T/C Lock up? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 03-27-2008, 05:16 PM   #1 (permalink)
T/C Lock up?
can anyone tell me how/what torque converter lock up does... and how to use it to make my truck blow alot of smoke, saw it on youtube and became intrested.
thanks any help is appreciated\
Dwayne Jr
2000 F-350 7.3 Turbo w/ Ts Performance chip, dfuser 18k, 5inch exhaust, gunna get AFE stage 2 intake, DIY stage 2 injectors, and the X-Wheel.
1975 Ford F-350 W/1965'390FE 4Speed w/ Granny low and 4.10s(top speed of about 7MPH in 1st), Crane cam and Flowtech Headers...ready and willing to pull ANY chevy/dodge or both.
RedHotNrollin2000F350PSD is offline
Old 03-27-2008, 08:43 PM   #2 (permalink)
Simply put, it's a switch that completes a ground from the pcm to tell the torque converter to lock up before the pcm would normally tell it to. It also is an instant lock up instead of a slow smooth lock up like the pcm would send. You simply install a wire from a wire in the harness to a switch and then to a ground. Get the rpms above 1200, throw the switch and the torque converter locks. If you don't back off the throttle a little it slams into full lock. The only way it could make more smoke is because the engine basically bogs down from the shift and then would have too much fuel going to it until the turbo spools back up. The purpose is to put ALL the power to the wheels at one time and earlier than the pcm would do it. I use it to keep the trans mission from unlocking while pulling the camper. Also for keeping the torque converter locked while holding the truck back when going down the mountain roads.
Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
MOUNTAINMAN444 is offline
Old 03-28-2008, 02:31 PM   #3 (permalink)
so when should i engage it to make the truck smoke more...before or after i take off, and can it to any damage to the truck?
thanks for the help....and i like yer name
MoutainMan
Old 03-28-2008, 02:45 PM   #4 (permalink)
Send a message via Yahoo to treytroxell
you lock it right after you take off about 5mph but its not good on the T/C at all and if you have a stock T/C it will blow up in a few trys
1999.5 Ford F-250 7.3l 4x4 PSD With some extras
treytroxell is offline
Old 03-28-2008, 02:56 PM   #5 (permalink)
well that was a big disappointment..... is there anyother way to make a truck blow smoke...not a chip or injectors but like a truck to get it to blow smoke, ive got the chip and everything.....just wanna blow black lol
thanks
Old 03-28-2008, 03:24 PM   #6 (permalink)
Charcoal_02's Avatar
If you compare it to manual trans, when you let out on the clutch there is no slippage which allows you to lug the engine(you could be in second at 10mph). An automatic at slow speeds and low RPMs will slip or be in a low enough gear which would prevent the engine from lugging.
The TC lockup would allow you to lock the converter(stop slippage). So you could be at slow speeds or low RPMs, stomp the go pedal, and cause over fueling and black smoke.
With my programmer and no TC lock up, my stock tranny likes to slip into 4th gear a little early(40-45mph, 1200rpm) if I'm accelerating slowly. Sometimes when I'm wanting to fog someone, I let it slip into 4th a little early and mash the pedal about 3/4 of the way down. If you mash it to the floor at 45mph it will down shift and the air clears up pretty quick after that.
P.S...Could you shorten up that signature so you don't have to scroll down to Mexico to read all the posts?
'02 Ford-350, 7.3L!!, 4x4, CC, 3:73's, straight 4" exhaust(early exit), Edge Evolution programer, Charcoal grey exterior and two-tone grey interior, 308,000 miles and counting
'83 F-250 w/ 7.3L(toasted), 4x4, 3" lift, Bank's Sidewinder, Dark Metallic Blue
Charcoal_02 is offline
Old 03-28-2008, 08:45 PM   #7 (permalink)
for me to fully understand what you said id have to be in the truck trying to do it... and ill try to shorten it ...i guess
Old 03-31-2008, 08:32 AM   #8 (permalink)
thanks
If you have a good chip there shouldnt be any problem getting it to smoke with out having to do the t/c lockup
my DP-Tuner chip on the 40hp setting will smoke but on the 140 aggressive it will smoke out any cummins around here.
Old 03-31-2008, 11:20 AM   #9 (permalink)
a chip is the best way to make it...it also improves power substancially, and can give you mpg gains at the fuel pump. a chip can literally payfor itself in less then a year.
If you you , don't get speeding tickets, and learn how to go easy on the pedal with a chip.
you also should get an egt guage at the minimum...but chips are great.
early 99 f350 4x4 crew cab
work in progress
southmike is offline
Old 03-31-2008, 04:56 PM   #10 (permalink)
my Ts smokes like a freight train too...but do to the rev limiter it only smoke for about 10 seconds then the rev limiter kicks in and it just stops blowin...even at high rpm.
Old 03-31-2008, 09:52 PM   #11 (permalink)
Powerstrokedogg's Avatar
Send a message via ICQ to Powerstrokedogg
if you want smoke cheap put a bag over your air cleaner
2001 F-350 7.3L 4X4(ESOF) CC LWB 4R100 4X4, WIX 46637 open element air filter, Wicked Wheel, walker BTM, 203* Tstat, IC tube foil removed, coolant filter, AIH removed, 08 aluminum finned rear end cover, DP tuner 80econ 140smoke high idle,Phantom gauges, ATS transmission,ATS deep trans pan, 5 star torque converter, V10 trans cooler, 4" MRBP SS downpipe, twin 4" stacks
1989 F-250 6.9L IDI E4OD 500,000+ miles(sold)
1982 VW rabbit 1.6L diesel
2007 Arctic cat 700 diesel ATV
1975 W900 Kenworth 500 Cummins
1997 Ford school bus 5.9 cummins
Powerstrokedogg is offline
Old 04-01-2008, 06:26 AM   #12 (permalink)
don't you know that smoke means your are wasting power and its bad for the motor? all you want is just a little hase of smoke at WOT
Old 04-01-2008, 02:35 PM   #13 (permalink)
who wants a little haze.....i wanna kill all the misquitos in a 4 mile radius
Old 04-01-2008, 02:46 PM   #14 (permalink)
i used to be just like you till i realized how much more power you can get when you do it right. trust me if i want to i can still smoke out the cars behind me to where they cant see but once the turbo is spooled why do you want that much smoke? so you can tare up your truck? how old are you any way 16. you will learn one day when you have to pay to fix what you thought was so cool.
