Upgrades and Aftermarket - 99 & up 7.3L EngineUpgrading or adding OEM or aftermarket equipment to your 1999-Up Super Duty or Excursion with 7.3L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 7.3L Power Stroke engine.
There is a Teflon tape that is fuel and oil safe. I used it for the fittings when I installed the regulated fuel system on my truck, also on the fitting of my trans temp sender. It was yellow instead of white and I picked it up at the local parts store. Pretty cheap if my memory is correct. You are right that there is no sealant on the drain plug but it also see's very little pressure, unlike an oil or fuel line. For me it was cheap insurance to prevent any leaks and to not have to do it over again. jmho
2001 Ford F-350 drw 4x2 auto,4.10 gears,Turbonetics ball bearing turbo, Turbo Master Wastegate controller, Dieselsite Boots, ceramic coated up-pipes and exaust manifolds, DIY Tymar, 4 inch exaust turbo to tip, Isspro guages EGT,Boost, Trans temp from DieselManor, 6.0 trans cooler, AIH delete with boost attachment, ITP Regulated Fuel Return kit,hutch and harpoon mod done, ITP in tank and prepump mod kit, Rotella ELC, 203 Stat. Oil Guard by-pass filter system
DP Tuner-no start, stock,40,60,80E,120
BTS Transmission,(BTS-BUBBA)
105,000 miles, built to tow
Toys: 03 Screaming Eagle Duece Harley
37ft Cyclone by Heartland 5th wheel toy hauler
You don't need sealant/tape on the hose side of the fittings, but you do need it on the block side of those fittings. Even the manual says it doesn't matter. Just don't wrap the first 1 or 2 threads (1st ones to go in and get threaded) with either. I used tape and it works great.
Don't know how true this is but I heard from a plumber that pipe dope and teflon tape do not really seal anything, they just provide lubrication of the threads to enable a tight enough fit to seal the connection.
