Tapping Map Sensor Boost line - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 99 & up 7.3L Engine
Upgrades and Aftermarket - 99 & up 7.3L Engine Upgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
Old 05-04-2006, 05:27 PM   #1 (permalink)
I was wondering if it matters if the line leaks a bit. I went to Ace Hardware and got two barbs for the right hose size, and a connecter that connects the two threaded barbs. this fitting also has a threaded top so I can screw the right tap into it to tap the line. these are all brass fittings..
If the fitting leaks what are the issues? I have no real way of testing it but im sure it leaks a bit. I didn't want to use teflon tape cause I didn't want to ruin teh map sensor.
02 F250 PSD 7.3L
Cobra 29 NW ST CB radio
5% tint everywhere with 20% down the whole front windshield
Tymer intake setup
4 inch DP to a 5 inch straight pipe
Air Bag w\ compressor setup
triple gauge pod w\ Di-Pricol Optix (EGT,Boost,tranny temp)
CCV Mod, In-tank mod, Harpoon mod, Airdog Kit, AIH Delete
ITP regulated Return (8LL replaced with AD)
Oilguard Bypass Oil System
Dieselsite Coolant Filter, Fluidampr
ITP boost Annihilator, BTS Trans and T.C.
DP tuner 6 position, ATS housing
02Powerstroke is offline
Old 05-04-2006, 05:42 PM   #2 (permalink)
My Photos: (31)
Re: Tapping Map Sensor Boost line
Your boost gauge won't read correctly, it will read low. I [img]/ubbthreads/images/graemlins/shrug.gif[/img] guess it depends where it leaks from?
2001 F350 XLT White Crew Cab 7.3L Long Bed * (CCV) Racor 4500 * Fumoto (Oil Drain Valve) * AFE Stage II(Pro Guard 7) * AC control valve * AutoMeter Lunar gauges on the pillar (Pyro - Transmission Temp - Boost) * (TTM) Turbo Temp Monitor * 6.0L Tranny cooler * 6.0L IC * 203 Thermostat * (SS) HX-Hose * Non-Wastegated Van Turbo w/ATS housing & Stock Wheel * Gutted Pedistal * Line X * ZooDad Air * 4" DPPI SS dual exhaust from ITP * Aeroturbine 4040 * Donahoe 2" (mini spring packs) leveling kit * F5 DP Tuner chip with live custom tunes * Brians Truck Shop Transmission (BTS)
Truck Pictures
Webshots
Ford Makes It - International Shakes It "FOMOGO"
Humdinger is offline
Old 05-04-2006, 05:45 PM   #3 (permalink)
can I use teflon tape on the pieces I have? There wasn't a "one piece" part taht would allow me to tap the line.. I had to use multiple parts..
02 F250 PSD 7.3L
Tymer intake setup
Old 05-04-2006, 07:27 PM   #4 (permalink)
i have used teflon tape on one of my trucks and never had a issue thus far, and if your connection leaks your killing yourself in two areas.........inaccurate readings and loss of boost pressure to the motor......you should also replace those cheap ford quick clamps on the boost line itself to keep those from leaking as well.......and depending on your mod future yuou would do well to put a boost relief valve in place of your new t-connector
96 f-350 2wd dually powerstroke roach coach 365k BTS tranny,4.10, XLT,alcoa alloys,tymar intake,western diesel downpipe, a/c bypass mod,coolant filter behind front bumper, beans stage 1's,dp tuner 60hp pcm, hx hardline crossover from ITP......
01 f-350 dually powerstroke lariat supercab 61k 4.10 4x4 ESOF, leather, heated seats all the toys i dont need, 4r100,garret ball bearing turbo,tymar intake, ccv redirected out under the truck,magnaflow 4inch tuner exhaust, a/c bypass mod,zoodad mod,autometer cobalt pyro boost and tranny,dp tuner 4program chip,ITP complete regulated return fuel kit,ITP hx crossover hard line,203 t-stat and dieselsite billet t-stat neck, coolant filter,dieselsite high pressure intercooler boots
2009 F-450 dually 6.4 auto 4.30 2wd XLT power pedals,aux cab heater, dual alternators,bostonian catering body,stock everything for now......things to change soon
chris bottom is offline
Old 05-04-2006, 08:32 PM   #5 (permalink)
you wioll never no if it leaks and it wont leak any way.you dont need anything on them.it is air not feul and it is so small of a leak it could not be mesured.dont wory about it.it is not what you would call a boost leak.
