rims, 08 AlumDiffCvr, Bilsteins, otherwise mostly stock.
24' 5th wheel camping trailer, no RV parks...just the woods.
2005 VW Passat 2.0 TDI, 40+ mpg hiway
1969 Mustang Mach1 HotWheel, 377 clevor, R&P steering, 3.50 posi, 2003 Mach1 Wheels (17s)
69mach1377 is offline
Old 01-11-2007, 08:41 PM   #5 (permalink)
The programmer didn't do it, it was just coincidence. Uvc harnesses come apart all the time.
Old 01-12-2007, 04:29 PM   #6 (permalink)
Thanks guys. I know its not the chip, but it was just a big coincidence that it happened the same day.
I didn't loose the sale, he still wants it! My order will be in with Jody Monday.
Back to the other truck.. Problem fixed itself. That means its most likely the UVC harness. An injector won't fix itself, right?
Thanks again,
Joe
Joe92GT is offline