2000 f250 4x4 lariate woodland green metalic and gold on the bottom.sharp looking super cab.100,000 miles .air heater mod,CCV mod,zoodad,80 econo DP tuner PCM ,cranked doun stock waste gate,cubie hole type gauge pod,k@n replacement filter.sonax/tricumulator, map sensor pop off valve,boost tube,BTM ,code eliminators ,wiked wheel,EBPV deleat ,hp oil cross over feul presure shimed and gauge, Heater core hose bypass valve .Wet Okole seat covers with Powerstroke logo ,.home made donaldson intake in the works parts on order.mounting bracket and 45* silicone elbo.piss on this homemade thing it will never be as good as the AFE stage II.thats what i'll get next.i am curently running my stock air box
WUNDERHOOT is offline
Old 05-04-2006, 08:44 PM   #6 (permalink)
I agree with Wunder here. It will have no affect on the engine's airflow. The amount of air that would pass through the threads of a fitting is minuscule. The Ford quickie clamps are more than adequate for 1/4" hose. If you use 5/16" you may have to use a worm clamp since it's actually too big for the barb.
This space intentionally left blank.
444turbodiesel is offline
Old 05-04-2006, 10:25 PM   #7 (permalink)
Just finished installing my gauges. I took it for a run and am only reading MAx 14 pSI boost with the autometer 'z' gauge. I have changed the exhaust to an MBRP 4" turbo back and a K&N air intake. Other than that truck is stock 100k miles. Is this # OK?
2000 f-350 Lariat LE Dually 7.3 PSD 4x4 Auto. 4.10 gears
Autometer gauges, MBRP 4" exhaust, K&N Intake FIPK
tntmotorsports is offline
Old 05-04-2006, 11:52 PM   #8 (permalink)
Strictly Diesel's Avatar
Feedback Score: 3 reviews
Send a message via ICQ to Strictly Diesel Send a message via AIM to Strictly Diesel Send a message via MSN to Strictly Diesel Send a message via Yahoo to Strictly Diesel
If it bugs you, THIS will clean up the install.
Dennis Schroeder - Strictly Diesel
Phone :: 623-582-4404
E-Mail :: sales@strictlydiesel.com
Main Website :: www.strictlydiesel.com
Web Store :: shop.strictlydiesel.com
Race Truck :: 5500# / 422hp+ / 12.66 @ 105mph / Best 60' of 1.67 ... on 226k Mile PMRs!(PMR engine retired)
Race Truck :: 5800# / ???hp / 11.94 @ 114mph / Best 60' of 1.76 ... with "Built" Race Engine
Strictly Diesel is offline
Old 05-05-2006, 04:50 AM   #9 (permalink)
That piece that Dennis is pointing out is a nice one. You can see pics of it installed on my truck in my sig (along with ITP's boost regulator), in the Performance Mods album.
PS - Dennis.... pics of the ATS and Banks big head in my sig, too. [img]/ubbthreads/images/graemlins/cool.gif[/img] Thanks again...
Ryan Arthur
2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
Performance Mods: ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator and tee, ATS ported housing, Banks Big Head, CCV Mod, DP-Tuner flip chip, BTS valve body ||| LEDs everywhere: taillights/running boards/mirrors/rear, side lights wired as turn signals, upgraded headlight harness w/ Xtravisions, aux backup lights in bumper ||| Misc. Mods: no more dingers, newer cupholder, fumoto, C-Betrs, locking fuel cap, mud flaps, wannabe air horn, Line-X, behind-seat storage shelf, intercooler foil wrap removed, SS HPX
My Truck Pics
NorCal Powerstrokes
ryaneverk2 is offline
Old 05-05-2006, 09:34 AM   #10 (permalink)
My Photos: (5)
If you are planning the AIH delete, then you can get the plug from blackcloud diesel. This also got rid of my rattle in my isspro.
2002 F-250, PSD 6-speed, CC, short bed, 4X4, Toreador Red w/ Silver accent, A.R.E mx cap, Weld Super Single II and 33s in the summer, x-springs, F-350 blocks and badges, AIC, proflaps, ITP intank mod, AirDog with 3 micron filter, isspro guages and TTM, scangauge, husky liners, alarm, xm stereo,stull 5399-p grille, centramatics, ccv mod, AIS Air Filter, Southbend CON O, Detroit Truetrac LSD, coolant filter, 203 stat with billet housing, blackcloud intake heater plug/boost fitting, reese titan hitch, fabcraft PTO cover/temp sender port, prodigy brake controller, ITP Boost Annihalator, oilguard bypass filter, Mag-Hytec rear dif, bilsteins, hellwig rear stabilizer bar, ATS housing, non-ebpv pedistal and exhaust flange, magnaflow 3.5dp exhaust, ITP reg return, turbomaster wastegate controller, and ceramic coated bellowed up pipes, PHP 50t and 80p, currently 96,100 miles. truck Pictures
clydesdale is offline
Old 05-05-2006, 10:27 AM   #11 (permalink)
finished install... dieselpowerproducts is going to send me a T- fitting that im going to swap out.. everything works great... saw max boost of 18 psi right near the end of my gear..
only thing that was weird was my egt was about 400 when I parked, then I let it idle cause I thought I heard something in the engine compartment (other than the clanking of the engine) and was looking around, got back to my truck and the EGT was up around 550 or so.. whats that about?
02 F250 PSD 7.3L
Tymer intake setup
